Can not find my bluetooth mouse
I can not find my Bluetooth mouse on the dashboard of Bluetooth settings. I install bluez, bluez-utils, and blueman also config the file and comment-out (AutoEnable=true) but I can not find my Bluetooth mouse.
Can you provide your
As per the template
Here it is:
Kernel: 6.4.1-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=def7df17-4017-468b-ad13-0d6c7ce40761 rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Laptop System: HP product: HP Pavilion Laptop 15-cs3xxx
Mobo: HP model: 86AB v: 95.36 serial: <superuser required> UEFI: Insyde
v: F.16 date: 04/28/2022
ID-1: BAT0 charge: 41.6 Wh (100.0%) condition: 41.6/41.6 Wh (100.0%)
volts: 13.0 min: 11.4 model: HP Primary type: Li-ion serial: N/A
status: full
Info: model: Intel Core i5-1035G1 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xBA
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 1191 high: 1300 min/max: 400/3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 1200 2: 1200 3: 1200
4: 1300 5: 1200 6: 947 7: 1200 8: 1284 bogomips: 19046
Device-1: Intel Iris Plus Graphics G1 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21 ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a56
Device-2: Chicony HP Wide Vision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 04f2:b627
class-ID: 0e02
Monitor-1: eDP-1 model: AU Optronics 0x21ed built: 2018 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: Mesa Intel UHD Graphics (ICL GT1)
direct-render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
API: ALSA v: k6.4.1-zen2-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.72 status: active with: 1: pipewire-pulse
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
lanes: 1 port: 4000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:3
v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.14 TiB used: 24.38 GiB (2.1%)
fw-rev: 2B2QEXM7 temp: 42.9 C scheme: GPT
model: WD10SPZX-60Z10T0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A04 scheme: GPT
used: 19.54 GiB (8.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.3 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 62.0 C mobo: N/A
Processes: 276 Uptime: 24m wakeups: 1 Memory: available: 15.3 GiB
used: 3.76 GiB (24.6%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1378
libs: 347 tools: gnome-software,octopi,pamac,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27
System install date:     2023-07-04
Last full system update: 2023-07-05
