❯ sudo pacman -Sy list --arch -a ─╯
[sudo] password for janer:
error: failed retrieving file 'core.db' from www.caco.ic.unicamp.br : The requested URL returned error: 404
error: failed to update core (failed to retrieve some files)
error: failed retrieving file 'extra.db' from www.caco.ic.unicamp.br : The requested URL returned error: 404
error: failed to update extra (failed to retrieve some files)
error: failed retrieving file 'community.db' from www.caco.ic.unicamp.br : The requested URL returned error: 404
error: failed to update community (failed to retrieve some files)
error: failed retrieving file 'multilib.db' from www.caco.ic.unicamp.br : The requested URL returned error: 404
error: failed to update multilib (failed to retrieve some files)
error: failed retrieving file 'chaotic-aur.db' from builds.garudalinux.org : The requested URL returned error: 404
error: failed retrieving file 'chaotic-aur.db' from repo.kitsuna.net : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
error: failed retrieving file 'chaotic-aur.db' from chaotic.tn.dedyn.io : The requested URL returned error: 404
error: failed retrieving file 'chaotic-aur.db' from repo.jkanetwork.com : The requested URL returned error: 404
error: failed retrieving file 'chaotic-aur.db' from chaotic.dr460nf1r3.me : The requested URL returned error: 404
error: failed retrieving file 'chaotic-aur.db' from chaotic.bangl.de : The requested URL returned error: 404
error: failed retrieving file 'chaotic-aur.db' from mirror.maakpain.kro.kr : The requested URL returned error: 404
error: failed to update chaotic-aur (failed to retrieve some files)
error: failed to synchronize all databases
Using Garuda Gnome ...
I'm not exactly sure about that ...
But Chaotic-AUR updates don't seem to be fully integrated with Pamac.
I need to open Pamac and click on Update Database to start the update.
While they should appear and be run through the Pamac main window.
I run Pamac and the system update never appears.
In other words, Pamac does not search for Chaotic-AUR updates. Among others.
What is the definitive solution for this? Or should I install the Bauh app?
The Bauh also did not resolve the unsynchronized packets shown by Terminal.
The Pamac Updates Indicator extension remains enabled.
Meanwhile, the command 'yay -Syu' or 'sudo pacman -Syu' says that the items above are already updated.
❯ yay -Syu
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur 697.2 KiB 610 KiB/s 00:01 [----------------------------------------] 100%
warning: gesture-manager-x-git: local (0.1-1) is newer than chaotic-aur (r9.ce6f7d0-1)
there is nothing to do
:: Searching databases for updates...
:: Searching AUR for updates...
-> gesture-manager-x-git: local (0.1-1) is newer than chaotic-aur (r9.ce6f7d0-1)
