i am trying to use my controller to play multiversus but it doesnt work because the joystick is recognise as a mouse and it seem that every game that i play with proton has this issue
Kernel: 5.18.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=859b76f8-6f2a-49d6-a2ba-c39197e1548f rw [email protected]
Desktop: KDE Plasma v: 5.25.3 tk: Qt v: 5.15.5 info: latte-dock
Mobo: ASUSTeK model: PRIME H410M-A v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1402
date: 10/27/2020
Device-1: ps-controller-battery-d0:bc:c1:dc:d5:df model: N/A serial: N/A
charge: N/A status: discharging
Info: model: Intel Core i3-10100 bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 built: 2020 process: Intel 14nm family: 6 model-id: 0xA5 (165)
stepping: 3 microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 4100 min/max: 800/4300 scaling: driver: intel_cpufreq
governor: performance cores: 1: 4100 2: 4100 3: 4100 4: 4100 5: 4100
6: 4100 7: 4100 8: 4100 bogomips: 57600
Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: ZOTAC
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:21c4 class-ID: 0300
Screen-1: 0 s-res: 3840x1080 s-dpi: 93 s-size: 1049x292mm (41.30x11.50")
s-diag: 1089mm (42.87")
Monitor-1: DP-4 pos: primary,left res: 1920x1080 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
Monitor-2: HDMI-0 pos: right res: 1920x1080 hz: 60 dpi: 94
OpenGL: renderer: NVIDIA GeForce GTX 1660 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 515.57 direct render: Yes
Device-1: Intel Comet Lake PCH-V cAVS vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:a3f0 class-ID: 0403
Device-2: NVIDIA TU116 High Definition Audio vendor: ZOTAC
Sound Server-1: ALSA v: k5.18.12-zen1-1-zen running: yes
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168
Device-2: NetGear A6150 type: USB driver: rtl88x2bu bus-ID: 1-3:2
chip-ID: 0846:9055 class-ID: 0000 serial: <filter>
IF: wlp0s20f0u3 state: up mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-4:3 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 2.75 TiB used: 385.59 GiB (13.7%)
rev: 2B2QEXM7 temp: 48.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Intenso model: N/A size: 953.87 GiB
serial: <filter> rev: 0A0 scheme: GPT
ID-1: / raw-size: 1.39 TiB size: 1.39 TiB (100.00%)
used: 385.57 GiB (27.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 25.9 MiB (8.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.39 TiB size: 1.39 TiB (100.00%)
ID-4: /var/log raw-size: 1.39 TiB size: 1.39 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.39 TiB size: 1.39 TiB (100.00%)
ID-1: swap-1 type: zram size: 15.53 GiB used: 1.66 GiB (10.7%)
System Temperatures: cpu: 52.0 C mobo: N/A gpu: nvidia temp: 57 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 28%
Processes: 313 Uptime: 2h 34m wakeups: 2 Memory: 15.53 GiB
used: 6.95 GiB (44.7%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: 1966
note: see --pkg apt: 1 pacman: 1965 lib: 543 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.19
Garuda (2.6.5-1):
System install date: 2022-06-16
Last full system update: 2022-07-25 ↻
