Hello.
I am having problems using my computer after a failed update
after i tried to update my PC with the Garuda updater, it gives me the error
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur is up to date
resolving dependencies...
:: installing dav1d (1.0.0-1) breaks dependency 'libdav1d.so=5-64' required by ffmpeg-vulkan
i reset my PC and now i can't use my desktop environment but i can see my desktop and open apps by typing the app name.
sorry I'm new to using Linux so i don't know what that's called.
my Firefox also is grey if that helps.
i can tab screenshot and open apps just no dock or bar at the top.
i don't really know what to try and can't find any help with the error message or by searching this problem.
Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=10b0d1b1-1e65-4e4d-bbe1-bc7c6a0c0c0c rw [email protected]
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 info: latte-dock
Type: Desktop Mobo: ASRock model: B450 Gaming K4
serial: <superuser required> UEFI: American Megatrends v: P5.10
date: 08/04/2021
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3702 high: 4178 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4147 2: 4178
3: 3610 4: 3601 5: 3596 6: 3586 7: 3595 8: 3587 9: 3589 10: 3737 11: 3599
12: 3609 bogomips: 86405
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
vendor: Micro-Star MSI driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: HDMI-A-1,HDMI-A-2 empty: DP-1,DP-2,DVI-D-1
bus-ID: 09:00.0 chip-ID: 1002:67df class-ID: 0300
Screen-1: 0 s-res: 3360x1080 s-dpi: 96 s-size: 889x285mm (35.00x11.22")
s-diag: 934mm (36.75")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left
model: Samsung C27F390 serial: <filter> built: 2021 res: 1920x1080 hz: 60
dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27")
Monitor-2: HDMI-A-2 mapped: HDMI-A-1 pos: right model: NEC LCD193WXM
serial: <filter> built: 2007 res: 1440x900 hz: 60 dpi: 90 gamma: 1.2
size: 408x255mm (16.06x10.04") diag: 481mm (18.9") ratio: 16:10 modes:
max: 1440x900 min: 720x400
OpenGL: renderer: AMD Radeon RX 580 Series (polaris10 LLVM 13.0.1 DRM
3.44 5.17.5-zen1-1-zen)
v: 4.6 Mesa 22.0.2 direct render: Yes
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-10:3 chip-ID: 0c76:161e
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 2.04 TiB used: 1.09 TiB (53.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000BX500SSD1
type: SSD serial: <filter> rev: 054 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400M8240G
type: SSD serial: <filter> rev: 62B3 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST31000524AS
type: HDD rpm: 7200 serial: <filter> rev: JC4A scheme: GPT
used: 52.51 GiB (23.5%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 15.55 GiB used: 2.8 MiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 54.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 256
Processes: 370 Uptime: 7m wakeups: 0 Memory: 15.55 GiB
used: 4.2 GiB (27.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1942 lib: 534 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-04-25
Last full system update: 2022-05-05
Is partially upgraded: Yes
