Carrot inxi -Faz
# System:    Kernel: 5.15.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=9defb73e-3680-499e-89ec-10d7b12843a5
rw [email protected] quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
systemd.unified_cgroup_hierarchy=1 amdgpu.ppfeaturemask=0xffffffff
resume=UUID=922b6371-e6a5-4c9a-beae-5a05f7ce4b41 loglevel=3
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine:   Type: Desktop Mobo: Gigabyte model: B450M S2H v: x.x serial: <filter> UEFI: American Megatrends
v: F50 date: 11/27/2019
CPU:       Info: Quad Core model: AMD Ryzen 3 3100 bits: 64 type: MT MCP arch: Zen 2 family: 17 (23)
model-id: 71 (113) stepping: 0 microcode: 8701013 cache: L2: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 57491
Speed: 2123 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 2123 2: 2263
3: 2698 4: 2107 5: 2161 6: 2257 7: 2365 8: 2051
mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics:  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] vendor: Sapphire Limited
driver: amdgpu v: kernel bus-ID: 0a:00.0 chip-ID: 1002:67df class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: amdgpu,ati
Monitor-1: HDMI-A-1 res: 1920x1080 hz: 75 dpi: 102 size: 480x270mm (18.9x10.6")
diag: 551mm (21.7")
OpenGL: renderer: AMD Radeon RX 570 Series (POLARIS10 DRM 3.42.0 5.15.2-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Audio:     Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: Sapphire Limited
driver: snd_hda_intel v: kernel bus-ID: 0a:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
Device-3: JMTek LLC. FANTECH CAPTAIN 7.1 type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 3-1:2 chip-ID: 0c76:16cb class-ID: 0300
Sound Server-1: ALSA v: k5.15.2-zen1-1-zen running: yes
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169
v: kernel port: f000 bus-ID: 09:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp9s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB driver: btusb v: 0.8
bus-ID: 1-4.1:3 chip-ID: 0a12:0001 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
hardware: no software: no address: <filter>
Drives:    Local Storage: total: 1.14 TiB used: 512.09 GiB (43.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX6000PNP size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
rev: V9002s34 temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
serial: <filter> rev: CC43 scheme: GPT
Partition: ID-1: / raw-size: 221.05 GiB size: 221.05 GiB (100.00%) used: 74.15 GiB (33.5%) fs: btrfs
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 221.05 GiB size: 221.05 GiB (100.00%) used: 74.15 GiB (33.5%) fs: btrfs
ID-4: /var/log raw-size: 221.05 GiB size: 221.05 GiB (100.00%) used: 74.15 GiB (33.5%)
ID-5: /var/tmp raw-size: 221.05 GiB size: 221.05 GiB (100.00%) used: 74.15 GiB (33.5%)
ID-1: swap-1 type: partition size: 17.13 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 15.63 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors:   System Temperatures: cpu: 16.8 C mobo: N/A gpu: amdgpu temp: 43.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1790
Info:      Processes: 324 Uptime: 1h 9m wakeups: 0 Memory: 15.63 GiB used: 2.97 GiB (19.0%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1876 lib: 518
flatpak: 0 Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.08
