Sometimes chrome takes too long to open
Not only chrome other application like vs code also take too long to open
Define long
We are not psychics, we need more details, what operating system are you using, Windows?
Read
please
and post
inxi -Fxxxza
as text!
Even if you personally think it is unnecessary.
and
I am using Garuda KDE Dr460nized
Not always but sometimes application takes too long to start
Application that i noticed taking too long to start
1--visual studio code
2--chrome
3--dolphin
As @SGS has already stated without your system specs and some ram usage statistics this conversation is going nowhere.
System: Kernel: 5.12.2-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=9699b3da-875a-4507-9cf0-a4a1b0dc3b79
systemd.unified_cgroup_hierarchy=1 resume=UUID=34b61e46-1cf3-44cb-8205-37ea3381524a loglevel=3
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: ASUSTeK model: EX-A320M-GAMING v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 5007 date: 06/18/2019
CPU: Info: Quad Core model: AMD Ryzen 5 3400G with Radeon Vega Graphics bits: 64 type: MT MCP
arch: Zen/Zen+ note: check family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108102
cache: L2: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 59089
Speed: 1249 MHz min/max: 1400/3700 MHz boost: enabled Core speeds (MHz): 1: 1249 2: 1305
3: 1726 4: 1311 5: 1314 6: 2453 7: 2342 8: 1246
Graphics: Device-1: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 06:00.0
chip-ID: 1002:15d8 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: amdgpu,ati
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4") s-diag: 485mm (19.1")
Monitor-1: HDMI-A-0 res: 1600x900 hz: 60 dpi: 94 size: 434x236mm (17.1x9.3")
diag: 494mm (19.4")
OpenGL: renderer: AMD Radeon Vega 11 Graphics (RAVEN DRM 3.40.0 5.12.2-zen2-1-zen LLVM 11.1.0)
v: 4.6 Mesa 21.1.0 direct render: Yes
Audio: Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 06:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.12.2-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.27 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
v: kernel port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB driver: r8188eu
bus-ID: 1-7:2 chip-ID: 0bda:8179 class-ID: 0000 serial: <filter>
IF: wlp1s0f0u7 state: up mac: <filter>
Drives: Local Storage: total: 689.33 GiB used: 127.9 GiB (18.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1 size: 223.57 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 041
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3500414CS size: 465.76 GiB block-size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s rotation: 5900 rpm serial: <filter> rev: CA14
Partition: ID-1: / raw-size: 214.52 GiB size: 214.52 GiB (100.00%) used: 13.07 GiB (6.1%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 546 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 214.52 GiB size: 214.52 GiB (100.00%) used: 13.07 GiB (6.1%) fs: btrfs
ID-4: /var/log raw-size: 214.52 GiB size: 214.52 GiB (100.00%) used: 13.07 GiB (6.1%) fs: btrfs
ID-5: /var/tmp raw-size: 214.52 GiB size: 214.52 GiB (100.00%) used: 13.07 GiB (6.1%) fs: btrfs
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
ID-2: swap-2 type: zram size: 740.7 MiB used: 3 MiB (0.4%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 740.7 MiB used: 3.1 MiB (0.4%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 740.7 MiB used: 2.6 MiB (0.4%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 740.7 MiB used: 2.9 MiB (0.4%) priority: 32767 dev: /dev/zram3
ID-6: swap-6 type: zram size: 740.7 MiB used: 2.7 MiB (0.4%) priority: 32767 dev: /dev/zram4
ID-7: swap-7 type: zram size: 740.7 MiB used: 2.5 MiB (0.3%) priority: 32767 dev: /dev/zram5
ID-8: swap-8 type: zram size: 740.7 MiB used: 2.6 MiB (0.4%) priority: 32767 dev: /dev/zram6
ID-9: swap-9 type: zram size: 740.7 MiB used: 2.5 MiB (0.3%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 47.2 C mobo: 0 C gpu: amdgpu temp: 47.0 C
Info: Processes: 311 Uptime: 40m wakeups: 0 Memory: 5.79 GiB used: 2.92 GiB (50.5%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1212 lib: 301
Shell: fish v: 3.2.2 running-in: konsole inxi: 3.3.04
Buy more RAM.
Integrated GPU?
Ya I have integrated gpu
Does firedragon work fine?
i dont use firedragon when i have to use web browser i then i always use chrome so i cant say about it
You can at least test firedragon. It is pre-installed.
Dont think that i have not used firedragon i have used few times but now i will use it frequently
i think for me it's UI is bit different from other browser UI
