Cannot connect to wifi network
inxi
  Kernel: 5.19.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
    root=UUID=21c7fde8-1bef-4f82-abc8-364dad2d6848 rw [email protected]
    resume=UUID=59131e58-a432-49f0-bae1-aebf3325230e loglevel=3 ibt=off
  Type: Laptop System: HP product: OMEN by HP Laptop 15-dc1xxx v: N/A
  Mobo: HP model: 8574 v: 21.17 serial: <superuser required> UEFI: AMI
    v: F.22 date: 05/03/2021
  ID-1: BAT0 charge: 45.8 Wh (100.0%) condition: 45.8/45.8 Wh (100.0%)
    volts: 17.4 min: 15.4 model: HP Primary type: Li-ion serial: N/A
    status: full
    gen: core 9 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
    stepping: 0xD (13) microcode: 0xF0
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 1850 high: 2600 min/max: 800/4500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1100 2: 2600 3: 2600
    4: 1100 5: 1101 6: 2600 7: 1100 8: 1100 9: 2600 10: 2600 11: 2600
    12: 1100 bogomips: 62399
  Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Hewlett-Packard
    driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-07) arch: Turing code: TUxxx
    process: TSMC 12nm built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
    link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:1f11 class-ID: 0300
  Device-2: Lite-On HP Wide Vision HD Camera type: USB driver: uvcvideo
    bus-ID: 1-6:3 chip-ID: 04ca:707f class-ID: 0e02 serial: <filter>
    compositors: 1: kwin_x11 2: Tabby driver: X: loaded: nvidia gpu: nvidia
  Screen-1: 0 s-res: 1920x1080 s-dpi: 143 s-size: 341x191mm (13.43x7.52")
    s-diag: 391mm (15.39")
  Monitor-1: DP-2 res: 1920x1080 hz: 60 dpi: 142
  OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA
    515.65.01 direct render: Yes
  Device-2: NVIDIA TU106 High Definition Audio vendor: Hewlett-Packard
    link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
  Sound Server-1: ALSA v: k5.19.2-zen1-1-zen running: yes
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 3c:00.0 chip-ID: 10ec:8168
    speed: 5 GT/s lanes: 1 bus-ID: 3d:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF-ID-1: br-da2c536dbf10 state: down mac: <filter>
  IF-ID-3: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
    bus-ID: 1-7:4 chip-ID: 8087:0029 class-ID: e001
    v: 3.0 port: 5020 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
    class-ID: 0104
  Local Storage: total: 1.84 TiB used: 62.46 GiB (3.3%)
    model: MZVLB1T0HBLR-000H1 size: 953.87 GiB block-size: physical: 512 B
    rev: HPS0NEXF temp: 45.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
  ID-1: / raw-size: 896.9 GiB size: 896.9 GiB (100.00%) used: 62.46 GiB
    (7.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 563 KiB
  ID-3: /home raw-size: 896.9 GiB size: 896.9 GiB (100.00%) used: 62.46 GiB
  ID-4: /var/log raw-size: 896.9 GiB size: 896.9 GiB (100.00%) used: 62.46
    GiB (7.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
  ID-5: /var/tmp raw-size: 896.9 GiB size: 896.9 GiB (100.00%) used: 62.46
  ID-1: swap-1 type: zram size: 31.23 GiB used: 0 KiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 34.36 GiB used: 0 KiB (0.0%)
  System Temperatures: cpu: 83.0 C pch: 54.0 C mobo: N/A gpu: nvidia
    temp: 55 C
  Fan Speeds (RPM): cpu: 2393 fan-2: 2207
  Processes: 338 Uptime: 4m wakeups: 1 Memory: 31.23 GiB used: 4.03 GiB
  (12.9%) Init: systemd v: 251 default: graphical tool: systemctl
  Compilers: gcc: 12.1.1 Packages: pacman: 1687 lib: 498 Shell: fish v: 3.5.1
  running-in: tabby inxi: 3.3.20
Garuda (2.6.6-1):
  System install date:     2021-07-24
  Last full system update: 2022-08-20
  Relevant software:       tlp NetworkManager
  Snapshots:               Timeshift (maybe)
Hello community,
I have problems connecting to previously used wifi network. After changing authentication method on my router - was previously WPA2/3-EAP to only WPA2/3 - NetworkManager gets stuck on "Configuring interface" and never connects. I've tried removing the connection altogether from NM and reentering the password without success. I can connect to other SSIDs broadcasted by the router and previously never used just fine. There is no issue in the router (Mikrotik), logs show nothing and other devices can connect w/o problems. There is also no IP conflict, I've reseted the routers DHCP leases, also without success.
