Hello!
I've been installing apps, downloading python libraries, and installing extensions but none of them is completing to their fullest apart from downloads that I'm putting on other partitions.
I'm receiving a message that the disk is full, I don't have a home partition but I do have a root partition which is not even nearly full, why aren't they installing?
Hi @AimeCyuzuzo, there is not enough information here to understand what is happening.
Please post the output of garuda-inxi
as requested by the forum template.
Please copy and paste the message you are receiving into the forum thread so we can take a look.
Additionally, the output of df -h
would help.
Output when I run df -h:
Filesystem Size Used Avail Use% Mounted on
dev 1,8G 0 1,8G 0% /dev
run 1,9G 1,8M 1,9G 1% /run
/dev/sda6 98G 29G 69G 30% /
tmpfs 1,9G 100M 1,8G 6% /dev/shm
/dev/sda6 98G 29G 69G 30% /var/tmp
/dev/sda6 98G 29G 69G 30% /srv
/dev/sda6 98G 29G 69G 30% /var/cache
/dev/sda6 98G 29G 69G 30% /var/log
/dev/sda6 98G 29G 69G 30% /root
/dev/sda6 98G 29G 69G 30% /home
tmpfs 1,9G 16M 1,8G 1% /tmp
/dev/sda1 20G 147M 19G 1% /boot
/dev/sda2 9,8G 624K 9,8G 1% /boot/efi
tmpfs 371M 371M 412K 100% /run/user/1000
/dev/sda5 542G 93G 450G 18% /run/media/aimecyuzuzo5/New Volume
/dev/sda4 205G 71M 205G 1% /run/media/aimecyuzuzo5/Another Drive
@BluishHumility I'm installing TensorFlow again so that I'll receive the error and put it on the thread. And as I mentioned before, when I try to install Chrome extensions, I'm having a download error: "Failed - Disk full".
That looks fine but we need to the exact error you are getting in context.
Without seeing the error you are getting it is hard to say what the issue is.
