just run
git clone https://aur.archlinux.org/linux-cacule.git
cd linux-cacule/
makepkg -s
Headers will be compiled automaticlly with.
just run
cd linux-cacule/
makepkg -s
Got it thanks, did that but with Paru instead though. Hopefully once it's done I don't have all the previous problems I did.
Also next time please create also a Issue at my GitHub.
I dont follow the forum everyday. so its hard to provide a daily support.
or Discord:
Okay no worries, thanks for letting me know. Will report back after the kernel has compiled and look most likely at discord as I use that more
So how long exactly does it take to compile the kernel? Been going for what seems hours haha. Depends on hardware I assume but wow this is loooonnnngggg
Yeah longer than that...
Mine is probably still grinding at home right now
Dude I tried copying a message from the terminal and did Ctrl+C and had to restart
Still having issues with self compiled 5.13.12-2. No audio and stuttering video. Guess I'll try 5.13.12-3
Oh sorry just realised I tagged you, my bad
And again, tell me the correct Issue,
Which is not running ?
Virtual Boxes and GNOME Boxes should run fine.
Regarding your Audi Driver ill going to check the Config.
Are you using the RDB Version or the normal one ?
Compiling right now a fresh kernel.
Uploading it after that. Please report
Compile done.
Download here:
Just vanilla cacule.
Thanks for the build. Unfortunately, this one too has audio problems, now tested on my other Lenovo machine as well.
Don’t know if it means something to you, but the Lenovo vendor logo appears a few times when booting into this kernel, in places where it is just a black screen when booting into a healthy kernel.
I will keep this instance installed, let me know if there are any logs I should post which would be helpful.
In which type "audio" problems?
Which soundcard do you have in ? And your CPU would be interesting.
Because the blackscreen could be caused by the lrng, which is a security feature.
If not ill remove the alsa patch.
But need first info about your CPU/Soundcard
The common way to ask for system Information is inxi -Faz
here - provided already here:
Again Kernel updated, added many codecs for SND and also modules and also removed the alsa.patch
please report.
Still no luck.
When I click volume up/down button, there is a terribly loud crackling noise.
Here is the inxi of this machine while booted into the last one:
inxi -Faz
System: Kernel: 5.13.12-3-cacule x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-cacule
root=UUID=c729be00-7e5b-47f3-995c-8d96822dc4fd rw rootflags=subvol=@ quiet splash
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Convertible System: LENOVO product: 81EM v: Lenovo ideapad FLEX 6-14IKB serial: <filter>
Chassis: type: 31 v: Lenovo ideapad FLEX 6-14IKB serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter> UEFI: LENOVO v: 7QCN43WW
date: 11/28/2019
Battery: ID-1: BAT0 charge: 9.0 Wh (45.9%) condition: 19.6/45.5 Wh (43.2%) volts: 7.5 min: 7.7
model: CPT-COS L17C4PB0 type: Li-poly serial: <filter> status: Discharging
CPU: Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 8E (142) stepping: A (10) microcode: EA cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28800
Speed: 792 MHz min/max: 400/1600 MHz Core speeds (MHz): 1: 792 2: 800 3: 800 4: 799 5: 800
6: 800 7: 799 8: 800
Graphics: Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:4
chip-ID: 04f2:b61e class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.6 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.13.12-3-cacule running: yes
Network: Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: Lenovo ThinkPad E595
driver: rtw_8822be v: N/A modules: rtw88_8822be port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:b822
IF-ID-1: br-65664a9372db state: down mac: <filter>
Bluetooth: Device-1: Realtek RTL8822BE Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8 bus-ID: 1-7:3
chip-ID: 0bda:b023 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
Drives: Local Storage: total: 238.47 GiB used: 31.87 GiB (13.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS256GD9TNG-62A0A size: 238.47 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 80001E00 temp: 38.9 C scheme: GPT
Partition: ID-1: / raw-size: 238.22 GiB size: 238.22 GiB (100.00%) used: 31.87 GiB (13.4%) fs: btrfs
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 546 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 238.22 GiB size: 238.22 GiB (100.00%) used: 31.87 GiB (13.4%) fs: btrfs
ID-4: /var/log raw-size: 238.22 GiB size: 238.22 GiB (100.00%) used: 31.87 GiB (13.4%)
ID-5: /var/tmp raw-size: 238.22 GiB size: 238.22 GiB (100.00%) used: 31.87 GiB (13.4%)
ID-1: swap-1 type: zram size: 7.56 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 38.0 C mobo: N/A
Info: Processes: 246 Uptime: 0m wakeups: 3 Memory: 7.56 GiB used: 1.42 GiB (18.7%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1267 lib: 296
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
The sound crackling i got in gernal when starting a game.
wth proton, then switch the input device some time then its fine.
Does this also happen with xanmod/tkg kerenl ?
I'm using the normal one and still have issues. My issue is mainly with the lack of audio through websites like YouTube but did also have kernel related errors like the following: https://askubuntu.com/questions/181239/virtualbox-error-message-rc-1908-after-kernel-upgrade
Would you recommend the RDB version? I'm not too familiar with what makes it different. I will however try your latest build and test virtualbox and audio so thanks for keeping tabs on the problem. Will try to reach you through Discord in future though like you said. Thanks