Any help in this matter would be greatly appreciated.
Thanks in advance!
Have you tried reverting this change?
Nope.
It was just a test in my homelab. Because the router has NAND memory there is a risk of destroying it with constant writes into it - and using EAP registers sessions IDs and everything into it.
Everything else works fine - other SSID which is using exactly the same authentication method / only different password works w/o problems.
Is there any way to reset NetworkManager completely? I suspect deleting the connection wasn't enough for some reason.
Then how do you know that was the cause?
Yesterday before I turned off my system it was working w/o problem when it was connected via old WPA2/3-EAP. Then from another computer I've changed security to WPA2/3. Today I can't connect to that SSID, but I can connect to other SSIDs that are broadcasted by my router. Only that one which was set to EAP won't work.
However I can connect to that SSID which had EAP and now has only WPA2/3 from another computer just fine, from my phone, from my smart TV, so I know the problem is not in the rouer.
This is the output of journalctl
srp 24 15:47:44 mikoshi NetworkManager[793]: <info>  [1661348864.9206] device (wlo1): Activation: (wifi) connection '☢ Lord Voldemodem ☢' has security, and secrets exist.  No new secrets needed.
srp 24 15:47:44 mikoshi NetworkManager[793]: <info>  [1661348864.9207] Config: added 'ssid' value '☢ Lord Voldemodem ☢'
srp 24 15:47:44 mikoshi NetworkManager[793]: <info>  [1661348864.9207] Config: added 'scan_ssid' value '1'
srp 24 15:47:44 mikoshi NetworkManager[793]: <info>  [1661348864.9207] Config: added 'bgscan' value 'simple:30:-70:86400'
srp 24 15:47:44 mikoshi NetworkManager[793]: <info>  [1661348864.9207] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
srp 24 15:47:44 mikoshi NetworkManager[793]: <info>  [1661348864.9207] Config: added 'auth_alg' value 'OPEN'
srp 24 15:47:44 mikoshi NetworkManager[793]: <info>  [1661348864.9207] Config: added 'psk' value '<hidden>'
srp 24 15:47:44 mikoshi NetworkManager[793]: <info>  [1661348864.9500] device (wlo1): supplicant interface state: disconnected -> scanning
srp 24 15:47:44 mikoshi NetworkManager[793]: <info>  [1661348864.9501] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> scanning
srp 24 15:47:46 mikoshi NetworkManager[793]: <info>  [1661348866.4986] device (wlo1): supplicant interface state: scanning -> authenticating
srp 24 15:47:46 mikoshi NetworkManager[793]: <info>  [1661348866.4987] device (p2p-dev-wlo1): supplicant management interface state: scanning -> authenticating
srp 24 15:47:48 mikoshi NetworkManager[793]: <info>  [1661348868.7133] device (wlo1): supplicant interface state: authenticating -> associating
srp 24 15:47:48 mikoshi NetworkManager[793]: <info>  [1661348868.7134] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> associating
srp 24 15:47:48 mikoshi NetworkManager[793]: <info>  [1661348868.7508] device (wlo1): supplicant interface state: associating -> associated
srp 24 15:47:48 mikoshi NetworkManager[793]: <info>  [1661348868.7508] device (p2p-dev-wlo1): supplicant management interface state: associating -> associated
srp 24 15:47:48 mikoshi NetworkManager[793]: <info>  [1661348868.8295] device (wlo1): supplicant interface state: associated -> 4way_handshake
srp 24 15:47:48 mikoshi NetworkManager[793]: <info>  [1661348868.8295] device (p2p-dev-wlo1): supplicant management interface state: associated -> 4way_handshake
srp 24 15:47:48 mikoshi NetworkManager[793]: <info>  [1661348868.8732] device (wlo1): supplicant interface state: 4way_handshake -> completed
srp 24 15:47:48 mikoshi NetworkManager[793]: <info>  [1661348868.8733] device (wlo1): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "☢ Lord Voldemodem ☢"
srp 24 15:47:48 mikoshi NetworkManager[793]: <info>  [1661348868.8733] device (p2p-dev-wlo1): supplicant management interface state: 4way_handshake -> completed
srp 24 15:47:48 mikoshi NetworkManager[793]: <info>  [1661348868.8733] device (wlo1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
