Hello guys,
For me no context menus or dropdown menus work. In Garuda Assistant I can't use the dropdown menu. In Dolphin I can't open the right click menu anymore and in any other applications too. Anyone knows why this happens (using Sway on Garuda)
Please reboot your machine, then check again. Post the output of garuda-inxi
into the thread if you need additional assistance.
Hello fellow Sway user.
Here I don't have this problem, now I'll update/reboot and report back.
You should provide more context, like since when this happens. And post the garuda-inxi
edit: updated/rebooted and still no problem.
Hi, I rebooted and it still remains like that
edit: I dont know when exactly it happened
Second edit: Everything works fine on hyprland and KDE Plasma, seems to only occur when being on sway
root=UUID=a8f197c1-8de4-42bc-90d0-52e8457a9b26 rw rootflags=subvol=@
Desktop: sway v: 1.7 info: waybar vt: 2 dm: SDDM Distro: Garuda Linux
Type: Desktop System: Gigabyte product: B450 AORUS PRO v: N/A
Mobo: Gigabyte model: B450 AORUS PRO-CF serial: <superuser required>
UEFI: American Megatrends LLC. v: F62d date: 10/13/2021
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3598 high: 3600 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3595 2: 3586
3: 3600 4: 3600 5: 3600 6: 3600 7: 3600 8: 3600 9: 3600 10: 3600 11: 3600
12: 3600 bogomips: 86236
protection
vendor: Sapphire Nitro+ driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: DP-1,HDMI-A-1
empty: DP-2,DVI-D-1,HDMI-A-2 bus-ID: 0b:00.0 chip-ID: 1002:67df
class-ID: 0300 temp: 49.0 C
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.4
compositor: sway v: 1.7 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 3840x1080
display-ID: 1
Monitor-1: DP-1 pos: right model: VG259QM serial: <filter> built: 2021
res: 1920x1080 hz: 240 dpi: 90 gamma: 1.2 scale: 1
size: 544x303mm (21.42x11.93") diag: 623mm (24.5") ratio: 16:9 modes:
Monitor-2: HDMI-A-1 pos: left model: Samsung S22C300 serial: <filter>
built: 2013 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2 scale: 1
OpenGL: renderer: AMD Radeon RX 580 Series (polaris10 LLVM 14.0.6 DRM
3.48 6.0.2-zen1-1-zen) v: 4.6 Mesa 22.2.1 direct render: Yes
vendor: Sapphire driver: snd_hda_intel v: kernel bus-ID: 3-2:2
chip-ID: 0951:16a4 pcie: class-ID: 0300 gen: 1 speed: 2.5 GT/s
serial: <filter> lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 0b:00.1
chip-ID: 1002:aaf0 class-ID: 0403
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Kingston HyperX 7.1 Audio type: USB
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 08:00.0
Device-1: TP-Link UB500 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-2:2 chip-ID: 2357:0604 class-ID: e001 serial: <filter>
Local Storage: total: 2.27 TiB used: 51.76 GiB (2.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B4QFXO7
temp: 43.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 033 scheme: GPT
model: WD5000AAKX-001CA0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: 1H15
scheme: MBR
ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 51.76 GiB
(5.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 612 KiB
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 51.76
GiB (5.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 51.76
ID-5: /var/tmp raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 51.76
ID-1: swap-1 type: zram size: 15.55 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: 52.5 C mobo: N/A gpu: amdgpu temp: 50.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1686
Processes: 324 Uptime: 1m wakeups: 0 Memory: 15.55 GiB used: 1.68 GiB
(10.8%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1454 libs: 398
tools: octopi,paru,yay Shell: Bash v: 5.1.16 running-in: foot inxi: 3.3.22
Garuda (2.6.8-1):
System install date: 2022-10-14
Last full system update: 2022-10-22
I have no idea if it means anything, but I noticed I have a different output (server
Display: wayland server: Xwayland v: 22.1.4 compositor: sway v: 1.7
driver: gpu: radeon d-rect: 1366x1536 display-ID: 1
Try making a new user and see if it happens there with the default configuration.
Installing multiple desktop environments can easily break things, especially with Sway. Sway does not have much flexibility with environment variables, for example. Things have to be set up in a very specific way to work correctly.
I agree with @meanruse, this does not look right–the Xorg server should not be running in a Sway session.
Tried new user with new home directory, works fine
Well I guess I fixed it. Had X11 Plasma first and then went trying out different WMs. I wiped it off and install Garuda Sway directly but it seems to be a lot different. Got greeted with "Welcome to swayr!..." what exactly is Swayr?
I have never heard of it before, to be honest.
If you like Sway, you should pull down a proper ISO from the download page and give the actual Garuda Sway spin a try. It is the best “out-of-the-box” Sway spin I have ever tried–actually it’s what got me hooked on Garuda in the first place.
Instead of stacking DEs on top of one another, consider making a separate partition so you can leave the install alone, and build stuff up without breaking other DEs. You can always set up a symlink for your home folder so you can get to all your stuff no matter what session you are booted into.
Yes thats what I did I prob didnt explain it really good above. I got the actual garuda sway spin now, but got greeted with a message on the top saying "welcome to swayr! I generated a config...." but I never heard of it, also my whole monitor seems to be yellow guess I gotta go trough some settings
It must be a new package they have added to the spin. It looks like it is in the Chaotic AUR:
chaotic-aur/swayr 0.22.0-1 [1.42MiB 3.86MiB]
Swayr is a window switcher (and more) for sway
It looks interesting, and complicated. Reading through the documentation made me a little dizzy.
I'm kind of tempted to try it out, although at this point I am very used to my Sway keybindings and I'm not sure I want to get lost down a whole new rabbit hole.
There is automatic adjustment of colors by time of day, it should be wlsunset
if it didn’t change.
You should find it in your ~/.config/sway/config.d/autostart_applications
configuration file, something like exec ~/.config/sway/scripts/light.sh
I looked into swayr
time ago but then did not find a chance to try it out.
I quote “looks interesting, and complicated”.
Oh okay, thank you. I guess imma also remove swayr since I have no idea what it is, also gotta put my keybinds to sways default. Guess the issue is solved thank you guys!
