only 1.1.1-2 version is working and other versions dont open at all. even this version cant control the cpu and doesnt minimize to tray.(using gnome and RX470)
Not sure if you tried already, but launching an app via command line is a good way to find out whats happening as it will most likely generate logs and status reports which you could then post here.
1.2.00 update works. But again I can't see it in system tray.
