Chaotic-AUR | Packages | Requests | Recompilation | Reports
==> Starting prepare()...
  java-19-openjdk (default)
grep: /usr/lib/jvm/default/lib/javafx.properties: No such file or directory
Major part of JavaFX version in pom does not match the version in JDK
==> ERROR: A failure occurred in prepare().
    Aborting...
error: failed to build 'cryptomator-1.6.16-1':
error: packages failed to build: cryptomator-1.6.16-1
sudo cp /lib/jvm/java-19-openjfx/lib/javafx.properties /usr/lib/jvm/default/lib/
DAMN
[INFO] Building jar: /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/cryptomator-1.6.16.jar
[INFO] ------------------------------------------------------------------------
[INFO] BUILD SUCCESS
[INFO] Total time:  38.683 s
[INFO] Finished at: 2022-12-07T12:52:48+01:00
/home/sgs/.cache/paru/clone/cryptomator/PKGBUILD: line 52: jlink: command not found
==> ERROR: A failure occurred in build().
    Aborting...
jlink \
    --output runtime \
    --module-path jmod \
    --add-modules java.base,java.desktop,java.instrument,java.logging,java.naming,ja>
    --strip-native-commands \
    --no-header-files \
    --no-man-pages \
    --strip-debug \
    --compress=1
Goes beyond my ability.
@SGS jlink is in /usr/lib/jvm/default/bin/jlink, maybe you could help find jpackage?
See more progress at:
sgs@y7p in /πŸ”’ as πŸ§™
πŸ•™ 01:09:15
Ξ» sudo cp /lib/jvm/java-19-openjfx/lib/javafx.properties /usr/lib/jvm/default/lib/
πŸ•™ 01:09:28
Ξ» sudo cp /usr/lib/jvm/default/bin/jlink /usr/lib/jvm/default/lib/
πŸ•™ 01:09:36
Ξ» update
garuda is up to date
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur                                                   2,1 MiB  2,53 MiB/s 00:01 [---------------------------------------------------] 100%
spawn pacman -Su
there is nothing to do
--> Updating AUR packages with paru..
:: Looking for AUR upgrades...
:: Looking for devel upgrades...
:: Resolving dependencies...
:: Calculating conflicts...
:: Calculating inner conflicts...
:: packages not in the AUR: rootactions-servicemenu
Aur (1) cryptomator-1.6.16-1
:: Proceed to review? [Y/n]:
:: Downloading PKGBUILDs...
PKGBUILDs up to date
nothing new to review
fetching devel info...
==> Making package: cryptomator 1.6.16-1 (Do 08 Dez 2022 01:10:05 CET)
==> Retrieving sources...
-> Found cryptomator-1.6.16.tar.gz
-> Found cryptomator-1.6.16.tar.gz.asc
==> Validating source files with sha256sums...
cryptomator-1.6.16.tar.gz ... Passed
cryptomator-1.6.16.tar.gz.asc ... Skipped
==> Verifying source file signatures with gpg...
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
==> Removing existing $srcdir/ directory...
==> Extracting sources...
-> Extracting cryptomator-1.6.16.tar.gz with bsdtar
javafx.version=19
==> Sources are ready.
cryptomator-1.6.16-1: parsing pkg list...
==> Making package: cryptomator 1.6.16-1 (Do 08 Dez 2022 01:10:07 CET)
==> WARNING: Using existing $srcdir/ tree
==> Removing existing $pkgdir/ directory...
==> Starting build()...
[INFO] Scanning for projects...
[INFO]
[INFO] --------------------< org.cryptomator:cryptomator >---------------------
[INFO] Building Cryptomator Desktop App 1.6.16
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] --- versions-maven-plugin:2.13.0:set (default-cli) @ cryptomator ---
[INFO] Searching for local aggregator root...
[INFO] Local aggregation root: /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16
[INFO] Processing change of org.cryptomator:cryptomator:1.6.16 -> 1.6.16
[INFO] Total time:  0.834 s
[INFO] Finished at: 2022-12-08T01:10:09+01:00
[INFO]
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ cryptomator ---
[INFO]
[INFO] --- license-maven-plugin:2.0.0:add-third-party (add-third-party) @ cryptomator ---
[WARNING]
[WARNING] licenseMerges will be overridden by licenseMergesUrl.
