Changing sound devices on kde
I have a blue-tooth sound bar and a dongle wireless headset they both work great; but changing audio device is not working the way I was used to it in Manjaro KDE. Is there a quick way to switch?
When I click on the sound icon in the tray and drops down to show devices. You can't un-toggle a device and when you want to switch to the other you have to have it playing and go into "configure audio devices" click on the "Configure" button on the bottom of the audio tab and change the output source in the drop down menu. I remember it being simple in Manjaro KDE click on audio icon in tray choose which device and it stays that way. Right now it will switch back to my sound bar sometimes if i have no audio playing. I hope I just missed something and its a simple fix but kind of annoying trying to not wake up my wife
Thanks
System:    Kernel: 5.13.4-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=d1a15a3b-a9ac-446d-9ae1-53f89a60345b rw
[email protected] quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine:   Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
Mobo: ASUSTeK model: ROG STRIX X470-I GAMING v: Rev 1.xx serial: <filter> UEFI: American Megatrends v: 4301
date: 03/04/2021
CPU:       Info: 6-Core model: AMD Ryzen 5 3600XT bits: 64 type: MT MCP arch: Zen 2 family: 17 (23) model-id: 71 (113)
stepping: 0 microcode: 8701021 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 91035
Speed: 3612 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz): 1: 3612 2: 3842 3: 3738 4: 4499 5: 3799
6: 4312 7: 3727 8: 4143 9: 3775 10: 4032 11: 3676 12: 3833
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] vendor: XFX Pine
driver: amdgpu v: kernel bus-ID: 0a:00.0 chip-ID: 1002:731f class-ID: 0300
Display: x11 server: X.Org 1.20.12 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting,radeon
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.0x22.5") s-diag: 1165mm (45.9")
Monitor-1: DisplayPort-1 res: 3840x2160 hz: 60 dpi: 161 size: 607x345mm (23.9x13.6") diag: 698mm (27.5")
OpenGL: renderer: AMD Radeon RX 5700 (NAVI10 DRM 3.41.0 5.13.4-zen2-1-zen LLVM 12.0.1) v: 4.6 Mesa 21.1.5
direct render: Yes
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio driver: snd_hda_intel v: kernel bus-ID: 0a:00.1
chip-ID: 1002:ab38 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Kingston HyperX Cloud II Wireless type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-3:4
chip-ID: 0951:1718 class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.13.4-zen2-1-zen running: yes
Network:   Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel port: d000 bus-ID: 03:00.0
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: ASUSTeK driver: rtw_8822be v: N/A
modules: rtw88_8822be port: c000 bus-ID: 04:00.0 chip-ID: 10ec:b822 class-ID: 0280
Bluetooth: Device-1: ASUSTek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-12:5 chip-ID: 0b05:185c class-ID: e001
Drives:    Local Storage: total: 9.33 TiB used: 1.76 TiB (18.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WDS256G1X0C-00ENX0 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: B35900WD temp: 47.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3000DM001-1ER166 size: 2.73 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC45 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DM000-1F2168 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5900 serial: <filter> rev: CC52 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 1B6Q scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 vendor: Western Digital model: WD20EARX-00PASB0 size: 1.82 TiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: AB51 scheme: GPT
Partition: ID-1: / raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 37.78 GiB (15.9%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 562 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 37.78 GiB (15.9%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-4: /var/log raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 37.78 GiB (15.9%) fs: btrfs
ID-5: /var/tmp raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 37.78 GiB (15.9%) fs: btrfs
ID-1: swap-1 type: zram size: 15.53 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors:   System Temperatures: cpu: 37.9 C mobo: N/A gpu: amdgpu temp: 32.0 C mem: 36.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1260
Info:      Processes: 321 Uptime: 4h 47m wakeups: 0 Memory: 15.53 GiB used: 4.2 GiB (27.1%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1840 lib: 524 Shell: fish v: 3.3.1
default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
Even if you personally think it is unnecessary.
I think your problem is that Manjaro uses Pulse Audio.
You do not have Pulse Audio running on your machine.
Looks like you have pipewire installed.
