Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=afaf3797-0958-4967-8df8-3f0b6c631970 rw [email protected]
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 info: latte-dock
Type: Desktop System: Gigabyte product: B550M H v: N/A
serial:
Mobo: Gigabyte model: B550M H v: x.x serial:
UEFI: American Megatrends v: F3 date: 08/20/2020
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial:
Info: model: AMD Ryzen 5 3600XT bits: 64 type: MT MCP arch: Zen 2
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3573 high: 3738 min/max: 2200/4635 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3738 2: 3592
3: 3598 4: 3593 5: 3582 6: 3244 7: 3594 8: 3589 9: 3592 10: 3593 11: 3588
12: 3584 bogomips: 91035
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
vendor: ASUSTeK driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-2,HDMI-A-1 empty: DP-1,DP-3 bus-ID: 0b:00.0
chip-ID: 1002:731f class-ID: 0300
Device-2: Microdia Dual Mode Camera (8006 VGA) type: USB
driver: hid-generic,usbhid bus-ID: 3-4:2 chip-ID: 0c45:8006 class-ID: 0301
s-diag: 1055mm (41.54")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,right model: XZ4010
serial: built: 2020 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left model: HDMI
max: 1920x1080 min: 640x350
OpenGL: renderer: AMD Radeon RX 5600 XT (navi10 LLVM 13.0.1 DRM 3.44
5.17.5-zen1-1-zen)
v: 4.6 Mesa 22.0.2 direct render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab38
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
lanes: 1 port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp8s0 state: up speed: 100 Mbps duplex: full mac:
Local Storage: total: 3.57 TiB used: 67.29 GiB (1.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8500G
speed: 31.6 Gb/s lanes: 4 type: SSD serial: rev: S5Z42105
temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3500413AS
type: HDD rpm: 7200 serial: rev: JC45 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S371920G
size: 1.75 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: rev: 0101 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM010-2EP102
speed: 1.5 Gb/s type: HDD rpm: 7200 serial: rev: CC43
used: 31.82 GiB (6.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.61 GiB used: 1.8 MiB (0.0%)
System Temperatures: cpu: 16.8 C mobo: N/A gpu: amdgpu temp: 60.0 C
mem: 62.0 C
Processes: 376 Uptime: 19m wakeups: 2 Memory: 15.61 GiB
used: 3.97 GiB (25.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1410 lib: 341 Shell: Bash v: 5.1.16
running-in: tilix inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-05-05
Last full system update: 2022-05-05 ↻
Hello, good day to everyone.
I have a problem with my gamepad balambrush, I connect it and it doesn't stop blinking, it appears to be connected but it doesn't react, I tried to install xbox--generic-controller and xboxdrv, but it still doesn't work, any ideas?, I've been wanting to use the control all day, I already used it on a windows laptop and it works very well, everything works except the gamepad, thank you very much.
Please, edit your post.