[WARNING]
[INFO] Writing third-party file to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/generated-sources/license/THIRD-PARTY.txt
[INFO]
[INFO] --- maven-resources-plugin:3.3.0:resources (default-resources) @ cryptomator ---
[INFO] Copying 154 resources
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:3.10.1:compile (default-compile) @ cryptomator ---
[INFO] Required filename-based automodules detected: [javax.inject-1.jar]. Please don't publish this project to a public artifact repository!
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 300 source files to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/classes
[INFO] /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/src/main/java/org/cryptomator/ui/recoverykey/WordEncoder.java: Some input files use unchecked or unsafe operations.
[INFO] /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/src/main/java/org/cryptomator/ui/recoverykey/WordEncoder.java: Recompile with-Xlint:unchecked for details.
[INFO]
[INFO] --- exec-maven-plugin:3.1.0:java (compile-light-theme) @ cryptomator ---
[INFO]
[INFO] --- exec-maven-plugin:3.1.0:java (compile-dark-theme) @ cryptomator ---
[INFO]
[INFO] --- maven-resources-plugin:3.3.0:testResources (default-testResources) @ cryptomator ---
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.10.1:testCompile (default-testCompile) @ cryptomator ---
[INFO] Compiling 27 source files to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/test-classes
[INFO] /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/src/test/java/org/cryptomator/ui/recoverykey/RecoveryKeyFactoryTest.java: /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/src/test/java/org/cryptomator/ui/recoverykey/RecoveryKeyFactoryTest.java uses uncheckedor unsafe operations.
[INFO] /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/src/test/java/org/cryptomator/ui/recoverykey/RecoveryKeyFactoryTest.java: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-surefire-plugin:3.0.0-M7:test (default-test) @ cryptomator ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-dependency-plugin:3.3.0:copy-dependencies (copy-mods) @ cryptomator ---
[INFO] Copying cryptofs-2.5.3.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/cryptofs-2.5.3.jar
[INFO] Copying cryptolib-2.1.0.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/cryptolib-2.1.0.jar
[INFO] Copying siv-mode-1.4.4.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/siv-mode-1.4.4.jar
[INFO] Copying fuse-nio-adapter-1.3.4.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/fuse-nio-adapter-1.3.4.jar
[INFO] Copying dokany-nio-adapter-1.3.3.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/dokany-nio-adapter-1.3.3.jar
[INFO] Copying commons-cli-1.4.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/commons-cli-1.4.jar
[INFO] Copying webdav-nio-adapter-1.2.8.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/webdav-nio-adapter-1.2.8.jar
[INFO] Copying webdav-nio-adapter-servlet-1.2.1.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/webdav-nio-adapter-servlet-1.2.1.jar
[INFO] Copying jetty-server-10.0.10.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/jetty-server-10.0.10.jar
[INFO] Copying jetty-servlet-api-4.0.6.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/jetty-servlet-api-4.0.6.jar
[INFO] Copying jetty-http-10.0.10.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/jetty-http-10.0.10.jar
[INFO] Copying jetty-util-10.0.10.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/jetty-util-10.0.10.jar
[INFO] Copying jetty-io-10.0.10.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/jetty-io-10.0.10.jar
[INFO] Copying jetty-servlet-10.0.10.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/jetty-servlet-10.0.10.jar
[INFO] Copying jetty-security-10.0.10.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/jetty-security-10.0.10.jar
[INFO] Copying integrations-api-1.2.0-beta1.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/integrations-api-1.2.0-beta1.jar
[INFO] Copying slf4j-api-2.0.3.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/slf4j-api-2.0.3.jar
[INFO] Copying logback-core-1.4.4.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/logback-core-1.4.4.jar
[INFO] Copying logback-classic-1.4.4.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/logback-classic-1.4.4.jar
[INFO] Copying commons-lang3-3.12.0.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/commons-lang3-3.12.0.jar
[INFO] Copying tiny-oauth2-client-0.5.1.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/tiny-oauth2-client-0.5.1.jar
