LANGUAGE = "",
LC_ALL = (unset),
LC_CTYPE = (unset),
LC_NUMERIC = "mk_MK.UTF-8",
LC_COLLATE = (unset),
LC_TIME = "mk_MK.UTF-8",
LC_MESSAGES = (unset),
LC_MONETARY = "mk_MK.UTF-8",
LC_ADDRESS = "mk_MK.UTF-8",
LC_IDENTIFICATION = "mk_MK.UTF-8",
LC_MEASUREMENT = "mk_MK.UTF-8",
LC_PAPER = "mk_MK.UTF-8",
LC_TELEPHONE = "mk_MK.UTF-8",
LC_NAME = "mk_MK.UTF-8",
LANG = "en_US.UTF-8"
perl: warning: Falling back to the standard locale ("C").
Kernel: 6.14.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=dc2e2e47-5bfd-4f22-964b-b559252f1a74 rw rootflags=subvol=@
Type: Laptop System: ASUSTeK product: K54C v: 1.0
Mobo: ASUSTeK model: K54C v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: K54C.210
date: 10/23/2012
ID-1: BAT0 charge: 12.9 Wh (100.0%) condition: 12.9/30.8 Wh (42.0%)
volts: 14.8 min: 14.4 model: ASUSTek K53--27 type: Li-ion serial: N/A
status: full
Info: model: Intel Pentium B950 bits: 64 type: MCP arch: Sandy Bridge
level: v2 built: 2010-12 process: Intel 32nm family: 6 model-id: 0x2A (42)
stepping: 7 microcode: 0x2F
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 smt: <unsupported> cache:
L3: 2 MiB desc: 1x2 MiB
Speed (MHz): avg: 1020 min/max: 800/2100 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 1020 2: 1020 bogomips: 8381
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
vendor: ASUSTeK driver: i915 v: kernel arch: Gen-6 code: Sandybridge
process: Intel 32nm built: 2011 ports: active: LVDS-1
empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0106
Device-2: Alcor Micro Asus Integrated Webcam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.2:4
chip-ID: 058f:a014 class-ID: 0e02
alternate: fbdev,intel,vesa dri: crocus gpu: i915 display-ID: 0
Monitor-1: LVDS-1 model: Seiko Epson 0x324a built: 2011 res:
mode: 1366x768 hz: 60 scale: 100% (1) dpi: 101 gamma: 1.2
modes: 1366x768
device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus wayland:
drv: crocus x11: drv: crocus
API: OpenGL v: 4.5 compat-v: 3.3 vendor: intel mesa v: 25.1.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 2000 (SNB
GT1) device-ID: 8086:0106 memory: 1.46 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 5 device: 0 type: cpu name: llvmpipe (LLVM
19.1.7 128 bits) driver: mesa llvmpipe v: 25.1.1-arch1.2 (LLVM 19.1.7)
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
API: ALSA v: k6.14.9-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.4.4 status: active with: 1: pipewire-pulse
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter vendor: Foxconn
driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 168c:002b class-ID: 0280
Device-2: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: ASUSTeK
driver: atl1c v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: a000
bus-ID: 04:00.0 chip-ID: 1969:1083 class-ID: 0200
Device-1: Qualcomm Atheros AR3011 Bluetooth driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.1:3
chip-ID: 0cf3:3005 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 3.0
lmp-v: 5 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 465.76 GiB used: 32.04 GiB (6.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS547550A9E384
tech: HDD rpm: 5400 serial: <filter> fw-rev: A60A scheme: GPT
ID-1: / raw-size: 50 GiB size: 50 GiB (100.00%) used: 17.26 GiB (34.5%)
fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-2: /boot/efi raw-size: 768 MiB size: 766.5 MiB (99.80%)
used: 19.7 MiB (2.6%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 50 GiB size: 50 GiB (100.00%)
used: 17.26 GiB (34.5%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-4: /var/log raw-size: 50 GiB size: 50 GiB (100.00%)
ID-5: /var/tmp raw-size: 50 GiB size: 50 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.65 GiB used: 31.7 MiB (0.4%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 2
ID-2: swap-2 type: partition size: 12 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 54.0 C mobo: N/A
Fan Speeds (rpm): cpu: 2500
Memory: total: 8 GiB available: 7.66 GiB used: 4.22 GiB (55.1%)
Processes: 206 Power: uptime: 2h 27m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.04 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1277 libs: 365 tools: octopi,paru Compilers:
inxi: 3.3.38
System install date: 2024-10-31
Last full system update: 2025-05-31
