Hello so i have installed 3 types of garuda on to my pc and i can not figer out why but the cpu ramps all the way up to 90% and the my pc becomes unusable i found out that its waylad but i had tried to use chat gpt to help get some info and serched the web and came across several posible solitions but none worked like a fresh install bad config file and even tryed using some gommands to make sure that it was set up correctly.
PC build
rysen 7 2700x
nvidia 3070 rtx
32gb ram
2x 1tb hdd
1tb ssd m.2
secure boot off as well as fast boot
i tryed installing Mokka, Dr460nized Gaming, Garuda KDE Lite and so far they have all had the same issue but its fine up untill i reach the desktop as soon as the desktop opens then the cpu hits 90% and the pc becomes unusable i have seen a few threads o this but i am confused as they haven’t really answered my issue.
is there any thing i can do as id love to use this distro but if not and its juts a incompatibility id like to know so i can fined somthing that will work.