[INFO] Copying java-jwt-4.2.1.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/java-jwt-4.2.1.jar
[INFO] Copying jackson-databind-2.13.4.2.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/jackson-databind-2.13.4.2.jar
[INFO] Copying jackson-annotations-2.13.4.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/jackson-annotations-2.13.4.jar
[INFO] Copying jackson-core-2.13.4.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/jackson-core-2.13.4.jar
[INFO] Copying nimbus-jose-jwt-9.25.4.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/nimbus-jose-jwt-9.25.4.jar
[INFO] Copying jcip-annotations-1.0-1.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/jcip-annotations-1.0-1.jar
[INFO] Copying easybind-2.2.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/easybind-2.2.jar
[INFO] Copying zxcvbn-1.7.0.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/zxcvbn-1.7.0.jar
[INFO] Copying guava-31.1-jre.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/guava-31.1-jre.jar
[INFO] Copying failureaccess-1.0.1.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/failureaccess-1.0.1.jar
[INFO] Copying dagger-2.44.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/dagger-2.44.jar
[INFO] Copying javax.inject-1.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/javax.inject-1.jar
[INFO] Copying gson-2.9.1.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/gson-2.9.1.jar
[INFO] Copying integrations-linux-1.1.0.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/integrations-linux-1.1.0.jar
[INFO] Copying hkdf-1.1.0.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/mods/hkdf-1.1.0.jar
[INFO]
[INFO] --- maven-dependency-plugin:3.3.0:copy-dependencies (copy-libs) @ cryptomator ---
[INFO] Copying jnr-fuse-0.5.7.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/jnr-fuse-0.5.7.jar
[INFO] Copying jnr-ffi-2.2.7.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/jnr-ffi-2.2.7.jar
[INFO] Copying jffi-1.3.5.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/jffi-1.3.5.jar
[INFO] Copying jffi-1.3.5-native.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/jffi-1.3.5-native.jar
[INFO] Copying jnr-a64asm-1.0.0.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/jnr-a64asm-1.0.0.jar
[INFO] Copying jnr-x86asm-1.0.2.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/jnr-x86asm-1.0.2.jar
[INFO] Copying jnr-posix-3.1.10.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/jnr-posix-3.1.10.jar
[INFO] Copying jnr-constants-0.10.2.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/jnr-constants-0.10.2.jar
[INFO] Copying jnr-unixsocket-0.38.5.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/jnr-unixsocket-0.38.5.jar
[INFO] Copying jnr-enxio-0.32.3.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/jnr-enxio-0.32.3.jar
[INFO] Copying asm-9.2.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/asm-9.2.jar
[INFO] Copying asm-commons-9.2.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/asm-commons-9.2.jar
[INFO] Copying asm-analysis-9.2.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/asm-analysis-9.2.jar
[INFO] Copying asm-tree-9.2.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/asm-tree-9.2.jar
[INFO] Copying asm-util-9.2.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/asm-util-9.2.jar
[INFO] Copying jna-5.9.0.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/jna-5.9.0.jar
[INFO] Copying jna-platform-5.9.0.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/jna-platform-5.9.0.jar
[INFO] Copying jackrabbit-webdav-2.21.5.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/jackrabbit-webdav-2.21.5.jar
[INFO] Copying httpcore-4.4.14.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/httpcore-4.4.14.jar
[INFO] Copying secret-service-1.7.0.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/secret-service-1.7.0.jar
[INFO] Copying kdewallet-1.2.6.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/kdewallet-1.2.6.jar
[INFO] Copying dbus-java-3.3.0.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/dbus-java-3.3.0.jar
[INFO] Copying dbus-java-core-4.0.0.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/dbus-java-core-4.0.0.jar
[INFO] Copying dbus-java-transport-native-unixsocket-4.0.0.jar to /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/libs/dbus-java-transport-native-unixsocket-4.0.0.jar
[INFO]
[INFO] --- maven-jar-plugin:3.3.0:jar (default-jar) @ cryptomator ---
[INFO] Total time:  11.608 s
[INFO] Finished at: 2022-12-08T01:10:21+01:00
Aborting...
