Hello everyone,
i'm trying to update my system, but the new version of obs prevent me to update because obs-studio-browser and libva-vdpau-driver are in conflict. I could update the system before this. I tried to remove the package in question, but it's installed by 'garuda-video-linux-config'. What should i do?
This is the update command
[[email protected] ~]$ update
:: Sincronizzazione dei database in corso...
garuda è aggiornato
core è aggiornato
extra è aggiornato
community è aggiornato
multilib è aggiornato
chaotic-aur 2,2 MiB 2,16 MiB/s 00:01 [---------------------------------------] 100%
--> Refreshing mirrorlists using rate-mirrors, please be patient..
download di garuda in corso...
download di core in corso...
download di extra in corso...
download di community in corso...
download di multilib in corso...
download di chaotic-aur in corso...
spawn pacman -Su
warning: ttf-google-fonts-git: ignoring package upgrade (1:r4587.c048e845b-1 => 1:r4588.160934bd0-1)
resolving dependencies...
:: obs-studio-browser and libva-vdpau-driver are in conflict. Remove libva-vdpau-driver? [y/N]
n
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
and here is garuda-inxi
Kernel: 6.1.5-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=0eb95736-e32e-43e8-be85-1f050b5d32b6 rw [email protected]
quiet resume=UUID=4594523c-24c5-451b-8620-1ebd681f5b2e loglevel=3
pcie_aspm=off ibt=off
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: X541UV v: 1.0
Mobo: ASUSTeK model: X541UV v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X541UV.309 date: 04/17/2019
ID-1: BAT0 charge: 28.2 Wh (98.9%) condition: 28.5/34.6 Wh (82.4%)
volts: 10.8 min: 10.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 342
Info: model: Intel Core i5-6198DU bits: 64 type: MT MCP arch: Skylake
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2588 high: 2800 min/max: 400/2800 scaling:
driver: intel_pstate governor: performance cores: 1: 2754 2: 2800 3: 2400
4: 2400 bogomips: 19200
Device-1: Intel HD Graphics 510 vendor: ASUSTeK driver: i915 v: kernel
arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: HDMI-A-2
off: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1906
Device-2: NVIDIA GM108M [GeForce 920MX] vendor: ASUSTeK driver: nvidia
v: 525.78.01 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:134f
class-ID: 0302
Device-3: Chicony USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 04f2:b52b class-ID: 0e02 serial: <filter>
compositor: kwin_x11 driver: X: loaded: intel,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: i965 gpu: i915
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (19.96x11.22")
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-2 mapped: HDMI2 pos: primary model: Acer VG240Y
serial: <filter> built: 2021 res: 1920x1080 hz: 75 dpi: 92 gamma: 1.2
size: 530x300mm (20.87x11.81") diag: 604mm (23.8") ratio: 16:9 modes:
Monitor-2: eDP-1 mapped: eDP1 note: disabled model: ChiMei InnoLux 0x15ca
built: 2014 res: 1920x1080 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: Mesa Intel HD Graphics 510 (SKL
GT1) direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel bus-ID: 1-2.3:6 v: kernel chip-ID: 046d:0adf
alternate: snd_soc_skl,snd_soc_avs class-ID: 0300 bus-ID: 00:1f.3
chip-ID: 8086:9d70 serial: <filter> class-ID: 0403
Device-2: Logitech G435 Wireless Gaming Headset type: USB
Sound API: ALSA v: k6.1.5-zen2-1-zen running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 02:00.2 chip-ID: 10ec:8136 class-ID: 0200
IF: enp2s0f2 state: down mac: <filter>
Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Lite-On
driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 168c:0032 class-ID: 0280
Local Storage: total: 1.36 TiB used: 611.42 GiB (43.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
type: SSD serial: <filter> rev: 023 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HTS545050B9A300
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: C64G scheme: GPT
ID-1: / raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
used: 520.68 GiB (56.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
ID-4: /var/log raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
ID-5: /var/tmp raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.63 GiB used: 897 MiB (11.5%) priority: 100
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 49.0 C pch: 38.5 C mobo: N/A
Fan Speeds (RPM): cpu: 2300
Processes: 237 Uptime: 5h 33m wakeups: 21 Memory: 7.63 GiB
used: 3.16 GiB (41.5%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 alt: 11 clang: 14.0.6 Packages:
pm: dpkg pkgs: 0 pm: pacman pkgs: 1747 libs: 529 tools: pamac pm: flatpak
pkgs: 0 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2022-11-20
Last full system update: 2023-01-14 ↻
Is partially upgraded: Yes
