Motain
17 February 2022 09:44
#1
Hello everyone, since my garuda-update of this morning I have a big interface issue. My theme and Alt+Tab shortcut not work well... Normaly the application panel on the bottom should be transparent and not black. This is the same problem with my fish terminal. It should be transparent and not black. Normaly, for the Alt+Tab shortcut, the background is not black but transparent and I have a preview of the working apps but now I have just a big ugly zoom on the app icon.
I think this is just a crash of on app but I can't find how to resolv the problem. Someone have an idea ?
Sorry, I'm new user on the forum and I can't upload any screenshots.
Of course, 2 reboot not solve the problem
Welcome
Can you provide your
Motain
17 February 2022 09:47
#4
Kernel: 5.16.9-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=f327471a-c329-462b-a1dc-fca7bb7580b2 rw [email protected]
Desktop: KDE Plasma 5.24.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Laptop System: LENOVO product: 20TH001AFR v: ThinkPad P1 Gen 3
Mobo: LENOVO model: 20TH001AFR v: SDK0T08861 WIN
serial: <superuser required> UEFI: LENOVO v: N2VET26W (1.11 )
date: 11/16/2020
ID-1: BAT0 charge: 70.4 Wh (96.8%) condition: 72.7/80.4 Wh (90.4%)
volts: 17.4 min: 15.4 model: SMP 5B10X19049 type: Li-poly serial: <filter>
status: Charging cycles: 75
Info: model: Intel Core i9-10885H bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 2 microcode: 0xEC
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4387 high: 5088 min/max: 800/5300 scaling:
driver: intel_pstate governor: performance cores: 1: 4274 2: 5057 3: 4400
4: 4400 5: 4103 6: 4510 7: 1223 8: 4600 9: 4600 10: 4792 11: 5088
12: 5008 13: 4702 14: 4591 15: 4449 16: 4400 bogomips: 76800
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117GLM [Quadro T2000 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1fb8 class-ID: 0300
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:2 chip-ID: 04f2:b6cb class-ID: fe01 serial: <filter>
loaded: modesetting,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (20.0x11.2")
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.3.6
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0401
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.16.9-zen1-1-zen running: yes
Local Storage: total: 953.87 GiB used: 189.02 GiB (19.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 5108AGLA
temp: 35.9 C scheme: GPT
ID-1: / raw-size: 585.94 GiB size: 585.94 GiB (100.00%)
used: 188.99 GiB (32.3%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 33.6 MiB (13.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 585.94 GiB size: 585.94 GiB (100.00%)
ID-4: /var/log raw-size: 585.94 GiB size: 585.94 GiB (100.00%)
ID-5: /var/tmp raw-size: 585.94 GiB size: 585.94 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.98 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: 42.0 C pch: 45.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 2564 fan-2: 2361
Processes: 395 Uptime: 28m wakeups: 4502 Memory: 30.98 GiB
used: 9.32 GiB (30.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1464 pacman: 1458 lib: 349 snap: 6
Shell: fish v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2021-11-16
Last full system update: 2022-02-17
Motain
17 February 2022 09:48
#5
And today I'm not connected to any external screen
filo
17 February 2022 10:06
#6
Please search and check in the settings
the status of the compositor
If it displays an error, try ackniwledging the reset/re-enable.
If this helps, but the problem occurs again, you could try changing the compositor settings to see if you can find a stable configuration.
Motain
17 February 2022 10:14
#7
Default reset solve the error !!!! Thank so mutch
system
closed
19 February 2022 10:15
#8
