Default micro theme should be changed to geany, probably
Geany on the left, default on the right. As alacritty is transparent by default, micro should be too.
You can set your colorscheme with Ctrl+E (brings up the console) and then
set colorscheme [your colorscheme]
I think micro is very simple terminal based text editor. It doesn't support themes and transparency, but am not sure.
it does support them, and it's very easy to change one. I literally described the whole process in this post (without including around 30 strings of code needed to create one and also placing a theme in a /.config/micro/colorschemes)
"My" Micro theme.
Where? I am missing something?
Why Geany theme? I have there also not the standard theme :slight_smile:
2021-05-16_16-05
And geany is built-in micro theme, so you should be able to choose it right away. I suggested geany theme only because it's transparent, and it will be a good fit for our transparent alacritty
Damn, its beautiful. Nice find, will add this soon :smiley:
Alright, its done. :smiley:
