Checking permissions, in problem NTFS partition, root has ownership. In the good NTFS partition, my user had the ownership.
How can my user get ownership of problem NTFS partition?
Are you still not finished with your ntfs-experiments?
Obviously not…
Finally get this nonsense out of your head.
That’s what ntfs2btrfs
is for. But I advise you against it. Plus you have no space to convert…
Buy an external drive and finally make a backup.
By mounting it in the terminal with write permission argument.
How, what and why - you can find it in Wild Wild Web, e.g. here:
https://www.kernel.org/doc/html/latest/filesystems/ntfs3.html
https://wiki.archlinux.org/title/NTFS
https://wiki.archlinux.org/title/NTFS-3G
https://man.archlinux.org/man/ntfs-3g.8
You caused the problems yourself. Have you already forgotten what I told you in your other topic?
Switch the volumes to a Linux file system (e.g. ext4 or btrfs) and you won’t have any problems anymore.
And if you want or have to work with NTFS:
btw: Try to break out of your existing logic
Thanks for your response.
The one volume with NTFS that had write permissions I delete, previously backup 200GB and I formatted in BTRFS ==> All good.
But, I have problems with the other NTFS partition that have 1.3TB. First of all, I want to make it write to my user, right now is write only to root. Can you help me on that, please? Or, if impossible, I will backup the disk and format in BTRFS.
The problem is that I have not the ownership in the 1.3TB NTFS disk.
Kernel: 6.8.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e38ee0d4-0c6f-4526-9adf-c7cf1a1f23b5 rw rootflags=subvol=@
Desktop: Cinnamon v: 6.0.4 tk: GTK v: 3.24.41 wm: Muffin v: 6.0.1 tools:
avail: cinnamon-screensaver,xautolock vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: LENOVO product: VIQYx v: INVALID
serial: <superuser required> Chassis: type: 10 v: INVALID
Mobo: LENOVO model: VIQY0Y1 v: 31900006WIN8 STD MBR IPG
serial: <superuser required> part-nu: LENOVO_BI_IDEAPAD
uuid: <superuser required> UEFI: LENOVO v: 74CN26WW(107T22)
date: 05/09/2013
ID-1: BAT1 charge: 42.4 Wh (100.0%) condition: 42.4/56.4 Wh (75.2%)
power: 655.4 W volts: 12.2 min: 10.8 model: LENOVO PABAS0241231 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i7-4700MQ bits: 64 type: MT MCP arch: Haswell
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3235 high: 3400 min/max: 800/3400 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3400 2: 3400 3: 3400
4: 3400 5: 3400 6: 2084 7: 3400 8: 3400 bogomips: 38310
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo
driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
active: VGA-1,eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:0416
Device-2: NVIDIA GK107M [GeForce GT 750M] vendor: Lenovo driver: nvidia
v: 470.239.06 alternate: nouveau,nvidia_drm non-free: series: 470.xx+
status: legacy-active (EOL~2024-09-xx) arch: Kepler code: GKxxx
process: TSMC 28nm built: 2012-2018 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:0fe4 class-ID: 0300
Device-3: Realtek Lenovo EasyCamera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 0bda:58b9
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa
dri: crocus gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 2966x900 s-dpi: 96 s-size: 784x238mm (30.87x9.37")
s-diag: 819mm (32.26")
Monitor-1: VGA-1 pos: left model: LG (GoldStar) 20EN33 serial: <filter>
built: 2013 res: 1600x900 hz: 60 dpi: 92 gamma: 1.2
size: 443x249mm (17.44x9.8") diag: 508mm (20") ratio: 16:9 modes:
max: 1600x900 min: 720x400
Monitor-2: eDP-1 pos: primary,right model: LG Display 0x033a built: 2011
res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
API: EGL v: 1.5 hw: drv: intel crocus drv: nvidia platforms: device: 0
drv: nvidia device: 2 drv: crocus device: 3 drv: swrast surfaceless:
drv: swrast x11: drv: crocus inactive: gbm,wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4600 (HSW
GT2) device-ID: 8086:0416 memory: 1.46 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel
HD Graphics 4600 (HSW GT2) driver: mesa intel v: 24.0.5-arch1.1
device-ID: 8086:0416 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce GT 750M driver: nvidia v: 470.239.06
device-ID: 10de:0fe4 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
Device-3: NVIDIA GK107 HDMI Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
Device-4: Kingston HyperX QuadCast
lanes: 1 mode: 1.1 bus-ID: 3-4.4.2:9 chip-ID: 0951:16df class-ID: 0300
API: ALSA v: k6.8.7-zen1-1-zen status: kernel-api tools: N/A
Device-1: Qualcomm Atheros QCA8171 Gigabit Ethernet vendor: Lenovo
driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
bus-ID: 08:00.0 chip-ID: 1969:10a1 class-ID: 0200
Device-2: Broadcom BCM4352 802.11ac Dual Band Wireless Network Adapter
vendor: Lenovo driver: wl v: kernel modules: bcma pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 09:00.0 chip-ID: 14e4:43b1 class-ID: 0280
IF: wlp9s0 state: down mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4.2:6
Report: btmgmt ID: hci1 rfk-id: 3 state: up address: <filter> bt-v: 4.0
lmp-v: 6 status: discoverable: no pairing: no class-ID: 6c010c
Device-2: Lite-On BCM20702A0 driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-7:5 chip-ID: 04ca:200b
Report: ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.0 lmp-v: 6
Local Storage: total: 2.27 TiB used: 1.43 TiB (63.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT2000MX500SSD1
ID-1: / raw-size: 100.42 GiB size: 100.42 GiB (100.00%)
used: 24.54 GiB (24.4%) fs: btrfs dev: /dev/sdb4 maj-min: 8:20
ID-2: /boot/efi raw-size: 1.86 GiB size: 1.86 GiB (99.80%)
used: 584 KiB (0.0%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 309.96 GiB size: 309.96 GiB (100.00%)
used: 149.59 GiB (48.3%) fs: btrfs dev: /dev/sdb5 maj-min: 8:21
ID-4: /var/log raw-size: 100.42 GiB size: 100.42 GiB (100.00%)
ID-5: /var/tmp raw-size: 100.42 GiB size: 100.42 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.35 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 20.12 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 66.0 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.35 GiB used: 5.26 GiB (34.3%)
Processes: 336 Power: uptime: 16m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.11 GiB services: csd-power,upowerd
Packages: pm: pacman pkgs: 1430 libs: 412 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1
running-in: gnome-terminal inxi: 3.3.34
System install date: 2024-02-04
Last full system update: 2024-04-20
We know that.
There have already been many tips on how to solve this problem.
Start reading and search for yourself too, please.
This thread has already been solved, so I’ve closed it.
