The results of garuda-inxi are appended.
I am a born-yesterday user of Garuda and Linux in general. Please be patient.
I am using Cinnamon and wanted to change it. Reinstalled Garuda from scratch and this time was not offered a choice of desktop environments. What did I do wrong?
The underlying issue is that either Garuda or Cinnamon is superimposing Garuda cursors over other software. This is annoying at best. With one work-critical program, it is superimposing a video-game gunsight over the program's own crosshairs. It is not entirely in synch with the crosshairs, which move in fixed increments, and causes two pixels to blink where they overlap. This is infernally distracting during a process where I can't afford to be distracted. So:
Is this characteristic of Garuda? If so, how can I prevent the problem. If I can't fix it, I will have to abandon Garuda--with great reluctance, as it seems otherwise a viable escape from the Borgs of Bellingham and Cupertino.
I have searched for answers but have not found anything on point.
Thanks for any help you can provide.
Kernel: 5.19.7-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=99d033ae-700a-4c92-8968-78ccb176889b rw rootflags=subvol=@
Desktop: Cinnamon v: 5.4.12 tk: GTK v: 3.24.34 wm: Mutter vt: 7
dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: MSI model: H110M PRO-VD (MS-7996) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 2.70
date: 06/16/2016
Info: model: Intel Core i5-6400 bits: 64 type: MCP arch: Skylake-S
gen: core 6 level: v3 built: 2015 process: Intel 14nm family: 6
desc: 1x6 MiB
Speed (MHz): avg: 2225 high: 2700 min/max: 800/3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 2700 2: 2700 3: 800
4: 2700 bogomips: 21599
disabled
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT disabled
PBRSB-eIBRS: Not affected
Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] vendor: ASUSTeK driver: nvidia
v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
(as of 2022-08) arch: Maxwell code: GMxxx process: TSMC 28nm
built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1380 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa gpu: nvidia
s-diag: 610mm (24")
Monitor-1: VGA-0 res: 1920x1080 hz: 60 dpi: 92
size: 531x298mm (20.91x11.73") diag: 609mm (23.97") modes: N/A
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fbc class-ID: 0403
Sound Server-1: ALSA v: k5.19.7-zen2-1-zen running: yes
Local Storage: total: 237.89 GiB used: 13.46 GiB (5.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD8SBBU240G1122
type: SSD serial: <filter> rev: 6000 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Cruzer
size: 14.32 GiB block-size: physical: 512 B logical: 512 B type: N/A
ID-1: / raw-size: 223.27 GiB size: 223.27 GiB (100.00%) used: 13.46 GiB
(6.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 223.27 GiB size: 223.27 GiB (100.00%) used: 13.46
GiB (6.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 223.27 GiB size: 223.27 GiB (100.00%) used: 13.46
ID-5: /var/tmp raw-size: 223.27 GiB size: 223.27 GiB (100.00%) used: 13.46
ID-1: swap-1 type: zram size: 15.59 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 36.0 C pch: 39.0 C mobo: N/A gpu: nvidia
temp: 42 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 229 Uptime: 1h 46m wakeups: 0 Memory: 15.59 GiB used: 2.8 GiB
(18.0%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1350 libs: 325
tools: paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.21
Garuda (2.6.8-1):
System install date: 2022-10-03
Last full system update: 2022-10-03 ↻
