How and from where to install this dongles drivers?
lsusb
lspci
Output of these
In text no pictures
Bus 002 Device 013: ID 2717:ff80 Xiaomi Inc. Mi/Redmi series (RNDIS)
Bus 002 Device 012: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 0000:0538 USB OPTICAL MOUSE
Bus 001 Device 005: ID 04ca:004b Lite-On Technology Corp. Keyboard
Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub**
lspci
00:00.0 Host bridge: Intel Corporation Core Processor DRAM Controller (rev 02)
00:02.0 VGA compatible controller: Intel Corporation Core Processor Integrated Graphics Controller (rev 02)
00:16.0 Communication controller: Intel Corporation 5 Series/3400 Series Chipset HECI Controller (rev 06)
00:16.2 IDE interface: Intel Corporation 5 Series/3400 Series Chipset PT IDER Controller (rev 06)
00:16.3 Serial controller: Intel Corporation 5 Series/3400 Series Chipset KT Controller (rev 06)
00:19.0 Ethernet controller: Intel Corporation 82578DC Gigabit Network Connection (rev 06)
00:1a.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host
Controller (rev 06)
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 06)
00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 06)
00:1c.4 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 5 (rev 06)
00:1d.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host
Controller (rev 06)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a6)
00:1f.0 ISA bridge: Intel Corporation H55 Chipset LPC Interface Controller (rev 06)
00:1f.2 IDE interface: Intel Corporation 5 Series/3400 Series Chipset 4 port SATA IDE Controller (rev
06)
00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 06)
3f:00.0 Host bridge: Intel Corporation Core Processor QuickPath Architecture Generic Non-core
Registers (rev 02)
3f:00.1 Host bridge: Intel Corporation Core Processor QuickPath Architecture System Address
Decoder (rev 02)
3f:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev 02)
3f:02.1 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor QPI Physical 0 (rev 02)
3f:02.2 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor Reserved (rev 02)
3f:02.3 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor Reserved (rev 02)
conf file in home directory and run both sh and patch files?
i ran the script and patch files and pasted conf file in home directory. doesnt work yet. the bluetooth support button isnt working in garuda assistant
I've handled plenty of help requests on that dongle on other distros. The general conclusion was most of those CSR dongles are legit and they usually don't have issues, but others that are sold are cheap Chinese knock offs that don't use the same chip.
I'm not saying that's the case here, but I've seen enough of these problems with that adapter that I don't waste my time trying to get it working anymore. If it is one of the cheap knock offs your not likely to get it working in Linux.
Is the installation method I mentioned correct?
I would expect these options woud be set in:
/etc/modprobe.d/csr-bluetoothdongle.conf
I have that same dongle if its genuine it will work out the box. make sure bluetooth is enabled sudo systemctl enable bluetooth sudo systemctl start bluetooth
Unfortunately their are lots of fakes.
Ok after copying that file bluetooth started working.
