Hello all.
When I reboot Garuda sometimes my system freezes right after I login. It mostly seems to happen at random. Sometimes after a system crash, after I update, or just when I boot up. After the system freezes and I hard reboot, on the linux boot screen I get a Wating for dynamic link cache for about 2 seconds, boot up nomally, then login again. After loging in again applications like Pamac and Brave have the Breeze Dark theme (instead of the Sweetified Plasma theme), The compositor goes starts using OpenGL 2.0 (instead of 3.1), and there's a blue button in the top left corner of every Titlebar (the same one you see if you go to System Settings -> Appearance -> Window Decorations -> Sweet-Dark/Sweet-Dark-transparent. I've gone to Garuda Assistant and reset every config one by one, but only after reseting "All" configs does it fix the issue.
Is there a way to fix this without having to reset all configs?
Kernel: 5.15.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=f4e7b0e7-de23-4a85-9052-1ef321250ac6 rw [email protected]
resume=UUID=203739ae-5fe8-4720-bf53-35f074b31819 loglevel=3
Type: Desktop System: ASUS product: All Series v: N/A
Mobo: ASUSTeK model: MAXIMUS VII FORMULA v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 3503
date: 04/18/2018
Info: model: Intel Core i7-4790K bits: 64 type: MT MCP arch: Haswell
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 4038 high: 4352 min/max: 800/4400 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3998 2: 3998 3: 3998
4: 3998 5: 4003 6: 3998 7: 3966 8: 4352 bogomips: 63961
Type: l1tf
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ZOTAC driver: nvidia
v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1b81
Device-2: NVIDIA GM204 [GeForce GTX 970] vendor: eVga.com. driver: nvidia
v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 02:00.0 chip-ID: 10de:13c2
loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 101 s-size: 966x272mm (38.0x10.7")
s-diag: 1004mm (39.5")
Monitor-1: DP-1 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
Monitor-2: DP-3 res: 1920x1080 hz: 60 dpi: 102
OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: Intel 9 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
Device-2: NVIDIA GP104 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f0
Device-3: NVIDIA GM204 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus-ID: 02:00.1 chip-ID: 10de:0fbb
Sound Server-1: ALSA v: k5.15.12-zen1-1-zen running: yes
Sound Server-5: PipeWire v: 0.3.42 running: yes
Device-1: Intel Ethernet I218-V vendor: ASUSTeK driver: e1000e v: kernel
port: f040 bus-ID: 00:19.0 chip-ID: 8086:15a1 class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel bus-ID: 06:00.0
chip-ID: 8086:24f3 class-ID: 0280
Device-3: TP-Link RTL8812AU Archer T4U 802.11ac type: USB driver: N/A
bus-ID: 7-1.4:4 chip-ID: 2357:0101 class-ID: 0000 serial: <filter>
bus-ID: 3-5.1:4 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 2.29 TiB used: 59.07 GiB (2.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Dogfish Technology model: SSD 512GB
type: SSD serial: <filter> rev: 1A0 scheme: GPT
model: WD10EZEX-21M2NA0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 500GB
ID-4: /dev/sdi maj-min: 8:128 type: USB vendor: Seagate
model: ST9500325AS size: 465.76 GiB block-size: physical: 512 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 214 scheme: GPT
ID-1: / raw-size: 431.05 GiB size: 431.05 GiB (100.00%)
used: 59.07 GiB (13.7%) fs: btrfs dev: /dev/sdc2 maj-min: 8:34
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
ID-3: /home raw-size: 431.05 GiB size: 431.05 GiB (100.00%)
ID-4: /var/log raw-size: 431.05 GiB size: 431.05 GiB (100.00%)
ID-5: /var/tmp raw-size: 431.05 GiB size: 431.05 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.42 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdc3 maj-min: 8:35
ID-2: swap-2 type: zram size: 31.29 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 48 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 13%
Processes: 379 Uptime: 2h 24m wakeups: 0 Memory: 31.29 GiB
used: 9.21 GiB (29.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 2178 lib: 587 flatpak: 0
Shell: fish v: 3.3.1 running-in: konsole inxi: 3.3.11
