I have just updated system and I am having problem of UI getting hang for long time after I power on or reboot laptop, Dock and other Menus or apps are not visible and if it is visible it is not clickable.
Second issue is that UI elements are changed like latte dock and workspace switcher or window switching UI.
Check here to see if it helps:
How I should do that? I am new to the garuda linux as well as new to linux.
Click on the link to the thread above, and read it.
Okk. Thank you.
It seems not working.
What exactly have you done and how it is working?
Compositing has been disabled, try reinableing it.
