CoreCtrl (missing options)
i tried using core control and its very limited, i looked it up and Ive seen videos on youtube with a multitude of options for voltages and and other things i don't have access to. should i edit grub and set the featuremask or is there a better way..i don't want to mess with grubs config if i don't have to.
inxi -Faz
System:    Kernel: 5.15.6-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=453092bf-16eb-4fa2-9643-a0e413678109
rw [email protected] quiet
cryptdevice=UUID=42bc0ad4-90a9-4f07-8a4c-78f17bd64474:luks-42bc0ad4-90a9-4f07-8a4c-78f17bd64474
root=/dev/mapper/luks-42bc0ad4-90a9-4f07-8a4c-78f17bd64474 splash rd.udev.log_priority=3
vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1
resume=/dev/mapper/luks-bd92b9d8-d6a0-4438-9c6e-a327dabdb6fc loglevel=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine:   Type: Laptop System: HP product: HP Pavilion Laptop 15-eh0xxx v: N/A
Mobo: HP model: 87C5 v: 35.24 serial: <superuser required> UEFI: AMI v: F.12 date: 03/04/2021
Battery:   ID-1: BAT0 charge: 27.4 Wh (75.1%) condition: 36.5/36.5 Wh (100.0%) volts: 11.8 min: 11.3
model: Hewlett-Packard Primary type: Li-ion serial: N/A status: Discharging cycles: 328
CPU:       Info: 6-Core model: AMD Ryzen 5 4500U with Radeon Graphics bits: 64 type: MCP arch: Zen 2
family: 17 (23) model-id: 60 (96) stepping: 1 microcode: 8600106 cache: L1: 384 KiB L2: 3 MiB
L3: 8 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 28445
Speed: 1857 MHz min/max: 1400/2375 MHz boost: enabled Core speeds (MHz): 1: 2057 2: 1491
3: 1533 4: 1520 5: 1807 6: 2077
mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics:  Device-1: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 04:00.0
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: amdgpu,ati
Monitor-1: eDP res: 1920x1080 dpi: 142 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.15.6-zen2-1-zen LLVM 13.0.0) v: 4.6 Mesa 21.2.5
direct render: Yes
Audio:     Device-1: AMD vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 04:00.1
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Hewlett-Packard
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x,snd_pci_acp5x bus-ID: 04:00.5
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.15.6-zen2-1-zen running: yes
Network:   Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 02:00.0 chip-ID: 8086:2723
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:3 chip-ID: 8087:0029
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: N/A
Drives:    Local Storage: total: 476.94 GiB used: 300.51 GiB (63.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ512HALU-000H1 size: 476.94 GiB
rev: HPS4NFXV temp: 30.9 C scheme: GPT
Partition: ID-1: / raw-size: 467.84 GiB size: 467.84 GiB (100.00%) used: 300.51 GiB (64.2%) fs: btrfs
dev: /dev/dm-0 maj-min: 254:0 mapped: luks-42bc0ad4-90a9-4f07-8a4c-78f17bd64474
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 720 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 467.84 GiB size: 467.84 GiB (100.00%) used: 300.51 GiB (64.2%) fs: btrfs
ID-4: /var/log raw-size: 467.84 GiB size: 467.84 GiB (100.00%) used: 300.51 GiB (64.2%)
fs: btrfs dev: /dev/dm-0 maj-min: 254:0 mapped: luks-42bc0ad4-90a9-4f07-8a4c-78f17bd64474
ID-5: /var/tmp raw-size: 467.84 GiB size: 467.84 GiB (100.00%) used: 300.51 GiB (64.2%)
ID-1: swap-1 type: zram size: 7.19 GiB used: 3.5 MiB (0.0%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1
maj-min: 254:1 mapped: luks-bd92b9d8-d6a0-4438-9c6e-a327dabdb6fc
Sensors:   System Temperatures: cpu: 44.0 C mobo: N/A gpu: amdgpu temp: 44.0 C
Info:      Processes: 268 Uptime: 2h 23m wakeups: 4440 Memory: 7.2 GiB used: 3.2 GiB (44.4%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1744 lib: 514
Shell: fish v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.09
i thought that looked a bit off, i incidentally didn't capitalize the "F" ins -Faz i posted this info in the apropriate section, how do i link to it the proper way?
Please, post full inxi -Faz :slight_smile:
Now that's a Zinger!
Most laptops are un overclockable, voltages/fan control/etc are on really HIGH end laptops and on desktops.
ryzen laptops ARE overclockable..apparently you didn't do the research
even my 2012 llano laptop was overclockable and that was supported officially with amd catalyst windows software
You have to do this otherwise clock control isn't available. This is the second thread with this issue. Please don't open multiple threads about the same issue. I have closed the other thread, but I'll re-post the answer I gave there:
