CPU governor with catchyos-bore
I’m trying different kernels, while for many seems irrelevant in terms of performances I’m noticing my desktop being A LOT more responsive with catchy-bore compared to any other kernel I tried (zen, lts, vanilla).
The problem comes with games: looks like the frequency of the cpu fluctuate only between 2,2 and 2,4 mhz, as consequence FPS are very low in every game.
I usually switch governor based on need with cpupower, the problem is that since I installed catchy it seems to ignore any request to change governor.
I’d like to fix this problems and keep this kernel due to the general performances but I accept suggestions on how to get more performances from other kernels.
With catchy the desktop feels as smooth as wayland, which I can’t use because… nvidia.
Below the inxi:
  Kernel: 6.8.9-4-cachyos-bore arch: x86_64 bits: 64 compiler: gcc v: 14.1.1 clocksource: tsc
    avail: hpet,acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-cachyos-bore
    root=UUID=523d6c7d-5e6f-44ac-9ba0-afa9b2784c01 rw rootflags=subvol=@ quiet
    resume=UUID=247575db-f46c-49a4-9a52-a328b9d1d079 loglevel=3 ibt=off
  Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.1.0 wm: kwin_x11 vt: 2
  Type: Desktop Mobo: Micro-Star model: X570-A PRO (MS-7C37) v: 3.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: H.I0 date: 08/10/2022
  Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3 level: v3 note: check
    built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x71 (113) stepping: 0
    microcode: 0x8701021
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB
    desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 2200 high: 2203 min/max: 2200/4426 boost: enabled scaling:
    driver: acpi-cpufreq governor: powersave cores: 1: 2200 2: 2200 3: 2200 4: 2200 5: 2200 6: 2200
    7: 2200 8: 2200 9: 2200 10: 2203 11: 2199 12: 2200 13: 2200 14: 2200 15: 2200 16: 2200
    bogomips: 115203
  Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: Micro-Star MSI driver: nvidia
    v: 550.78 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of 2024-04;
    EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: none off: DP-2,DP-3 empty: DP-1,HDMI-A-1
    bus-ID: 2d:00.0 chip-ID: 10de:2216 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 4480x1440 s-dpi: 92 s-size: 1237x402mm (48.70x15.83")
    s-diag: 1301mm (51.21")
  Monitor-1: not-matched mapped: DP-3 pos: bottom-r res: 1920x1080 hz: 60 dpi: 92
  Monitor-2: not-matched mapped: DP-4 pos: primary,top-left res: 2560x1440 hz: 165 dpi: 109
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2 drv: swrast gbm:
    drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78 glx-v: 1.4 direct-render: yes
    renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2 memory: 9.77 GiB
  API: Vulkan v: 1.3.279 layers: 8 device: 0 type: discrete-gpu name: NVIDIA GeForce RTX 3080
    driver: nvidia v: 550.78 device-ID: 10de:2216 surfaces: xcb,xlib
  Device-1: NVIDIA GA102 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.1 chip-ID: 10de:1aef class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI X570-A PRO driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Kingston HyperX 7.1 Audio driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0951:16a4 class-ID: 0300
  Device-4: Fifine Microphone driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:3 chip-ID: 3142:5060 class-ID: 0300
  API: ALSA v: k6.8.9-4-cachyos-bore status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse status: active
  Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit E
thernet vendor: Micro-Star MSI
    X570-A PRO driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
    bus-ID: 27:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-4:2 chip-ID: 0a12:0001 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.0 lmp-v: 6 status:
  Local Storage: total: 4.1 TiB used: 433.14 GiB (10.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010T8 size: 953.87 GiB
    fw-rev: 002C temp: 41.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Kingston model: SA2000M81000G size: 931.51 GiB
    fw-rev: S5Z42105 temp: 49.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-22BN5A0 size: 931.51 GiB
    fw-rev: 1A01 scheme: MBR
  ID-4: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SDSSDXPS480G size: 447.13 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 00RL
  ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD10EZEX-00BN5A0 size: 931.51 GiB
    fw-rev: 1A01 scheme: GPT
  ID-1: / raw-size: 896.83 GiB size: 896.83 GiB (100.00%) used: 146.04 GiB (16.3%) fs: btrfs
    dev: /dev/nvme1n1p2 maj-min: 259:8
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 584 KiB (0.2%) fs: vfat
    dev: /dev/nvme1n1p1 maj-min: 259:7
  ID-3: /home raw-size: 896.83 GiB size: 896.83 GiB (100.00%) used: 146.04 GiB (16.3%) fs: btrfs
  ID-4: /var/log raw-size: 896.83 GiB size: 896.83 GiB (100.00%) used: 146.04 GiB (16.3%)
    fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:8
  ID-5: /var/tmp raw-size: 896.83 GiB size: 896.83 GiB (100.00%) used: 146.04 GiB (16.3%)
  ID-1: swap-1 type: partition size: 34.39 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme1n1p3 maj-min: 259:9
  ID-2: swap-2 type: zram size: 31.26 GiB used: 755.2 MiB (2.4%) priority: 100 comp: zstd
    avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 16 dev: /dev/zram0
  System Temperatures: cpu: 52.4 C mobo: N/A gpu: nvidia temp: 53 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 32%
  Memory: total: 32 GiB available: 31.26 GiB used: 5.47 GiB (17.5%)
  Processes: 436 Power: uptime: 57m states: freeze,mem,disk suspend: deep avail: s2idle
    wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.46 GiB
    services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 255
  Packages: pm: pacman pkgs: 1530 libs: 422 tools: octopi,paru Compilers: clang: 17.0.6
    gcc: 14.1.1 Client: shell wrapper v: 5.2.26-release inxi: 3.3.34
  System install date:     2024-05-03
  Last full system update: 2024-05-10
Ask the developer :slight_smile:
I just lost the emojis, but cachyos is definitely recommended. In my opinion.
What I really value is freedom of choice. And, of course, the exchange with each other. Thanks for that.
Well, I’ll update this in case someone has the same problem:
Looks like catchy with bore doesn’t do good with cpupower and similar software, removing cpupower fixed the problem, bore doesn’t really need any other “help” in managing the cpu.
