Coredump for systemsettings5 and (nearly) all USB devices fail
I have an issue where I'm getting core dumps from "systemsettings5" periodically. When it happens all USB devices (except for my keyboard for some reason) fail and stop working. It seems to maybe happen when I have two apps playing audio at the same time (but by no means is it ANY time two apps are playing audio at the same time does this happen). A reboot seems to be required to reinitialize the USB devices.
Any idea what's going on here?
journalctl export just after the core dump, before I rebooted.
https://bin.garudalinux.org/?0312544d498d6efd#DrJJNiW8b2skhPiojSXJHZSE8u3rLd4rf9nW3zSXZzEt
inxi -Fzxxxa
System:    Kernel: 5.10.10-115-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.1
           root=UUID=eb6b0c6e-7658-4f94-86d5-9cb39b744755 rw [email protected] quiet splash
           Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM
           Distro: Garuda Linux
Machine:   Type: Desktop System: Gigabyte product: AB350M-D3H v: N/A serial: <filter>
           Mobo: Gigabyte model: AB350M-D3H-CF v: x.x serial: <filter> UEFI: American Megatrends
           v: F2 date: 04/07/2017
CPU:       Info: Quad Core model: AMD Ryzen 5 1400 bits: 64 type: MT MCP arch: Zen
           family: 17 (23) model-id: 1 stepping: 1 microcode: 800111C L2 cache: 2 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 51145
           Speed: 2992 MHz min/max: 1550/3200 MHz boost: disabled Core speeds (MHz): 1: 2992
           2: 3146 3: 3041 4: 3038 5: 3029 6: 3174 7: 3184 8: 3186
           Type: spectre_v2 mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Graphics:  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
           vendor: Micro-Star MSI driver: amdgpu v: kernel bus ID: 09:00.0 chip ID: 1002:67df
           Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: amdgpu,ati
           unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
           Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.8x15.0")
           s-diag: 987mm (38.8")
           Monitor-1: DisplayPort-2 res: 3440x1440 hz: 144 dpi: 109 size: 800x335mm (31.5x13.2")
           diag: 867mm (34.1")
           OpenGL:
           renderer: Radeon RX 570 Series (POLARIS10 DRM 3.40.0 5.10.10-115-tkg-bmq LLVM 11.0.1)
           v: 4.6 Mesa 20.3.3 direct render: Yes
Audio:     Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
           vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 09:00.1
           chip ID: 1002:aaf0
           Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
           bus ID: 12:00.3 chip ID: 1022:1457
           Device-3: Blue Microphones Yeti Stereo Microphone type: USB
           driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-3:2 chip ID: b58e:9e84
           Device-4: Kingston HyperX Cloud Flight S type: USB
           driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-2:2 chip ID: 0951:16ea
           Sound Server: ALSA v: k5.10.10-115-tkg-bmq
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte
           driver: r8169 v: kernel modules: r8168 port: f000 bus ID: 05:00.0 chip ID: 10ec:8168
           Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: f000 bus ID: 08:00.0
           chip ID: 8086:2723
Drives:    Local Storage: total: 689.33 GiB used: 38.51 GiB (5.6%)
           ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST240HM000-1G5152 size: 223.57 GiB
           block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
           rev: C675
           ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 500GB
           size: 465.76 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
           serial: <filter> rev: 3B6Q
Partition: ID-1: / raw size: 232.57 GiB size: 232.57 GiB (100.00%) used: 38.31 GiB (16.5%)
           fs: btrfs dev: /dev/sdb5 maj-min: 8:21
           ID-2: /boot/efi raw size: 498 MiB size: 497 MiB (99.80%) used: 201.6 MiB (40.6%)
           fs: vfat dev: /dev/sda1 maj-min: 8:1
           ID-3: /home raw size: 232.57 GiB size: 232.57 GiB (100.00%) used: 38.31 GiB (16.5%)
           ID-4: /var/log raw size: 232.57 GiB size: 232.57 GiB (100.00%)
           used: 38.31 GiB (16.5%) fs: btrfs dev: /dev/sdb5 maj-min: 8:21
           ID-5: /var/tmp raw size: 232.57 GiB size: 232.57 GiB (100.00%)
Swap:      Kernel: swappiness: 10 (default 60) cache pressure: 75 (default 100)
           ID-1: swap-1 type: zram size: 1.96 GiB used: 512 KiB (0.0%) priority: 32767
           ID-2: swap-2 type: zram size: 1.96 GiB used: 512 KiB (0.0%) priority: 32767
           dev: /dev/zram1
           ID-3: swap-3 type: zram size: 1.96 GiB used: 512 KiB (0.0%) priority: 32767
           dev: /dev/zram2
           ID-4: swap-4 type: zram size: 1.96 GiB used: 512 KiB (0.0%) priority: 32767
           dev: /dev/zram3
           ID-5: swap-5 type: zram size: 1.96 GiB used: 512 KiB (0.0%) priority: 32767
           dev: /dev/zram4
           ID-6: swap-6 type: zram size: 1.96 GiB used: 512 KiB (0.0%) priority: 32767
           dev: /dev/zram5
           ID-7: swap-7 type: zram size: 1.96 GiB used: 512 KiB (0.0%) priority: 32767
           dev: /dev/zram6
           ID-8: swap-8 type: zram size: 1.96 GiB used: 512 KiB (0.0%) priority: 32767
           dev: /dev/zram7
           ID-9: swap-9 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: 1024
           dev: /dev/sda4 maj-min: 8:4
Sensors:   System Temperatures: cpu: 73.1 C mobo: N/A gpu: amdgpu temp: 62.0 C
           Fan Speeds (RPM): N/A gpu: amdgpu fan: 1129
Info:      Processes: 339 Uptime: 15m wakeups: 0 Memory: 15.64 GiB used: 7.45 GiB (47.6%)
           Init: systemd v: 247 Compilers: gcc: 10.2.0 clang: 11.0.1 Packages: pacman: 1742
           lib: 535 Shell: fish v: 3.1.2 running in: alacritty inxi: 3.2.02
https://forums.linuxmint.com/viewtopic.php?t=273823
Bad Gigabyte mobo, second post today about these duds. Third one in the last week seems like everybody's got one (me too).
I've gone and updated my bios to the current version seeing as there were a bunch of usb fixes listed in the changelogs for the updates. No dice as it immediately had the problem when I logged in again, so that did not fix it. My keyboard even stopped working this time
suppose it could be the Mobo, would be shame really as I've gotten my setup just how I like it here.
Gonna edit the Grub params as suggested in the link and see if that solves the issue.
Try the provided advice.
Jan 29 12:22:29 kernel: irq 7: nobody cared (try booting with the "irqpoll" option)
Jan 29 14:26:42 kernel: irq 9: nobody cared (try booting with the "irqpoll" option)
Info
