I’ve searched everywhere, and I cannot seem to find anything about it on the forum, so hoping someone might have some insights. When I’m booted into the KDE Plasma Wayland session, the CTRL+Alt+F[n] keys which are supposed to switch you to a virtual console simply do not work. I have confirmed that when I log in to an X11 session, the keyboard combination works without any issue, with the GUI on F2. I can confirm that the keyboard shortcuts aren’t present in any other software, and the fact that it works in X11 indicates that maybe there’s something happening in Wayland that’s preventing this behavior? I can confirm that the key presses are registering in the system via xev
and wev
so it’s not that the system isn’t getting and recognizing the key combination.
Anyone else have this issue? Any advice? Here’s my garuda-inxi
> garuda-inxi
Kernel: 6.12.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=8dcc0c9c-8fe9-4fc6-b189-a8db2cfa3823 rw rootflags=subvol=@
rd.driver.pre=vfio-pci intel_iommu=on i915.enable_guc=3 i915.max_vfs=7
quiet resume=UUID=a14a443b-9c6b-47d0-b49a-d9686d767b7c loglevel=3
sysrq_always_enabled=1 ibt=off
wm: kwin_x11 tools: avail: hyprlock vt: 2 dm: SDDM Distro: Garuda
Mobo: ASUSTeK model: PRIME Z690-P WIFI v: Rev 1.xx
UEFI: American Megatrends v: 3601 date: 10/14/2024
Info: model: 12th Gen Intel Core i9-12900K bits: 64 type: MST AMCP
microcode: 0x37
Topology: cpus: 1x dies: 1 clusters: 10 cores: 16 threads: 24 mt: 8 tpc: 2
st: 8 smt: enabled cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32
KiB, 8x64 KiB L2: 14 MiB desc: 8x1.2 MiB, 2x2 MiB L3: 30 MiB
desc: 1x30 MiB
Speed (MHz): avg: 800 min/max: 800/5100:5200:3900 scaling:
driver: intel_pstate governor: performance cores: 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800
14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800
23: 800 24: 800 bogomips: 152985
Device-1: Intel AlderLake-S GT1 vendor: ASUSTeK driver: i915 v: kernel
alternate: xe arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
active: none empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:4680 class-ID: 0300
Device-2: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate]
vendor: ASUSTeK driver: nvidia v: 565.77 alternate: nouveau,nvidia_drm
non-free: 550.xx+ status: current (as of 2024-09; EOL~2026-12-xx)
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none off: DP-2,DP-4
empty: DP-3,HDMI-A-3,HDMI-A-4 bus-ID: 01:00.0 chip-ID: 10de:2489
Device-3: Realtek Integrated_Webcam_FHD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11.4:9
chip-ID: 0bda:58ba class-ID: 0e02 serial: <filter>
Device-4: Microsoft LifeCam Studio
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:3 chip-ID: 045e:0772
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
alternate: fbdev,intel,nv,vesa dri: iris gpu: nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 3840x1080 s-dpi: 82 s-size: 1189x331mm (46.81x13.03")
s-diag: 1234mm (48.59")
Monitor-1: DP-2 mapped: DP-1 note: disabled pos: left
model: Samsung SyncMaster serial: <filter> built: 2009 res: 1920x1080 hz: 60
dpi: 92 gamma: 1.2 size: 531x298mm (20.91x11.73") diag: 609mm (24")
Monitor-2: DP-4 note: disabled pos: primary,right model: Dell UZ2715H
serial: <filter> built: 2014 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
size: 597x336mm (23.5x13.23") diag: 676mm (26.6") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
drv: nvidia device: 1 drv: iris gbm: drv: iris surfaceless: drv: nvidia x11:
drv: nvidia inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: nvidia mesa v: 565.77
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.4.303 layers: 15 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Ti driver: N/A device-ID: 10de:2489 surfaces: xcb,xlib
device: 1 type: integrated-gpu name: Intel UHD Graphics 770 (ADL-S GT1)
driver: N/A device-ID: 8086:4680 surfaces: xcb,xlib device: 2 type: cpu
name: llvmpipe (LLVM 18.1.8 256 bits) driver: N/A device-ID: 10005:0000
surfaces: xcb,xlib
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: vfio-pci
alternate: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_tgl bus-ID: 00:1f.3
Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-3: Conexant Systems (Rockwell) DELL UZ2715H
lanes: 1 mode: 1.1 bus-ID: 1-11.2:7 chip-ID: 0572:141c class-ID: 0300
API: ALSA v: k6.12.4-zen1-1-zen status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 4000 bus-ID: 06:00.0
IF-ID-1: br-82d31aa0b51e state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: br-b787944b7593 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: br-c22acf9ff387 state: down mac: <filter>
IF-ID-4: br-e9c38ec2b98c state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-5: docker0 state: down mac: <filter>
IF-ID-6: veth4e9ef38 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-7: veth92a2947 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-8: vethc34842a state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-9: virbr0 state: down mac: <filter>
IF-ID-10: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-11: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:10 chip-ID: 8087:0026
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 6.37 TiB used: 2.79 TiB (43.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO with
Heatsink 2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7
temp: 35.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 32.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000NE001-2MA101
tech: HDD rpm: 7200 serial: <filter> fw-rev: EN01 scheme: GPT
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 606.97 GiB (33.2%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
used: 588 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
used: 606.97 GiB (33.2%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
ID-1: swap-1 type: zram size: 31.08 GiB used: 4.5 MiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 24
ID-2: swap-2 type: partition size: 34.2 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 31.2 C mobo: N/A gpu: nvidia temp: 35 C
Memory: total: 32 GiB note: est. available: 31.09 GiB used: 7.35 GiB (23.6%)
Processes: 596 Power: uptime: 57m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.38 GiB services: org_kde_powerdevil,
Packages: 2188 pm: pacman pkgs: 2172 libs: 611 tools: octopi,pacseek,paru
pm: flatpak pkgs: 16 Compilers: clang: 18.1.8 gcc: 14.2.1 alt: 13
Shell: garuda-inxi default: fish v: 3.7.1 running-in: kitty inxi: 3.3.36
System install date: 2024-10-16
Last full system update: 2024-12-17
Thanks in advance!
Edit: failed to mention that in xev
the key presses register properly as Control_L
Control_R
Alt_L
Alt_R
whereas with wev
it only registers Control
for either Ctrl key, and Mod1
for either Alt key. Wondering if that’s just a nomenclature difference or if, in fact, wayland’s not “seeing” Alt
- which could very well be the root of the issue lol. Also, the model keyboard I have selected is Generic | Generic 104-key PC
