Is there any rationale behind the disappearance of desktop effects such as wobbly window, magic lamp and transparent window switch, etc. I was just messing around with conky and after that some of these beautiful desktop effects stopped working.
And when I checked desktop effects in system settings they are unavailable. Any suggestion will be a great help.
Go to System Settings, then Display Configuration, then Compositor and see if there's a message there about Compositor having crashed and you have to click on something to re-enable it. If it doesn't get re-enabled, try making a change to "Allow applications to block compositing" and Apply. If this doesn't fix it, try pressing Ctrl+Alt+F12 but be advised [!] that it can crash the system (it crashes mine) and you have to Ctrl+Alt+Del then to restart.
But again, this should work: 1. System Settings 2. Display Configuration 3. Compositor 4. See the warning and respond to it there.
It shouldn’t crash it, it should just switch to TTY without a shell (black screen with a blinking cursor). To get back you can just go to TTY1 with Ctrl+Alt+F1
The problem is, it’s the wrong shortcut.
The default “Suspend Compositing” shortcut on Plasma is Shift+Alt+F12. Hit it twice to disable and enable compositing.
