Crash on Login
On login to my user, I see the desktop with my mouse cursor, and after 2 seconds, it’s followed by a system crash.
Please provide the output of your garuda-inxi, as required in the topic template.
If you cannot boot, even just the garuda-inxi from a live USB would be a starting point.
If you use an Nvidia GPU in Hyprland (this is clear from the garuda-inxi), check this thread for the related hints.
If the problem started after an update, consider restoring the latest working sapshot.
Consider also that you could chroot from your live USB (with the relevant function in the live USB or this procedure and e.g. garuda-update from there.
Video demonstration: unnamed
    misobasedir=garuda root=miso:LABEL=GARUDA_HYPRLAND_RAPTOR quiet
    systemd.show_status=1 ibt=off driver=free nouveau.modeset=1
  Mobo: ASUSTeK model: TUF GAMING B550-PLUS WIFI II v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 3405
    date: 12/13/2023
  Info: model: AMD Ryzen 5 5500 bits: 64 type: MT MCP arch: Zen 3 gen: 4
    level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
    family: 0x19 (25) model-id: 0x50 (80) stepping: 0 microcode: 0xA50000F
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1249 high: 3798 min/max: 400/4506 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3798 2: 400 3: 400
    4: 400 5: 3796 6: 400 7: 400 8: 400 9: 3798 10: 400 11: 400 12: 400
    bogomips: 91205
  Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: ASRock
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-3
    empty: DP-1,DP-2,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:73ff
    compositor: Hyprland driver: X: loaded: amdgpu unloaded: modesetting,radeon
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 1
  Monitor-1: DP-3 model: Dell AW2521HFLA serial: <filter> built: 2021
    res: 1920x1080 hz: 60 dpi: 90 gamma: 1.2 scale: 1
    size: 544x303mm (21.42x11.93") diag: 623mm (24.5") ratio: 16:9 modes:
  API: Vulkan v: 1.3.269 layers: 3 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6600 XT (RADV NAVI23) driver: mesa radv v: 23.2.1-arch1.2
    device-ID: 1002:73ff surfaces: xcb,xlib,wayland device: 1 type: cpu
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
    link-max: gen: 4 speed: 16 GT/s bus-ID: 0a:00.1 chip-ID: 1002:1637
    link-max: gen: 4 speed: 16 GT/s bus-ID: 0a:00.6 chip-ID: 1022:15e3
  Device-4: HP [] driver: hid-generic,snd-usb-audio,usbhid type: USB
    rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:5 chip-ID: 03f0:0592
  Server-2: PipeWire v: 0.3.83 status: active with: 1: pipewire-pulse
  Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
    lanes: 1 bus-ID: 07:00.0 chip-ID: 14c3:7961 class-ID: 0280
  IF: wlp7s0 state: up mac: <filter>
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 08:00.0
  Device-1: IMC Networks [] driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 13d3:3563
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
  Local Storage: total: 2.31 TiB used: 0 KiB (0.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Patriot model: VPN110 512GB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 32A0T54B temp: 31.9 C
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2UB102
  ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: DataTraveler 3.0
    size: 28.82 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    scheme: MBR
  ID-1: swap-1 type: zram size: 31.14 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 57.4 C mobo: N/A gpu: amdgpu temp: 31.0 C
    mem: 30.0 C
  Processes: 292 Uptime: 3m wakeups: 0 Memory: total: 32 GiB note: est.
  available: 31.14 GiB used: 1.77 GiB (5.7%) Init: systemd v: 254
  pm: pacman pkgs: 1228 libs: 356 tools: paru Shell: fish v: 3.6.1
  running-in: foot inxi: 3.3.30
Garuda (2.6.17-1):
  System install date:     2024-02-05
  Last full system update: 2024-02-05 ↻
Hyprland does not support nvidea, but you can fix it, read the link.
I have AMD tho.
It looks like a recurring keymap issue.
Check e.g.
Or other threads in the Hyprland section.
You can change the hyprland.conf files from the live USB.
Seems I mixed some posts :smiley:
Yep.
I was using EndeavourOS for a while (The installer was the same, but using the same keyboard layout was functional, is it an issue with Garuda or Hyprland?)
I think I fix it, but it is not in your ISO
Please, maybe try this
https://iso.builds.garudalinux.org/iso/community/hyprland/240131/
I’ll try it out and let you know :3
Now after selecting garuda in the bootloader, I am redirected back to the bootloader to select it again, on second selection I am put into windows.
You use the live ISO or you have Hypr installed on metall??
We talk about the dark grub menu with the black/bluish background?
I ran the installer from your ISO (on a usb flashed) to a 120gb unallocated partition.
I have grub installed with the dark backgroud and a bit of blue colours here and there
This is the GRUB of your installed system, not the one of the live USB.
You should press a button (usually an Fx) repeatedly immediately after pushing the power button to select the USB for booking.
Or enter the BIOS and set the USB as first in the boot order.
You can recognize the live USB GRUB from the fact that it has two more options to boot using free drivers (use that) or proprietary drivers.
I installed it already from the live USB with the grub interface, after trying to boot from the UEFI, the error I talked about appeared.
Ok, the live ISO boot to Garuda login page, there you type the password garuda, you can login, install then via calamares Garuda on metall, then you remove the USB-Stick, on new boot you got the grub and click on Garuda Linux bring you back to this page again, after doing the same, click on Garuda Linux, but then start M$.
Thats new for me. :man_shrugging:
That’s exactly what happens
Can I ask which language you set in calamares (or for the live ISO)?
I think I saw not the Raptor on last ISO.
I selected American English (It was there 2 times for some reason)
