Chroot into encrypted partition
I might be misuerstanding, but do you want me to boot off a snapshot and try garuda-update from it?
No. I was suggesting to first try the chroot, garuda-update and kernel reinstallation.
If this should not help, I was reminding the possibility to restore a snapshot.
Thanks for the response, had a chuckle.
But essentially I updated the system through Garuda Helper as usual and I got the same issue as the other chap in the other post. I can’t boot in to the OS. I can however boot in to a Snapshot. But… The issue is nothing on the snapshot besides photos, videos etc work. Firedragon says there is no profile, other software just won’t load and so forth.
As for fixing this, what steps are needed? As I said, I’m a bit of a caveman.
Here is my attempt at updating it from the live environment. It says there is no space even though I know there is.
 ╭─garuda@garuda in ~ as 🧙
 ╰─λ lsblk -f
NAME    FSTYPE FSVER LABEL            UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
loop0   squash 4.0                                                               0   100% /run/miso/sfs/livefs
loop1   squash 4.0                                                               0   100% /run/miso/sfs/mhwdfs
loop2   squash 4.0                                                               0   100% /run/miso/sfs/desktopfs
loop3   squash 4.0                                                               0   100% /run/miso/sfs/rootfs
sda
├─sda1  ntfs                          307CC93C7CC8FE1A
├─sda2  vfat   FAT32                  48E2-7C54
├─sda3
├─sda4
└─sda5  ntfs                          4E28335A28333FEF
sdb     iso966 Jolie GARUDA_GNOME_RAPTOR
                                      2023-03-19-16-49-22-00
├─sdb1  iso966 Jolie GARUDA_GNOME_RAPTOR
│                                     2023-03-19-16-49-22-00                     0   100% /run/miso/bootmnt
└─sdb2  vfat   FAT12 MISO_EFI         B49B-B214
zram0        [SWAP]
nvme1n1
├─nvme1n1p1
│       vfat   FAT32                  497C-2B30
└─nvme1n1p2
        crypto 1                      f2314da2-7bb3-4bfa-83ba-9a58d102e216
nvme0n1
├─nvme0n1p1
│       vfat   FAT32                  1228-F410
├─nvme0n1p2
└─nvme0n1p3
 ╭─garuda@garuda in ~ as 🧙 took 14ms
 ╰─λ sudo mkdir -p /mnt/broken
 ╭─garuda@garuda in ~ as 🧙 took 7ms
 ╰─λ sudo cryptsetup open /dev/nvme1n1p2 crypto_LUKS
Enter passphrase for /dev/nvme1n1p2:
 ╭─garuda@garuda in ~ as 🧙 took 4s
 ╰─λ
 ╰─λ sudo mount /dev/mapper/crypto_LUKS /mnt/broken
 ╭─garuda@garuda in ~ as 🧙 took 80ms
 ╰─λ sudo garuda-chroot /mnt/broken/@
sh-5.2# garuda-update
error: failed to synchronize all databases (unable to lock database)
mkdir: cannot create directory '/var/log/garuda/': No space left on device
sh-5.2# pacman -S linux-zen linux-zen-headers
error: failed to init transaction (unable to lock database)
error: could not lock database: No space left on device
sh-5.2#
Try this one instead (after opening and mounting crypto)
Is this right?
╭─garuda@garuda in ~ as 🧙 took 95ms
mount: /mnt/broken/proc: mount point does not exist.
       dmesg(1) may have more information after failed mount system call.
==> ERROR: failed to setup API filesystems in chroot /mnt/broken
umount: bad usage
Try 'umount --help' for more information.
 ╭─garuda@garuda in ~ as 🧙 took 57ms
Try with -a, like this:
garuda-chroot -a
It should ask you to identify the Linux partition, and then automatically mount the subvolumes and set the chroot for you.
Now what?
[⚡] × garuda-chroot -a
==> Mounting (Garuda_Linux) [/dev/mapper/crypto_LUKS]
 --> mount: [/mnt]
 --> mount: [/mnt/boot/efi]
[root@garuda-gnome /]#
Now you attempt the update.
garuda-update
Mission failed, sad times.
 --> mount: [/mnt]
[root@garuda-gnome /]# garuda-update
rm /var/lib/pacman/db.lck
[root@garuda-gnome /]# rm /var/lib/pacman/db.lck
rm: cannot remove '/var/lib/pacman/db.lck': No such file or directory
Encrypted or decrypted database?
Seems it is not my …
Year :smiley: :wink:
Yes, the device is full. I think we already knew that. You need to create some space to continue.
Clear the package cache:
paccache -rk0
Also delete some snapshots with Btrfs Assistant.
It can’t be full, it has 41gb free.
I think the issue is because I used rufus to flash the usb drive I’m using, it’s saying that is full.
Anyway here is what I get.
[root@garuda-gnome /]# paccache -rk0
==> ERROR: cachedir '/var/cache/pacman/pkg/' does not exist or is not a directory
Perhaps you have chrooted the wrong device.
I’m still new to this, can you identify from this?
 ╰─λ lsblk -f
sda
├─sda3
├─sda4
sdb       iso966 Jolie GARUDA_GNOME_BIRDOFPREY 2024-04-28-13-31-10-00
├─sdb1    iso966 Jolie GARUDA_GNOME_BIRDOFPREY 2024-04-28-13-31-10-00                     0   100% /run/miso/bootmnt
└─sdb2    vfat   FAT12 MISO_EFI                EFF1-3B17
zram0        [SWAP]
nvme1n1
├─nvme1n1p1
│         vfat   FAT32                         497C-2B30                             298.7M     0% /mnt/boot/efi
└─nvme1n1p2
  │       crypto 1                             f2314da2-7bb3-4bfa-83ba-9a58d102e216
  └─crypto_LUKS
          btrfs                                d06acea6-ea8c-4f8f-941c-00a29881dbad                /mnt
        /mnt/broken
nvme0n1
├─nvme0n1p1
├─nvme0n1p2
└─nvme0n1p3
Oh hmm…you already have the disk mounted here and there from some of the other efforts in the thread. It is likely that is the issue.
Let’s try to start fresh by rebooting. Then come back into the live environment, unlock the LUKS device, and run garuda-chroot -a again.
Alright, I’m freshly rebooted, I’ve gone in the file manager, clicked the drive, unlocked and I’m here in terminal.
 ╰─λ garuda-chroot -a
==> Mounting (Garuda_Linux) [/dev/mapper/luks-f2314da2-7bb3-4bfa-83ba-9a58d102e216]
 --> mount: [/mnt]
Hmm, still looks funny. What does this command output?
findmnt --real
