Hey.
It won't let you log in to the app. "Wrong pin code", even though I am entering the correct code.
The error message is;
"(criptext:90535): Gtk-WARNING **: 10:26:11.719: Theme parsing error: gtk.css:8318:24: negative values are not allowed.
(electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false". It will change to be "true" in Electron 9. For more information please check [Discussion] Requiring Native Modules in the Renderer Process to be NAPI or Context Aware · Issue #18397 · electron/electron · GitHub
(electron) 'setResizable function' is deprecated and will be removed. Please use 'resizable property' instead."
Thanks in advance for your help!