srp 24 15:47:48 mikoshi NetworkManager[793]: <info>  [1661348868.8736] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
srp 24 15:47:48 mikoshi NetworkManager[793]: <info>  [1661348868.9066] dhcp4 (wlo1): state changed new lease, address=10.100.10.116
srp 24 15:47:48 mikoshi NetworkManager[793]: <info>  [1661348868.9069] policy: set '☢ Lord Voldemodem ☢' (wlo1) as default for IPv4 routing and DNS
srp 24 15:47:48 mikoshi NetworkManager[793]: <info>  [1661348868.9156] device (wlo1): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
srp 24 15:47:48 mikoshi NetworkManager[793]: <info>  [1661348868.9173] device (wlo1): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
srp 24 15:47:48 mikoshi NetworkManager[793]: <info>  [1661348868.9175] device (wlo1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
srp 24 15:47:48 mikoshi NetworkManager[793]: <info>  [1661348868.9178] manager: NetworkManager state is now CONNECTED_SITE
srp 24 15:47:48 mikoshi NetworkManager[793]: <info>  [1661348868.9194] device (wlo1): Activation: successful, device activated.
srp 24 15:47:49 mikoshi NetworkManager[793]: <info>  [1661348869.0241] manager: NetworkManager state is now CONNECTED_GLOBAL
srp 24 15:48:17 mikoshi NetworkManager[793]: <info>  [1661348897.8861] audit: op="connection-delete" uuid="27a01034-1de1-43bd-a6e5-3815479ae18a" name="🔒 Voldemodem - Private" pid=3488 uid=1000 result="fail" reason="Error checking aut>
srp 24 15:48:17 mikoshi NetworkManager[793]: <info>  [1661348897.8862] audit: op="connection-delete" uuid="27a01034-1de1-43bd-a6e5-3815479ae18a" name="🔒 Voldemodem - Private" pid=3488 uid=1000 result="success"
srp 24 15:50:19 mikoshi NetworkManager[793]: <info>  [1661349019.0982] audit: op="statistics" interface="wlo1" ifindex=3 args="2000" pid=2327 uid=1000 result="success"
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.8395] device (wlo1): disconnecting for new activation request.
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.8395] device (wlo1): state change: activated -> deactivating (reason 'new-activation', sys-iface-state: 'managed')
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.8401] audit: op="connection-add-activate" uuid="8f3174de-1488-4dff-9bab-dad3802e6bd9" name="🔒 Voldemodem - Private" pid=2327 uid=1000 result="success"
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.8581] audit: op="statistics" interface="br-da2c536dbf10" ifindex=5 args="0" pid=2327 uid=1000 result="success"
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9285] device (wlo1): state change: deactivating -> disconnected (reason 'new-activation', sys-iface-state: 'managed')
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9412] dhcp4 (wlo1): canceled DHCP transaction
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9413] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9413] dhcp4 (wlo1): state changed no lease
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9522] device (wlo1): set-hw-addr: set MAC address to CA:21:46:E4:75:A4 (scanning)
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9596] device (wlo1): Activation: starting connection '🔒 Voldemodem - Private' (8f3174de-1488-4dff-9bab-dad3802e6bd9)
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9606] device (wlo1): supplicant interface state: completed -> disconnected
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9607] device (p2p-dev-wlo1): supplicant management interface state: completed -> disconnected
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9620] device (wlo1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9626] manager: NetworkManager state is now CONNECTING
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9720] device (wlo1): set-hw-addr: reset MAC address to 60:F2:62:F2:EC:3E (preserve)
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9756] device (wlo1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9761] device (wlo1): Activation: (wifi) access point '🔒 Voldemodem - Private' has security, but secrets are required.
