hiho,
after being in Standby my PC showed me a strange error msg in Fullscreen.. i shall press shift-strg f2, and enter loginctl unlock-session to fix my problem. After i rebooted my System booted to SDDM and stuck there, i can´t login with my password. I tried root (which worked), and also a test user worked as intended. I tryed the command in admin mode but nothing changed, also using a older snapshot didn´t work. Any Ideas how i can rescue my Account?
heres my inxi data..
Kernel: 6.1.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=2f16b873-cb2f-47c8-a98a-8dd51d19c048 rw [email protected]
resume=UUID=b4bcb446-90a0-4a25-a72b-5c6e4313dcb4 loglevel=3 ibt=off
Type: Desktop Mobo: Micro-Star model: MAG B550 TOMAHAWK (MS-7C91) v: 2.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.B1
date: 08/02/2022
Info: model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000D
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3749 high: 3800 min/max: 1400/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3800 2: 3800
3: 3800 4: 2994 5: 3800 6: 3800 7: 3800 8: 3800 9: 3800 10: 3800 11: 3800
12: 3800 13: 3800 14: 3800 15: 3800 16: 3800 bogomips: 121368
driver: amdgpu v: kernel arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm)
built: 2018-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: DP-1,HDMI-A-1 empty: DP-2 bus-ID: 30:00.0
chip-ID: 1002:1638 class-ID: 0300 temp: 31.0 C
Device-2: Sunplus Innovation Live Camera type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-1.4:4 chip-ID: 1bcf:2284
s-diag: 1052mm (41.43")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: right model: BenQ V2200Eco
serial: <filter> built: 2010 res: 1920x1080 dpi: 102 gamma: 1.2
size: 477x268mm (18.78x10.55") diag: 546mm (21.5") ratio: 16:9 modes:
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left model: AOC 22V2WG5
serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 476x268mm (18.74x10.55") diag: 546mm (21.5") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.49 6.1.7-zen1-1-zen) direct render: Yes
v: kernel pcie: bus-ID: 3-1.4:4 chip-ID: 1bcf:2284 gen: 3 class-ID: 0102
speed: 8 GT/s lanes: 16 serial: <filter> link-max: gen: 4 speed: 16 GT/s
bus-ID: 30:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 30:00.6 chip-ID: 1022:15e3
Device-3: Sunplus Innovation Live Camera type: USB
Sound API: ALSA v: k6.1.7-zen1-1-zen running: yes
lanes: 1 port: e000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 2a:00.0
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-2ef777660ffa state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: br-8597e3665ab8 state: down mac: <filter>
IF-ID-3: br-fbd8f9ca0e8f state: down mac: <filter>
IF-ID-4: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-5: vethb8d20f2 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-6: vethe842155 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Local Storage: total: 20.01 TiB used: 7.16 TiB (35.8%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung
rev: 3B2QEXM7 temp: 29.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
rev: 3B2QEXM7 temp: 26.9 C scheme: GPT
model: WD60EZAZ-00SF3B0 size: 5.46 TiB block-size: physical: 4096 B
rev: 0A80 scheme: GPT
model: WD20EFRX-68EUZN0 size: 1.82 TiB block-size: physical: 4096 B
rev: 0A82 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD60EFZX-68B3FN0 size: 5.46 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5640 serial: <filter>
rev: 0A81 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Western Digital
ID-1: / raw-size: 901.18 GiB size: 901.18 GiB (100.00%)
used: 383.07 GiB (42.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 901.18 GiB size: 901.18 GiB (100.00%)
ID-4: /var/log raw-size: 901.18 GiB size: 901.18 GiB (100.00%)
ID-5: /var/tmp raw-size: 901.18 GiB size: 901.18 GiB (100.00%)
ID-1: swap-1 type: zram size: 58.75 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 30.03 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:5
System Temperatures: cpu: 36.4 C mobo: N/A gpu: amdgpu temp: 32.0 C
Processes: 440 Uptime: 1h 49m wakeups: 0 Memory: 58.75 GiB
used: 3.78 GiB (6.4%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1776
libs: 517 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash v: 5.1.16
Garuda (2.6.14-1):
System install date: 2022-10-15
Last full system update: 2023-01-22
