Conky-manager not working correctly
Also how to get conky-manager namely conky_seamod to display rings?
Neither Green Apple Desktop or Conky_seamod display rings.
Also in just plane Conky, where does it put the confg file, it displays but I can’t find config or conky file to edit it.?
  Kernel: 6.9.1-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=f05fdfe0-830a-4af8-ae75-692329a3c995 rw rootflags=subvol=@
  Desktop: Cinnamon v: 6.0.4 tk: GTK v: 3.24.42 wm: Muffin v: 6.0.1 tools:
    avail: cinnamon-screensaver,xautolock vt: 7 dm: LightDM v: 1.32.0
  Type: Desktop System: Dell product: Inspiron 3670 v: N/A
  Mobo: Dell model: 0H4VK7 v: A01 serial: <superuser required> part-nu: 0868
    uuid: <superuser required> UEFI: Dell v: 2.21.0 date: 12/03/2021
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
  Info: model: Intel Core i5-9600K bits: 64 type: MCP arch: Coffee Lake
    model-id: 0x9E (158) stepping: 0xC (12) microcode: 0xF6
    desc: 1x9 MiB
  Speed (MHz): avg: 1433 high: 4600 min/max: 800/4600 scaling:
    driver: intel_pstate governor: performance cores: 1: 800 2: 800 3: 800
    4: 800 5: 4600 6: 800 bogomips: 44398
  Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Dell
    ports: active: none empty: DP-1,DP-2,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:3e98 class-ID: 0380
  Device-2: NVIDIA GP108 [GeForce GT 1030] vendor: Gigabyte driver: nvidia
    v: 550.78 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
    (as of 2024-04; EOL~2026-12-xx) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 4
    ports: active: none off: HDMI-A-1 empty: DVI-D-1 bus-ID: 01:00.0
    chip-ID: 10de:1d01 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0 driver: X:
    loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa
    dri: iris gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x331mm (23.70x13.03")
    s-diag: 687mm (27.05")
  Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: Acer KB272HL H
    serial: <filter> built: 2022 res: 1920x1080 hz: 75 dpi: 82 gamma: 1.2
    max: 1920x1080 min: 640x480
    surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GT 1030/PCIe/SSE2
    memory: 1.95 GiB
  API: Vulkan v: 1.3.279 layers: 4 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GT 1030 driver: nvidia v: 550.78 device-ID: 10de:1d01
    surfaces: xcb,xlib device: 1 type: integrated-gpu name: Intel UHD
    Graphics 630 (CFL GT2) driver: mesa intel v: 24.0.7-arch1.3
    device-ID: 8086:3e98 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
    (LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.7-arch1.3 (LLVM
    v: kernel alternate: snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_cnl
  Device-2: NVIDIA GP108 High Definition Audio vendor: Gigabyte
    bus-ID: 01:00.1 chip-ID: 10de:0fb8 class-ID: 0403
  API: ALSA v: k6.9.1-zen1-2-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
  Device-2: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0 chip-ID: 8086:15f3
  IF: enp3s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5
  Local Storage: total: 2.3 TiB used: 698.49 GiB (29.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P3PSSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR413 temp: 23.9 C
    model: WD20EARX-00PASB0 size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: AB51
    scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: PNY model: USB 2.0 FD size: 28.91 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
    lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: PMAP scheme: MBR
  ID-1: / raw-size: 232.52 GiB size: 232.52 GiB (100.00%)
    used: 30.99 GiB (13.3%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
    used: 35.7 MiB (37.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 232.52 GiB size: 232.52 GiB (100.00%)
  ID-4: /var/log raw-size: 232.52 GiB size: 232.52 GiB (100.00%)
  ID-5: /var/tmp raw-size: 232.52 GiB size: 232.52 GiB (100.00%)
  ID-1: swap-1 type: zram size: 31.14 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 6 dev: /dev/zram0
  System Temperatures: cpu: 26.0 C pch: 33.0 C mobo: 25.0 C gpu: nvidia
    temp: 32 C
  Fan Speeds (rpm): fan-1: 1006 gpu: nvidia fan: 32%
  Memory: total: 32 GiB available: 31.14 GiB used: 2.8 GiB (9.0%)
  Processes: 313 Power: uptime: 1h 7m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.41 GiB services: csd-power,upowerd
  Packages: pm: pacman pkgs: 1742 libs: 507 tools: pamac,paru,yay Compilers:
    gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
    running-in: gnome-terminal inxi: 3.3.34
  System install date:     2024-04-23
  Last full system update: 2024-05-24
