@moderators Can any of you enable me to edit the first post again?
I have a new update - being able to tab through suggestions - and like to introduce that.
I also consider just hosting this on Codeberg, Gitlab or any other instance - but then again, would love to add that to this post.
Or do you recommend opening another post?
If you like to edit yourself:
function add --wraps "pacman -S"
update --skip-mirrorlist &&
paru -Sua &&
echo \n "Update pkgfile database" \n &&
sudo pkgfile --update &&
if set -q argv[1]
sudo pacman -S $argv
if test $status -eq 1
paru -S --aur --skipreview $argv
end
end
end
As you can see, the first line changed.
