Can't mount BTRFS partition
My /home partition won’t mount anymore. I reinstalled the system, so I now have /home on the same partition as /, but I can’t access any of the files on my old /home. When I try to mount it, I get this error:
mount: /run/media/zedmost/myhome: mount(2) system call failed: No such file or directory.
dmesg(1) may have more information after failed mount system call.
When I run dmesg, I get this.
Here’s my garuda-inxi:
Kernel: 6.7.0-zen3-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=55d59fa2-02fd-42ce-9ed8-f00efdb9061b rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_wayland vt: 1
Mobo: ASUSTeK model: ROG STRIX B550-A GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2604
date: 02/25/2022
Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 614 high: 2977 min/max: 400/4464 scaling:
4: 400 5: 400 6: 2977 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400
bogomips: 93420
link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1 empty: DP-1
bus-ID: 0a:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 32.0 C
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.3-arch1.1
renoir LLVM 16.0.6 DRM 3.56 6.7.0-zen3-1-zen) device-ID: 1002:1638
API: Vulkan v: 1.3.274 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 23.3.3-arch1.1
device-ID: 1002:1638 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 23.3.3-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
Device-1: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 0a:00.1 chip-ID: 1002:1637
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 0a:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.7.0-zen3-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 08:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7.2:8 chip-ID: 8087:0029
Report: btmgmt ID: hci0 rfk-id: 3 state: up address: <filter> bt-v: 5.2
Local Storage: total: 3.23 TiB used: 793.61 GiB (24.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SKC3000D2048G
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 20.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3500630NS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: N/A serial: <filter> fw-rev: 3CNR scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM003-1CH162
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC47 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Kingston model: DataTraveler 2.0
size: 3.84 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: PMAP
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 10.09 GiB (10.1%)
ID-3: /home raw-size: 100 GiB size: 100 GiB (100.00%)
used: 10.09 GiB (10.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
ID-1: swap-1 type: zram size: 14.91 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 36.6 C mobo: N/A gpu: amdgpu temp: 33.0 C
Processes: 335 Uptime: 4h 39m wakeups: 1 Memory: total: 16 GiB note: est.
available: 14.91 GiB used: 5.29 GiB (35.5%) Init: systemd v: 255
pm: pacman pkgs: 1208 libs: 356 tools: octopi,paru Shell: fish v: 3.7.0
running-in: yakuake inxi: 3.3.31
Garuda (2.6.22-1):
System install date:     2024-01-20
Last full system update: 2024-01-23
I’d like to get my files back, if possible. What’s the best path I can take? This is the first time I’ve ever had to deal with this on Linux, and I’m pretty new to btrfs as well. I tried running btrfs restore with the --dry-run option to see if there were any files I could recover that way, but there was no response. I’m guessing the options I have left are btrfs check and btrfs rescue?
First try is to restore a snapshot from grub.
Check
lsblk -f
Use live ISO chroot, if you install new I think ~/ is empty, try testdisk if you can restore youre files, do not use the new system.
I tried a couple of snapshots from when the system was working, but it still wouldn’t mount. I guess my old snapshots are gone now that I re-installed? I thought that it only made snapshots for the system partition, though, and this is a separate partition.
What is your method for mounting it? Post the exact command into the thread.
:point_up_2: Let’s take a look.
As @SGS already mentioned, if you need to recover files from an inaccessible partition it is best to never use that drive at all.
Use testdisk to try and recover your files from the inaccessible drive/partition. Copy any recovered files to a completely separate drive, (not a different partition). Continuing to use a drive you need to recover files from is only going to make it harder (or impossible) to recover the files you want.
