I've installed Garuda KDE Dr460nized in machine. I completely erased my hard drive while installing it with swap (with hibernate)
enabled. Is it possible to somehow create partitions after installation?
I want to keep my OS and installed softwares/packages in one separate partition and create two other partitions to store other stuff.
Please guide me about how can I do it without affecting the installed OS.
Yes, use gparted.
Thats not the Linux way, search in forum about.
You are very fine with directories, no need for partitions. That is not M$.
BTW, you forget to post your garuda-inxi.
