root=UUID=949f120b-6fda-47c9-8302-5cc39177e07b rw rootflags=subvol=@
rd.luks.uuid=9d3e9398-8c28-4e4e-94ce-6270ff9d82ac loglevel=3 pci=noaer
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Laptop System: Micro-Star product: GE75 Raider 10SF v: REV:1.0
Mobo: Micro-Star model: MS-17E9 v: REV:1.0 serial: <superuser required>
part-nu: 17E9.1 uuid: <superuser required> UEFI: American Megatrends
v: E17E9IMS.10D date: 11/17/2020
ID-1: BAT1 charge: 22.2 Wh (56.2%) condition: 39.5/51.6 Wh (76.7%)
volts: 11.1 min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xFC
Speed (MHz): avg: 4860 min/max: 800/5000 scaling: driver: intel_pstate
governor: powersave cores: 1: 4860 2: 4860 3: 4860 4: 4860 5: 4860 6: 4860
7: 4860 8: 4860 9: 4860 10: 4860 11: 4860 12: 4860 bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU106M [GeForce RTX 2070 Mobile / Max-Q Refresh]
vendor: Micro-Star MSI driver: nvidia v: 570.133.07
alternate: nouveau,nvidia_drm non-free: 550/565.xx+ status: current (as
of 2025-01; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: none empty: DP-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:1f14 class-ID: 0300
Device-3: Bison HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-13:5 chip-ID: 5986:211c
class-ID: 0e02
display-ID: 0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x176e built: 2019 res:
mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 128 gamma: 1.2
size: 381x214mm (15x8.43") diag: 437mm (17.2") ratio: 16:9
modes: 1920x1080
drv: iris x11: drv: iris
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.0.3-arch1.1
device-ID: 8086:9bc4 memory: 15.21 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.309 layers: 14 device: 0 type: integrated-gpu
name: Intel UHD Graphics (CML GT2) driver: N/A device-ID: 8086:9bc4
surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 2070 driver: N/A device-ID: 10de:1f14
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
API: ALSA v: k6.13.8-zen1-1-zen status: kernel-api with: aoss
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 1969:e0b1 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:6 chip-ID: 8087:0026
Local Storage: total: 1.84 TiB used: 405.54 GiB (21.5%)
model: MZVL21T0HCLR-00B00 size: 953.87 GiB block-size: physical: 512 B
fw-rev: GXA7301Q temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
used: 405.54 GiB (42.5%) fs: btrfs dev: /dev/dm-0 maj-min: 253:0
mapped: luks-9d3e9398-8c28-4e4e-94ce-6270ff9d82ac
used: 768 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 31.16 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 55.0 C pch: 62.0 C mobo: N/A
Memory: total: 32 GiB available: 31.16 GiB used: 4.34 GiB (13.9%)
Processes: 363 Power: uptime: 11m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.4 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1759 libs: 529 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 4.0.1
System install date: 2025-03-12 (fresh install for the change to Wayland)
Last full system update: 2025-04-04
I would like to set certain applications to always use the dGPU, regardless of how they are launched. I imagine having a list, in a .conf file, that contains programs that should always be run with prime-run
(or otherwise be presented the dGPU as primary). For example. I always want Firefox to run on the NVIDIA dGPU. There is not ever a scenario, in my use-case, where I would want it to run on the iGPU. Same goes for mpv and a handful of others. I realize that I could prepend the Exec=
line in a .desktop file with prime-run
but that wouldn’t catch instances launched from another application, such as clicking on an external link in Steam.
I figured something would have a hook that would evaluate the application name and, when the app matched a name in the config, set the environment for that app the same as using prime-run
would. Right now I’m resorting to prime-run firefox &
from Konsole which is tedious and does not catch everything. I’ve found posts posing essentially the same question on several sites but they are either unanswered, suggest using DRI_PRIME=1
, suggest using prime-run
, or point to the arch wiki, which I did not find to have a relevant solution.
So the question is:
What can I do to have Firefox launch using the dGPU regardless of whether it was launched:
- using
firefox
- using
prime-run firefox
- using a .desktop file
- clicking a link in another application
- any other way Firefox could be initiated.
