root=UUID=aff0fdd6-4400-4013-a778-7a951099c5b4 rw [email protected]
resume=UUID=51ade4f1-4b88-49c3-82bb-5651c48c852b loglevel=3
Desktop: sway v: 1.7 info: waybar vt: 1 dm: greetd Distro: Garuda Linux
Type: Desktop System: LENOVO product: 10AU00ESUS v: ThinkCentre E73
Mobo: LENOVO model: N/A v: SDK0E50510 WIN serial: <superuser required>
UEFI: LENOVO v: FCKT70AUS date: 04/23/2015
Device-1: hid-CC253620006G61CAB-battery model: Apple Inc. Magic Trackpad 2
serial: N/A charge: N/A status: discharging
Info: model: Intel Core i3-4150 bits: 64 type: MT MCP arch: Haswell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1537 high: 1935 min/max: 800/3500 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1935 2: 1267 3: 1330
4: 1616 bogomips: 27935
Device-1: Intel 4th Generation Core Processor Family Integrated Graphics
vendor: Lenovo driver: i915 v: kernel ports: active: VGA-1
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:041e class-ID: 0300
Display: wayland server: Xwayland v: 22.1.1 compositor: sway v: 1.7
driver: gpu: i915 display-ID: 1
Monitor-1: VGA-1 model: Dell E2215HV serial: <filter> built: 2014
res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2 scale: 1
size: 476x268mm (18.74x10.55") diag: 546mm (21.5") ratio: 16:9 modes:
Message: Wayland GBM/EGL data currently not available.
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
Sound Server-4: PipeWire v: 0.3.49 running: yes
vendor: Lenovo ThinkCentre E73 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168
Local Storage: total: 268.35 GiB used: 9.99 GiB (3.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Transcend model: TS256GSSD370
type: SSD serial: <filter> rev: 4B scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Samsung model: Flash Drive
size: 29.88 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 1100 scheme: MBR
ID-1: / raw-size: 229.93 GiB size: 229.93 GiB (100.00%)
used: 9.99 GiB (4.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 229.93 GiB size: 229.93 GiB (100.00%)
ID-4: /var/log raw-size: 229.93 GiB size: 229.93 GiB (100.00%)
ID-5: /var/tmp raw-size: 229.93 GiB size: 229.93 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.24 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 3.75 GiB used: 36.8 MiB (1.0%)
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 208 Uptime: 4h 12m wakeups: 2 Memory: 3.75 GiB
used: 2.03 GiB (54.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1157 lib: 300 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: alacritty inxi: 3.3.14
Garuda (2.5.6-2):
System install date: 2022-04-02
Last full system update: 2022-04-02 ↻
