Hi.
I tried to make a system update with garuda-update. But It fails due to a conflict between qemu-emulators-full and docker-machine-driver-kvm2.
pacman -Syu doesn't fail because I can avoid to substitute qemu with qemu-emulators-full
Any suggestion?
Thanks
Here my garuda-inxi:
Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=e1b87af6-67e0-4350-97cb-8bdfe430d209
rw rootflags=subvol=@ quiet
cryptdevice=UUID=735c2a29-e901-4fc7-893a-52a88bf43878:luks-735c2a29-e901-4fc7-893a-52a88bf43878
root=/dev/mapper/luks-735c2a29-e901-4fc7-893a-52a88bf43878 splash rd.udev.log_priority=3
vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1
resume=/dev/mapper/luks-23c04b79-4698-461f-ade3-f485919f86ca loglevel=3
Console: pty pts/1 DM: SDDM Distro: Garuda Linux base: Arch Linux
Type: Laptop System: FUJITSU product: LIFEBOOK A544 v: N/A serial: <filter> Chassis: type: 10
Mobo: FUJITSU model: FJNBB35 serial: <filter> UEFI: FUJITSU // Phoenix v: Version 1.13
date: 11/18/2013
ID-1: BAT0 charge: 0.8 Wh (88.9%) condition: 0.9/4.5 Wh (20.5%) volts: 12.0 min: 10.8
model: PTL CP651527-01 type: Li-ion serial: <filter> status: N/A cycles: 274
Info: model: Intel Core i7-4702MQ socket: rPGA988B (On Board) note: check bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2190 high: 2195 min/max: 800/3200 base/boost: 2200/2200 scaling:
driver: intel_cpufreq governor: performance volts: 0.8 V ext-clock: 100 MHz cores: 1: 2192
2: 2177 3: 2184 4: 2193 5: 2193 6: 2193 7: 2193 8: 2195 bogomips: 35116
mitigation: Retpolines, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Fujitsu driver: i915
v: kernel ports: active: HDMI-A-1 off: eDP-1 empty: VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0416
Device-2: Importek FJ Camera type: USB driver: uvcvideo bus-ID: 1-7:5 chip-ID: 10f1:1a58
class-ID: 0e02
Display: server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1 compositor: kwin_wayland driver:
X: loaded: modesetting alternate: fbdev,intel,vesa gpu: i915 tty: 110x25
Monitor-1: HDMI-A-1 model: LG (GoldStar) FULL HD built: 2016 res: 1920x1080 dpi: 102
gamma: 1.2 size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9 modes: max: 1920x1080
min: 720x400
Monitor-2: eDP-1 model: Seiko Epson 0x3642 built: 2012 res: 1366x768 dpi: 101 gamma: 1.2
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
Message: GL data unavailable in console for root.
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Fujitsu
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Fujitsu
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
Device-1: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 8086:08b1 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Fujitsu
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0
IF-ID-2: virbr1 state: down mac: <filter>
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-8:7
chip-ID: 8087:07dc class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 5 state: down bt-service: enabled,running rfk-block:
hardware: no software: no address: <filter>
Local Storage: total: 931.51 GiB used: 89.46 GiB (9.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 1TB family: based SSDs
size: 931.51 GiB block-size: physical: 512 B logical: 512 B sata: 3.3 speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 1B6Q temp: 26 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 111d 8h cycles: 940 written: 4.42 TiB
ID-1: / raw-size: 922.45 GiB size: 922.45 GiB (100.00%) used: 89.46 GiB (9.7%) fs: btrfs
block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0
mapped: luks-735c2a29-e901-4fc7-893a-52a88bf43878
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 682 KiB (0.3%) fs: vfat
block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 922.45 GiB size: 922.45 GiB (100.00%) used: 89.46 GiB (9.7%) fs: btrfs
ID-4: /var/log raw-size: 922.45 GiB size: 922.45 GiB (100.00%) used: 89.46 GiB (9.7%)