Paru exited with error code 1
Checking for plugin updates
Nothing to install / update
System updated! 🐧
IDK what
means :slight_smile:
ls /home/sgs/.cache/paru/clone/cryptomator/src/cryptomator-1.6.16/target/
drwxr-xr-x    - sgs  8 Dez 01:10 ο„• classes
drwxr-xr-x    - sgs  8 Dez 01:10 ο„• generated-sources
drwxr-xr-x    - sgs  8 Dez 01:10 ο„• generated-test-sources
drwxr-xr-x    - sgs  8 Dez 01:10 ο„• libs
drwxr-xr-x    - sgs  8 Dez 01:10 ο„• maven-archiver
drwxr-xr-x    - sgs  8 Dez 01:10 ο„• maven-status
drwxr-xr-x    - sgs  8 Dez 01:10 ο„• mods
drwxr-xr-x    - sgs  8 Dez 01:10 ο„• test-classes
.rw-r--r-- 2,6M sgs  8 Dez 01:10 ξˆ„ cryptomator-1.6.16.jar
.rw-r--r--  704 sgs  8 Dez 01:10 ξ˜‹ launcher-gtk2.properties
.rwxr-xr-x  430 sgs  8 Dez 01:10 ο’‰ launcher.sh
.rw-r--r--  35k sgs  8 Dez 01:10 ο…œ LICENSE.txt
grafik
I cant edit my posts :expressionless:
I think this line is wrong, (ja> at the end, and missing \. Maybe just the terminal window was too small :smiley: )
java.lang.module.FindException: Module javafx.base not found
	at java.base/java.lang.module.Resolver.findFail(Resolver.java:892)
	at java.base/java.lang.module.Resolver.resolve(Resolver.java:129)
	at java.base/java.lang.module.Configuration.resolve(Configuration.java:420)
	at java.base/java.lang.module.Configuration.resolve(Configuration.java:254)
	at jdk.jlink/jdk.tools.jlink.internal.Jlink$JlinkConfiguration.resolve(Jlink.java:217)
	at jdk.jlink/jdk.tools.jlink.internal.JlinkTask.createImageProvider(JlinkTask.java:536)
	at jdk.jlink/jdk.tools.jlink.internal.JlinkTask.createImage(JlinkTask.java:424)
	at jdk.jlink/jdk.tools.jlink.internal.JlinkTask.run(JlinkTask.java:276)
	at jdk.jlink/jdk.tools.jlink.internal.Main.run(Main.java:56)
	at jdk.jlink/jdk.tools.jlink.internal.Main.main(Main.java:34)
In Java 11 the JavaFX components have been removed into their own SDK, so when you run it won’t be able to find them in the runtime.
The JavaFX page has the instructions to get it going: Getting Started with JavaFX
In short, you have to compile / run by adding the javafx modules in, either as options passed on the command line, or using a modular project.
I found that the modular project with Maven and IntelliJ worked best for me. Getting Started with JavaFX
I am out.
I hate Java :grin:
SailReal commented on 2022-12-07 23:36 (UTC)
@Technetium1 Hmm you’re right, thanks for mentioning it, will fix it tomorrow.
Hi, sorry if this is the wrong place to ask. If it is, just tell me to get out :smiley: lololol
I'm assuming ungoogled-chromium that is provided via the setup assistant is provided by Chaotic AUR and is built by the maintainer?
After updating last night, I've run into the issue described in this GitHub issue, where Chromium won't start due to the error mentioned in that thread:
/usr/lib/chromium/chromium: error while loading shared libraries: libre2.so.9: cannot open shared object file:No such file or directory.
Apparently it needs to be rebuilt against the re2 update - looking back in /var/log/pacman.log, the update was [2022-12-08T00:52:45+1100] [ALPM] upgraded re2 (1:20220601-1 -> 1:20221201-1).
