Corsair Commander Pro broken after updating today
After I updated my system today my corsair commander pro no longer shows up at all. Without it, my fans are not ramping up while gaming causing my internal case temperatures to rise quite a bit. Anybody know how to fix this? I tried doing a sensors-detect but that doesnt seem to have done anything for me.
Also, if theres already been a post made about this I apologize. I tried to search on here for something similar but returned no results.
Try the last working snapshot and then check which applications could cause the problem when updating...
Please note: This forum is not a general technical support forum.
There is no Corsair forum?
And why don't you post the garuda-inxi?
Kernel: 6.4.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=b57ccd9d-2722-4636-bfb8-ebddbe2ad009 rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Desktop Mobo: Micro-Star model: B450 GAMING PRO CARBON MAX WIFI
(MS-7B85) v: 1.0 serial: <superuser required> UEFI: American Megatrends
LLC. v: 2.90 date: 03/23/2022
Info: model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4399 high: 4403 min/max: 2200/5143 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4403 2: 4400
3: 4400 4: 4400 5: 4400 6: 4396 7: 4400 8: 4400 9: 4400 10: 4400 11: 4400
12: 4400 13: 4400 14: 4400 15: 4400 16: 4398 bogomips: 140808
active: DP-3,HDMI-A-1 empty: DP-1,DP-2 bus-ID: 28:00.0 chip-ID: 1002:73df
s-diag: 1245mm (49.01")
Monitor-1: DP-3 mapped: DisplayPort-2 pos: primary,left
model: Gigabyte G27Q serial: <filter> built: 2021 res: 2560x1440 dpi: 109
gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 685mm (27") ratio: 16:9
modes: max: 2560x1440 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model: Samsung S27C230
serial: <filter> built: 2014 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: AMD Radeon RX 6700 XT (navi22
LLVM 15.0.7 DRM 3.52 6.4.1-zen1-1-zen) direct-render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 28:00.1 chip-ID: 1002:ab28
bus-ID: 2a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: SteelSeries ApS Arctis 7
lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 1038:12ad class-ID: 0300
API: ALSA v: k6.4.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.72 status: active with: 1: pipewire-pulse
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 21:00.0 chip-ID: 8086:2526 class-ID: 0280
Device-2: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 22:00.0
IF: enp34s0 state: down mac: <filter>
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:4
address: <filter>
Local Storage: total: 2.73 TiB used: 522.47 GiB (18.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 1B4QFXO7 temp: 33.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM001-1ER164
tech: HDD rpm: 7200 serial: <filter> fw-rev: HP51 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: PNY model: CS900 500GB SSD
tech: SSD serial: <filter> fw-rev: 06B5 scheme: GPT
used: 162.46 GiB (34.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 33.0 C mobo: 32.0 C gpu: amdgpu temp: 38.0 C
mem: 36.0 C
Fan Speeds (RPM): fan-1: 2419 fan-2: 0 fan-3: 0 fan-4: 0 fan-5: 0 fan-6: 0
gpu: amdgpu fan: 482
Processes: 351 Uptime: 44m wakeups: 0 Memory: available: 15.54 GiB
used: 2.82 GiB (18.1%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 2005
pm: pacman pkgs: 1999 libs: 564 tools: octopi,paru pm: flatpak pkgs: 6
inxi: 3.3.27
System install date:     2022-11-15
Last full system update: 2023-07-03
Failed units:            fancontrol.service
reverting back to snapshot has fixed it. I guess i'll wait a week before attempting to update again.
Is it active? Try
systemctl status fancontrol.service
fancontrol.service - Start fan control, if configured
Loaded: loaded (/usr/lib/systemd/system/fancontrol.service; enabled; preset: disabled)
Active: failed (Result: exit-code) since Mon 2023-07-03 12:36:33 CDT; 23min ago
I dont use fancontrol anyways. I have been using Coolero.
Maybe you shouldn’t
[🔴] × paru -Ss coolero
aur/coolero 0.13.3-2 [+4 ~0.00] [Out-of-date: 2023-04-22]
A program to monitor and control your cooling devices
The thing’s marked out of date.
it still works fine for me and does what I need it to do lol
Also, he's still actively working on coolero on github.
