Hey there,
I have noticed a weird thing with garuda, where it's getting detected as ubuntu.
Now this is nothing new, I know, but the weird thing is, that next to grub now also snapper and even garuda chroot (kinda red flag) are detecting it as ubuntu - what is going on?
I can't remember to have changed anything regarding this.
How could this happen?
Thanks!
System: Kernel: 5.13.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=2a555427-5d35-463f-8011-b023a855b928 rw
rootflags=subvol=@ loglevel=3 quiet splash lsm=lockdown,yama,apparmor,bpf
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop System: Gigabyte product: AX370-Gaming 3 v: N/A serial: <filter>
Mobo: Gigabyte model: AX370-Gaming 3-CF v: x.x serial: <filter> UEFI-[Legacy]: American Megatrends v: F50a
date: 11/27/2019
CPU: Info: 6-Core model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 8 stepping: 2
microcode: 800820D cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 86226
Speed: 3243 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 3243 2: 3417 3: 4140 4: 3930 5: 4153
6: 4098 7: 4149 8: 4034 9: 3123 10: 3660 11: 4131 12: 4101
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Baffin [Radeon RX 550 640SP / RX 560/560X] vendor: ASUSTeK
driver: amdgpu v: kernel bus-ID: 08:00.0 chip-ID: 1002:67ff class-ID: 0300
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 3-4:4 chip-ID: 046d:0825
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting
Screen-1: 0 s-res: 3600x1200 s-dpi: 96 s-size: 952x317mm (37.5x12.5") s-diag: 1003mm (39.5")
Monitor-1: HDMI-A-0 res: 1680x1050 hz: 60 dpi: 90 size: 474x296mm (18.7x11.7") diag: 559mm (22")
Monitor-2: DVI-D-0 res: 1920x1200 hz: 60 dpi: 99 size: 495x310mm (19.5x12.2") diag: 584mm (23")
OpenGL: renderer: Radeon RX 560 Series (POLARIS11 DRM 3.41.0 5.13.13-zen1-1-zen LLVM 12.0.1) v: 4.6 Mesa 21.2.1
direct render: Yes
Audio: Device-1: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X] vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 08:00.1 chip-ID: 1002:aae0 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: C-Media USB Microphone type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2:3
chip-ID: 0d8c:9700 class-ID: 0300 serial: <filter>
Device-4: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 3-4:4 chip-ID: 046d:0825
Sound Server-1: ALSA v: k5.13.13-zen1-1-zen running: yes
Sound Server-5: PipeWire v: 0.3.35 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel
port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Drives: Local Storage: total: 2.96 TiB used: 985.52 GiB (32.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD20EFRX-68EUZN0 size: 1.82 TiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 0A82 scheme: GPT
Partition: ID-1: / raw-size: 195.31 GiB size: 195.31 GiB (100.00%) used: 52.09 GiB (26.7%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-2: /home raw-size: 736.18 GiB size: 736.18 GiB (100.00%) used: 87.98 GiB (12.0%) fs: btrfs dev: /dev/sda3
maj-min: 8:3
ID-3: /var/log raw-size: 195.31 GiB size: 195.31 GiB (100.00%) used: 52.09 GiB (26.7%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-4: /var/tmp raw-size: 195.31 GiB size: 195.31 GiB (100.00%) used: 52.09 GiB (26.7%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-1: swap-1 type: zram size: 31.3 GiB used: 407.8 MiB (1.3%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 49.8 C mobo: N/A gpu: amdgpu temp: 50.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1443
Info: Processes: 445 Uptime: 3h 47m wakeups: 0 Memory: 31.3 GiB used: 8.46 GiB (27.0%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 2086 apt: 0 pacman: 2080 lib: 468 snap: 6
Shell: fish v: 3.3.1 running-in: yakuake inxi: 3.3.06
I love this template, it tells you everything
