Thanks for your reply review them and merge them hmm thanks ill research that info.
man alias
Ive installed meld from the AUR not sure how to run it from the terminal.
https://bin.garudalinux.org/?5737c179b9521277#BiJmmvN9prrNGheApYJyJqmGFsKMfz7X5TpA5hYzpBAC
==> pacnew file found for /etc/default/grub-btrfs/config
:: (V)iew, (S)kip, (R)emove pacnew, (O)verwrite with pacnew, (Q)uit: [v/s/r/o/q] o
You must use "v" not "o" for overwrite, did you read?
Thanks i did read it but i must have misread it v is view thought i was over writing thanks for clearing that up will try again
https://bin.garudalinux.org/?6c038eb34cdea707#Dd3DznFZjvqnATzV9zpKPBWEmqHSDvmpKMPgReZeKi4F
As the pacman output says "there is nothing to do" I think this thread has run its course.
