Kernel: 5.16.9-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=f062fbe5-d376-4d74-9fa2-c38191c4ebe8
Desktop: KDE Plasma 5.24.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: X470 AORUS ULTRA GAMING v: N/A
Mobo: Gigabyte model: X470 AORUS ULTRA GAMING-CF serial: <superuser required>
UEFI: American Megatrends LLC. v: F62c date: 10/01/2021
Info: model: AMD Ryzen 9 3950X bits: 64 type: MT MCP arch: Zen 2 family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache: L1: 1024 KiB
desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 4000 high: 4293 min/max: 2200/4761 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 4037 2: 4286 3: 3744 4: 4251 5: 3664
6: 4270 7: 4292 8: 4192 9: 3461 10: 4121 11: 4072 12: 4278 13: 3781 14: 3633 15: 4079 16: 3552
17: 4242 18: 4293 19: 3465 20: 3858 21: 4265 22: 4276 23: 4179 24: 4231 25: 4275 26: 4281
27: 4278 28: 4282 29: 3545 30: 3425 31: 3905 32: 3507 bogomips: 224007
mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: Gigabyte driver: nvidia v: 510.54
alternate: nouveau,nvidia_drm bus-ID: 09:00.0 chip-ID: 10de:2484 class-ID: 0300
Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0
Screen-1: 0 s-res: 5760x1080 s-dpi: 91 s-size: 1605x301mm (63.2x11.9") s-diag: 1633mm (64.3")
Monitor-1: HDMI-0 res: 1920x1080 dpi: 92 size: 530x300mm (20.9x11.8") diag: 609mm (24")
Monitor-2: DP-0 res: 1920x1080 hz: 144 dpi: 94 size: 521x293mm (20.5x11.5")
diag: 598mm (23.5")
Monitor-3: DP-3 res: 1920x1080 dpi: 81 size: 600x330mm (23.6x13.0") diag: 685mm (27")
OpenGL: renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2 v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 09:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Kingston HyperX QuadCast type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 5-2:3 chip-ID: 0951:16df class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.16.9-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.46 running: yes
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel port: f000
bus-ID: 06:00.0 chip-ID: 8086:1539 class-ID: 0200
Device-2: Ralink RT2870/RT3070 Wireless Adapter type: USB driver: rt2800usb bus-ID: 5-1:2
chip-ID: 148f:3070 class-ID: 0000 serial: <filter>
IF: wlp11s0f3u1 state: down mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 5-3:4
chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
Local Storage:
total: 5.95 TiB used: 387.01 GiB (6.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G size: 447.13 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 61K1 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SDSSDH3 2T00 size: 1.82 TiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 20RL scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD30EZRX-00SPEB0 size: 2.73 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 0A80 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital model: WDS100T2G0A-00JH30
size: 931.52 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 0000 scheme: GPT
ID-5: /dev/sde maj-min: 8:64 type: USB vendor: SanDisk model: USB 3.2Gen1 size: 57.3 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 115.93 GiB (12.4%) fs: btrfs
dev: /dev/sdd2 maj-min: 8:50
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
dev: /dev/sdd1 maj-min: 8:49
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 115.93 GiB (12.4%) fs: btrfs
ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 115.93 GiB (12.4%)
fs: btrfs dev: /dev/sdd2 maj-min: 8:50
ID-5: /var/tmp raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 115.93 GiB (12.4%)
ID-1: swap-1 type: zram size: 31.33 GiB used: 22.5 MiB (0.1%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 30.0 C mobo: N/A gpu: nvidia temp: 51 C
Fan Speeds (RPM): cpu: 1147 fan-2: 178 fan-3: 845 gpu: nvidia fan: 0%
Power: 12v: N/A 5v: N/A 3.3v: 1.68 vbat: 1.58
Processes: 573 Uptime: 2h 42m wakeups: 0 Memory: 31.33 GiB used: 7.64 GiB (24.4%) Init: systemd
v: 250 tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1578 lib: 472
Client: shell wrapper v: 5.1.16-release inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2022-02-06
Last full system update: 2022-02-17
Servus erst ein mal an alle
Ich habe folgendes Problem. Das mein Globales Design manche Programm für mich nicht mehr nutzbar sind. Ich kann z.b. die Schrift nicht mehr Lesen oder die Verschiebe Balken kann man nicht mehr Sehen.
Kann ich nicht manche Programm aus dem Deisgn auschließen?
Hier ein Bild von Audacity.
Man kann unten deutlich erkennen das der Balken zum Verschieben fehlt.
So sollte es eigentlich Aussehen.
Ich dachte ich könnte vielleicht hier eine Einstellung dazu finden. Leider ohne Erfolg.
In Audacity habe ich das Design auch schon extra geändert. Dann wird es aber nur schlimmer.
Hoffentlich hat man verstehen können was ich meine. Ich danke allen schon mal