fs: btrfs block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0
ID-5: /var/tmp raw-size: 922.45 GiB size: 922.45 GiB (100.00%) used: 89.46 GiB (9.7%)
ID-1: swap-1 type: zram size: 7.67 GiB used: 719.1 MiB (9.2%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1
maj-min: 254:1 mapped: luks-23c04b79-4698-461f-ade3-f485919f86ca
System Temperatures: cpu: 68.0 C pch: 55.0 C mobo: 27.8 C
Processes: 311 Uptime: 2d 19h 20m wakeups: 8 Memory: 7.67 GiB used: 2.95 GiB (38.5%)
Init: systemd v: 250 tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages:
pacman: 1680 lib: 387 Shell: Bash v: 5.1.16 running-in: pty pts/1 inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2021-03-13
Last full system update: 2022-05-09 ↻
Failed units: pacman-files.service
[root@fibonacci ~]# systemctl restart pacman-files.service
[root@fibonacci ~]# garuda-inxi
date: 11/18/2013
Speed (MHz): avg: 2193 high: 2198 min/max: 800/3200 base/boost: 2200/2200 scaling:
driver: intel_cpufreq governor: performance volts: 0.8 V ext-clock: 100 MHz cores: 1: 2190
2: 2198 3: 2192 4: 2192 5: 2192 6: 2197 7: 2195 8: 2194 bogomips: 35116
class-ID: 0e02
min: 720x400
ID-1: swap-1 type: zram size: 7.67 GiB used: 718.9 MiB (9.2%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 62.0 C pch: 54.5 C mobo: 27.8 C
Processes: 310 Uptime: 2d 19h 21m wakeups: 8 Memory: 7.67 GiB used: 2.98 GiB (38.8%)
Garuda (2.6.2-1):
And here the output of garuda-update:
################# Arch Linux mirrorlist generated by Reflector #################
# With: reflector --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirrorlist
# When: 2022-05-09 13:52:45 UTC
# From: https://archlinux.org/mirrors/status/json/
# Retrieved: 2022-05-09 13:52:45 UTC
# Last Check: 2022-05-09 13:42:09 UTC
Server = https://archlinux.mailtunnel.eu/$repo/os/$arch
Server = https://mirror.theo546.fr/archlinux/$repo/os/$arch
Server = https://mirror.telepoint.bg/archlinux/$repo/os/$arch
Server = https://geo.mirror.pkgbuild.com/$repo/os/$arch
Server = https://asia.mirror.pkgbuild.com/$repo/os/$arch
:: Sincronizzazione dei database in corso...
core 156,0 KiB 645 KiB/s 00:00 [------------------------------------] 100%
extra 1721,2 KiB 1988 KiB/s 00:01 [------------------------------------] 100%
community 6,6 MiB 3,40 MiB/s 00:02 [------------------------------------] 100%
multilib 173,5 KiB 761 KiB/s 00:00 [------------------------------------] 100%
chaotic-aur 1749,0 KiB 702 KiB/s 00:02 [------------------------------------] 100%
spawn pacman -Su
:: Replace qemu with extra/qemu-desktop? [Y/n] y
:: Replace qemu-arch-extra with extra/qemu-emulators-full? [Y/n] y
resolving dependencies...
:: removing qemu breaks dependency 'qemu-headless' required by docker-machine-driver-kvm2
[root@fibonacci ~]#
[root@fibonacci ~]#
[root@fibonacci ~]#
[root@fibonacci ~]# garuda-update
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur 1748,9 KiB 815 KiB/s 00:02 [------------------------------------] 100%
--> Refreshing mirrorlists using reflector, please be patient..
# When: 2022-05-09 14:02:36 UTC
# Retrieved: 2022-05-09 14:02:26 UTC
# Last Check: 2022-05-09 13:51:22 UTC
Server = https://de.arch.mirror.kescher.at/$repo/os/$arch
Server = https://at.arch.mirror.kescher.at/$repo/os/$arch
Server = https://europe.mirror.pkgbuild.com/$repo/os/$arch
Server = https://america.mirror.pkgbuild.com/$repo/os/$arch
Server = https://mirror.luzea.de/archlinux/$repo/os/$arch
core 156,0 KiB 517 KiB/s 00:00 [------------------------------------] 100%
extra 1721,2 KiB 1553 KiB/s 00:01 [------------------------------------] 100%
community 6,6 MiB 3,06 MiB/s 00:02 [------------------------------------] 100%
multilib 173,5 KiB 626 KiB/s 00:00 [------------------------------------] 100%
chaotic-aur 1748,9 KiB 689 KiB/s 00:03 [------------------------------------] 100%
spawn pacman -Su