In case it's of any use, here's the output of pacman -Qi ungoogled-chromium:
Version         : 108.0.5359.94-1
Description     : A lightweight approach to removing Google web service dependency
Architecture    : x86_64
URL             : https://github.com/ungoogled-software/ungoogled-chromium
Licenses        : BSD
Groups          : None
Provides        : chromium
Depends On      : gtk3  nss  alsa-lib  xdg-utils  libxss  libcups  libgcrypt  ttf-liberation  systemd  dbus
libpulse  pciutils  libva  wayland  desktop-file-utils  hicolor-icon-theme  fontconfig
woff2  aom  brotli  libjpeg  icu  dav1d  flac  snappy  libxml2  ffmpeg  libwebp  minizip
opus  harfbuzz  re2  libavif  jsoncpp  libxslt  libpng  freetype2
Optional Deps   : pipewire: WebRTC desktop sharing under Wayland [installed]
kdialog: support for native dialogs in Plasma [installed]
org.freedesktop.secrets: password storage backend on GNOME / Xfce [installed]
kwallet: support for storing passwords in KWallet on Plasma [installed]
Required By     : None
Optional For    : None
Conflicts With  : chromium
Replaces        : None
Installed Size  : 279.30 MiB
Packager        : UFSCar HPC Builder <hpc.ufscar@chaotic.cx>
Build Date      : Sun 04 Dec 2022 21:08:45
Install Date    : Thu 08 Dec 2022 12:06:03
Install Reason  : Explicitly installed
Install Script  : No
Validated By    : Signature
As you can see, I gave it a reinstall to see what would happen but that obviously didn't work.
Not being able to use it is no big deal for me since I normally use Librewolf anyways, but having Chromium handy in case Librewolf breaks stuff is useful :slight_smile:
Same issue here. (scratch that, fixed locally)
I found this thread: https://forum.artixlinux.org/index.php/topic,1343.0.html
Turned out the library had been updated to libre2.so.10.0.0.
So in /usr/lib I created a symlink called libre2.so.9, pointing to libre2.so.
That solved the issue for me.
Awesome find, thanks Guybrush! :smiley:
Will just need to make sure to remove the link when the package gets a fresh build. ^^
Its built by our builders, yes. A fresh version has been built so it should work without the dirty workaround you mentioned :wink:
I started the ungoogled-chromium build before I went to bed. It finished 08:30 CET.
@SGS Thanks! I looked quite hard and somehow missed that path. We should be able to fix path in GitHub - chaotic-aur/interfere: This is how we interfere with broken AUR packages πŸ”§ for cryptomator and get it to build successfully. Hopefully no other shenanigans are required.
Finished making: cryptomator 1.6.16-1 (Sat 10 Dec 2022 05:27:32 PM CET) :tada:
Hi!
Can you please add joplin? There are some more joplin-packages in the AUR, but Appimage is the package provided by their homepage, and it is the only one in the AUR that is not flagged as out of date.
https://aur.archlinux.org/packages/joplin-appimage
Okay, but I'm going to replace it with a non-appimage when others eventually update. I didn't realize it would take so long and there would still be no updates. There are important security updates in the prereleases, but not stable, so I added joplin-beta-appimage.
I think useful for many who need proof to lower their ISP charges. :grin:
Unfortunately, Arch users have been forgotten. :frowning:
KUDOS :slight_smile:
git clone https://aur.archlinux.org/breitbandmessung.git
https://aur.archlinux.org/packages/breitbandmessung
Easy check with
speedtest++
for the rest of the world :wink:
Got it added :slight_smile: Add breitbandmessung for SGS Β· chaotic-aur/packages@981e2d8 Β· GitHub
Very nice of you, thank you very much :slight_smile:
Could you start compiling wayfire-git with meson -Db_sanitize=address? Makes it easier to debug issues as one doesn't have to always rebuild wayfire when a crash occurs that one needs to get behind. (Which happens somewhat frequently for me)
also could you add mesa-git? I sadly depend on some new patches :confused:
mesa-tkg-git and lib32-mesa-tkg-git are what I use personally.