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9761] device (wlo1): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9777] device (wlo1): supplicant interface state: disconnected -> interface_disabled
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9778] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> interface_disabled
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9915] device (wlo1): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9921] device (wlo1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9926] device (wlo1): Activation: (wifi) connection '🔒 Voldemodem - Private' has security, and secrets exist.  No new secrets needed.
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9926] Config: added 'ssid' value '🔒 Voldemodem - Private'
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9927] Config: added 'scan_ssid' value '1'
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9927] Config: added 'bgscan' value 'simple:30:-70:86400'
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9927] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9927] Config: added 'auth_alg' value 'OPEN'
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9928] Config: added 'psk' value '<hidden>'
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9959] device (wlo1): supplicant interface state: interface_disabled -> disconnected
srp 24 15:50:27 mikoshi NetworkManager[793]: <info>  [1661349027.9960] device (p2p-dev-wlo1): supplicant management interface state: interface_disabled -> disconnected
srp 24 15:50:29 mikoshi NetworkManager[793]: <info>  [1661349029.0180] device (wlo1): supplicant interface state: disconnected -> scanning
srp 24 15:50:29 mikoshi NetworkManager[793]: <info>  [1661349029.0180] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> scanning
srp 24 15:50:29 mikoshi NetworkManager[793]: <info>  [1661349029.7379] device (wlo1): supplicant interface state: scanning -> authenticating
srp 24 15:50:29 mikoshi NetworkManager[793]: <info>  [1661349029.7380] device (p2p-dev-wlo1): supplicant management interface state: scanning -> authenticating
srp 24 15:50:41 mikoshi NetworkManager[793]: <info>  [1661349041.5663] device (wlo1): supplicant interface state: authenticating -> scanning
srp 24 15:50:41 mikoshi NetworkManager[793]: <info>  [1661349041.5664] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> scanning
srp 24 15:50:41 mikoshi NetworkManager[793]: <info>  [1661349041.5705] device (wlo1): supplicant interface state: scanning -> disconnected
srp 24 15:50:41 mikoshi NetworkManager[793]: <info>  [1661349041.5705] device (p2p-dev-wlo1): supplicant management interface state: scanning -> disconnected
srp 24 15:50:41 mikoshi NetworkManager[793]: <info>  [1661349041.6898] device (wlo1): supplicant interface state: disconnected -> authenticating
srp 24 15:50:41 mikoshi NetworkManager[793]: <info>  [1661349041.6898] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> authenticating
srp 24 15:50:46 mikoshi NetworkManager[793]: <info>  [1661349046.8528] device (wlo1): supplicant interface state: authenticating -> disconnected
srp 24 15:50:46 mikoshi NetworkManager[793]: <info>  [1661349046.8528] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> disconnected
There are no logs in the router.
That appears to be wrong.
Network Manager connection settings are stored under /etc/NetworkManager/system-connections , so if deleting that doesn't work it's not the connection settings with the problem.
Yea, I see that it tries to set this value even when I manually set WPA2-Personal in the NetworkManager.
What I do not understand is that the network security in the router is set up exactly the same on both SSIDs, only the passwords are different.
SSID with sec_home is working in Garuda and everywhere else. SSID with sec_private is working everywhere else, but not in Garuda.
Also thinking, it will be worth disabling WPA3 to see if that makes a difference. It might be that you were connecting using WPA2 previously without realising it?
Oh, sorry, forgot to write the solution here.
Yep, it was the SAE (WPA3). After turning it off, both networks started working correctly. I don't know where the issue came from, because in NetworkManager there was correctly selected WPA3-Personal.
However, because most of my IoT devices don't suporrt WPA3 (and some probably never will), disabling the WPA3 was not a problem for me.
Thanks!
