Conky on Hyprland
Hy.
I just moving from garuda KDE to hyprland. There is any way to run conky like on kde and not in a tilling window?
thanks
inxi:
  Kernel: 6.7.0-zen3-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=095c9f1d-4e23-42b2-aa42-36402880711e rw rootflags=subvol=@
    quiet resume=UUID=4b8a0d61-7df0-445b-9329-0c5cf2f2c346 loglevel=3 ibt=off
  Type: Laptop System: Dell product: Vostro 3580 v: N/A
  Mobo: Dell model: 0PMTCG v: A00 serial: <superuser required> UEFI: Dell
    v: 1.27.0 date: 11/16/2023
  ID-1: BAT0 charge: 24.6 Wh (84.0%) condition: 29.3/42.0 Wh (69.8%)
    volts: 11.9 min: 11.4 model: BYD DELL 1VX1H97 type: Li-ion serial: <filter>
  Info: model: Intel Core i5-8265U bits: 64 type: MT MCP
    arch: Comet/Whiskey Lake note: check gen: core 8 level: v3 note: check
    stepping: 0xC (12) microcode: 0xF8
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 625 high: 700 min/max: 400/3900 scaling:
    driver: intel_pstate governor: powersave cores: 1: 700 2: 700 3: 700 4: 700
    5: 400 6: 700 7: 700 8: 400 bogomips: 28800
  Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Dell
    ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 0000:00:02.0
    chip-ID: 8086:3ea0 class-ID: 0300
  Device-2: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2
    chip-ID: 1bcf:2b98 class-ID: 0e02
    compositor: Hyprland driver: X: loaded: modesetting
    alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: 1
  Monitor-1: eDP-1 model: AU Optronics 0x38ed built: 2015 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 scale: 1 size: 344x193mm (13.54x7.6")
  API: Vulkan v: 1.3.274 layers: 3 device: 0 type: integrated-gpu name: Intel
    UHD Graphics 620 (WHL GT2) driver: mesa intel v: 23.3.3-arch1.1
    device-ID: 8086:3ea0 surfaces: xcb,xlib,wayland device: 1 type: cpu
    v: 23.3.3-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
  Device-1: Intel Cannon Point-LP High Definition Audio vendor: Dell
    bus-ID: 0000:00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
  API: ALSA v: k6.7.0-zen3-1-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
    vendor: Dell driver: r8169 v: kernel port: 3000 bus-ID: 0000:01:00.0
    vendor: Dell driver: ath10k_pci v: kernel bus-ID: 0000:02:00.0
    chip-ID: 168c:0042 class-ID: 0280
  IF-ID-1: wguk121t state: unknown speed: N/A duplex: N/A mac: N/A
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:3 chip-ID: 0cf3:e009
    driver: intel_nvme_remap v: N/A port: 4060 bus-ID: 0000:00:17.0
    chip-ID: 8086:282a rev: N/A class-ID: 0104
  Local Storage: total: 462.05 GiB used: 7.47 GiB (1.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
    model: KBG40ZNS256G NVMe 256GB size: 238.47 GiB block-size: physical: 512 B
    logical: 512 B tech: SSD serial: <filter> fw-rev: 10410106 temp: 22.9 C
  ID-2: /dev/sda maj-min: 8:0 vendor: A-Data model: SU630 size: 223.57 GiB
    serial: <filter> fw-rev: 3R17 scheme: GPT
  ID-1: / raw-size: 60 GiB size: 60 GiB (100.00%) used: 6.69 GiB (11.1%)
    used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /home raw-size: 162.16 GiB size: 162.16 GiB (100.00%)
    used: 799.6 MiB (0.5%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-4: /var/log raw-size: 60 GiB size: 60 GiB (100.00%)
    used: 6.69 GiB (11.1%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-5: /var/tmp raw-size: 60 GiB size: 60 GiB (100.00%)
  ID-1: swap-1 type: zram size: 7.63 GiB used: 0 KiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 16.01 GiB used: 0 KiB (0.0%)
  System Temperatures: cpu: 55.0 C pch: 53.0 C mobo: 36.0 C
  Fan Speeds (rpm): cpu: 0
  Processes: 254 Uptime: 19m wakeups: 0 Memory: total: 8 GiB
  available: 7.63 GiB used: 2.83 GiB (37.1%) Init: systemd v: 255
  pm: pacman pkgs: 1252 libs: 367 tools: paru Shell: fish v: 3.7.0
  running-in: foot inxi: 3.3.31
Garuda (2.6.22-1):
  System install date:     2024-01-21
  Last full system update: 2024-01-21
Let me try to help you out in my own way:
You can use the
window rule move ::: to specify where it would be on the screen:
windowrule = move <offset height from screen> <offset width from screen>,title:^(conky)$
Float rule ::: to make it float
windowrule = float,^(conky)$
fake fullscreen:::: just incase
windowrulev2 = fakefullscreen,title:^(conky)$
This is just an example config that I would use:
check with hyprctl clients for the right class names and title names.
For refrence: This is how I manage xpad on my hyprland config to have sticky notes on my workspaces ps:May have blurred out a thing or two
thanks, i will give it a try. but if i understand good it will still run the conky in windows?
By windows meaning borders & stuff… Yes.
However, with hyprland you can control each applications outlook on the config, even making it have no borders.
This will make it look as normal as it looks on KDE/GNOME e.t.c.
Refer to Hyprland Wiki
Thanks.
I will try find some time for this. I was thinking there is an easier solution. :grin:
windowrule = noborder,^(conky)$
windowrule = opacity, 0.9 0.9,^(conky)$
#windowrule = nofocus,^(conky)$
#windowrule = move x y,^(conky)$
#windowrule = size l w,^(conky)$
Use this then,… apply commented section if need be…
Anyway, hope it works out for you
You make my “job” easier. I will get move to my staff to hyprland and i will try it.
Thanks.
