Hello Everyone
Tried searching this but couldn't find anything.
I get the following error trying to execute the qbittorrent appimage.
(AppRun.wrapped:11601): GLib-GIO-ERROR **: 14:29:50.038: No GSettings schemas are installed on the system
My first thought was to check octopi for GSettings and found some stuff, so I installed what I didn't already have installed and then restarted. Same problem trying to execute the appimage.
╭─daniel@daniel in ~/Applications as 🧙 took 4s
[🔴] × garuda-inxi
Kernel: 5.18.14-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=1b82abfc-261b-494c-8bcb-ae36dce8a491 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.25.3 tk: Qt v: 5.15.5 info: latte-dock
Type: Laptop System: Micro-Star product: GF65 Thin 10UE v: REV:1.0
Mobo: Micro-Star model: MS-16W2 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16W2IMS.105 date: 05/14/2021
ID-1: BAT1 charge: 30.6 Wh (99.0%) condition: 30.9/51.3 Wh (60.2%)
volts: 13.0 min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A
status: charging
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 built: 2020 process: Intel 14nm family: 6 model-id: 0xA5 (165)
stepping: 2 microcode: 0xF0
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4349 high: 4601 min/max: 800/5000 scaling:
driver: intel_pstate governor: performance cores: 1: 4190 2: 4601 3: 4589
4: 4400 5: 4600 6: 4593 7: 4282 8: 4565 9: 4233 10: 4347 11: 3259
12: 4535 bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: Micro-Star MSI driver: nvidia v: 515.57
alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
unloaded: nouveau alternate: fbdev,intel,nv,vesa gpu: i915 display-ID: :0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1521 built: 2020 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.4
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
Device-2: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
Sound Server-1: ALSA v: k5.18.14-zen1-1-zen running: yes
bus-ID: 1-14:2 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 1.38 TiB used: 79.07 GiB (5.6%)
model: 2210 MTFDHBA512QFD size: 476.94 GiB block-size: physical: 512 B
rev: P6MA001 temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk
model: SSD PLUS 1000GB size: 931.52 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> scheme: GPT
ID-1: / raw-size: 60.55 GiB size: 60.55 GiB (100.00%)
used: 18.63 GiB (30.8%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 29.7 MiB (30.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 60.55 GiB size: 60.55 GiB (100.00%)
ID-4: /var/log raw-size: 60.55 GiB size: 60.55 GiB (100.00%)
ID-5: /var/tmp raw-size: 60.55 GiB size: 60.55 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.45 GiB used: 1.8 MiB (0.0%)
System Temperatures: cpu: 68.0 C pch: 55.0 C mobo: N/A
Processes: 337 Uptime: 15m wakeups: 1 Memory: 15.45 GiB
used: 3.53 GiB (22.9%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 Packages: pacman: 1824 lib: 522
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
Garuda (2.6.5-1):
System install date: 2022-07-30
Last full system update: 2022-07-30
