Hi,
The other day I tried garuda-update and afterwards my desktop completely froze. I was able to soft shutdown with my physical power button. At the sddm login screen, I cannot type and my mouse does not work. Tried all USB ports, either USB is dead or sddm is frozen.
I restored a snapshot with Snapper Tools from before the update, and everything returned to normal. Today I tried again, hoping there was some issue that would have been fixed quickly. No such luck, the exact same thing happened. I restored a snapshot again to get my system back.
So, it seems I can no longer update. Here is my garuda-inxi and the list of packages garuda-update wants to install. Maybe someone can tell me if there is something I can exclude in pacman.conf so this doesn’t happen?
Kernel: 6.11.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=e47b5a22-506c-4573-b60f-520b613f7533 rw rootflags=subvol=@
splash rd.udev.log_priority=3 loglevel=3 consoleblank=600
video=DP-2:640x480@60i amdgpu.ppfeaturemask=0xffffffff intel_iommu=on
iommu=pt vfio-pci.ids=10de:1d01,10de:0fb8 plymouth.enable=0
disablehooks=plymouth ibt=off
Desktop: KDE Plasma v: 6.2.0 tk: Qt v: N/A info: frameworks v: 6.6.0
wm: kwin_x11 tools: avail: xlock,xscreensaver vt: 2 dm: SDDM Distro: Garuda
Type: Desktop System: Gigabyte product: Z690 AERO D v: -CF
Mobo: Gigabyte model: Z690 AERO D serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F28
date: 12/14/2023
Info: model: 13th Gen Intel Core i7-13700K bits: 64 type: MST AMCP
microcode: 0x129
Topology: cpus: 1x dies: 1 clusters: 10 cores: 16 threads: 24 mt: 8 tpc: 2
st: 8 smt: enabled cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32
KiB, 8x64 KiB L2: 24 MiB desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 5300 min/max: 800/5300:5400:4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 5300 2: 5300 3: 5300
4: 5300 5: 5300 6: 5300 7: 5300 8: 5300 9: 5300 10: 5300 11: 5300 12: 5300
13: 5300 14: 5300 15: 5300 16: 5300 17: 5300 18: 5300 19: 5300 20: 5300
21: 5300 22: 5300 23: 5300 24: 5300 bogomips: 164044
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6950 XT]
vendor: XFX driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-1 off: DP-2 empty: DP-3,HDMI-A-1,Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:73a5 class-ID: 0300
Device-2: NVIDIA GP108 [GeForce GT 1030] vendor: Micro-Star MSI
driver: vfio-pci v: N/A alternate: nouveau non-free: 550.xx+ status: current
(as of 2024-09; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 04:00.0 chip-ID: 10de:1d01
Device-3: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.1:8
chip-ID: 1532:0e03 class-ID: 0102
Device-4: MacroSilicon USB Video
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.4:9 chip-ID: 534d:2109
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.3
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1015x571mm (39.96x22.48")
s-diag: 1165mm (45.85")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary model: Samsung
serial: <filter> built: 2021 res: 3840x2160 hz: 60 dpi: 52 gamma: 1.2
size: 1872x1053mm (73.7x41.46") diag: 801mm (31.5") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
Monitor-2: DP-2 mapped: DisplayPort-1 note: disabled model: DP2VGA V221
built: 2015 res: 3840x2160 dpi: 43 gamma: 1.2 size: 256x192mm (10.08x7.56")
diag: 690mm (27.2") ratio: 16:9 modes: max: 1024x768 min: 640x480
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6950 XT (radeonsi
navi21 LLVM 18.1.8 DRM 3.59 6.11.3-zen1-1-zen) device-ID: 1002:73a5
memory: 15.62 GiB unified: no
API: Vulkan v: 1.3.295 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6950 XT (RADV NAVI21) driver: mesa radv v: 24.2.4-arch1.1
device-ID: 1002:73a5 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.4-arch1.1 (LLVM
Device-2: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-3: NVIDIA GP108 High Definition Audio vendor: Micro-Star MSI
driver: vfio-pci alternate: snd_hda_intel pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s bus-ID: 04:00.1 chip-ID: 10de:0fb8
Device-4: Antlion Audio USB Microphone
lanes: 1 mode: 1.1 bus-ID: 1-12.1:18 chip-ID: 2f96:0200 class-ID: 0300
Device-5: PreSonus Audio AudioBox USB driver: snd-usb-audio type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12.3:21
chip-ID: 194f:0302 class-ID: 0103
Device-6: Giga-Byte USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2
chip-ID: 0414:a00b class-ID: 0300
Device-7: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
Device-8: MacroSilicon USB Video
Device-9: Emagic Soft- und Hardware GmbH Unitor8 driver: snd-usb-audio
type: USB rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8.4.2:23
chip-ID: 086a:0001 class-ID: ff00
API: ALSA v: k6.11.3-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
Device-2: Aquantia AQC113C NBase-T/IEEE 802.3an Ethernet [Marvell
Scalable mGig] vendor: Gigabyte driver: atlantic v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 2 port: N/A bus-ID: 09:00.0 chip-ID: 1d6a:14c0
class-ID: 0200 temp: 44.0 C
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0a:00.0
IF: enp10s0 state: down mac: <filter>
wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:20 chip-ID: 8087:0033
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.3
lmp-v: 12 sub-v: 3678 hci-v: 12 rev: 3678 class-ID: 6c0104
Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff
link-mode: peripheral accept service-classes: rendering, capturing, audio,
telephony
Local Storage: total: 16.61 TiB used: 2.61 TiB (15.7%)
model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 620331WD temp: 50.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731100WD temp: 55.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:3 vendor: Western Digital
fw-rev: 731100WD temp: 59.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD8SN8U-256G-1006
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0006 scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
ID-6: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DM008-2FR102
ID-7: /dev/sdd maj-min: 8:48 vendor: HGST (Hitachi) model: HUS724030ALE640
tech: HDD rpm: 7200 serial: <filter> fw-rev: A580 scheme: GPT
ID-8: /dev/sde maj-min: 8:64 vendor: HGST (Hitachi) model: HUS724040ALA640
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: AA70 scheme: GPT
ID-9: /dev/sdf maj-min: 8:80 vendor: HGST (Hitachi) model: HMS5C4040BLE640
tech: HDD rpm: 5700 serial: <filter> fw-rev: A5D0 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.51 TiB (83.3%)
used: 2.1 MiB (0.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 1.51 TiB (83.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.61 GiB used: 750.5 MiB (1.2%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 24
System Temperatures: cpu: 45.2 C mobo: N/A gpu: amdgpu temp: 47.0 C
mem: 50.0 C
Memory: total: 64 GiB note: est. available: 62.61 GiB used: 8.76 GiB (14.0%)
Processes: 578 Power: uptime: 8m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2597 libs: 634 tools: octopi,paru,yay pm: rpm
pkgs: 0 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.36
System install date: 2023-05-03
Last full system update: 2024-10-20
Packages (269) android-udev-20241019-1 apparmor-3.1.7-5 asciidoctor-2.0.23-3 attica-6.7.0-1 baloo-6.7.0-1 bind-9.20.3-1
blender-17:4.2.3-1 bluedevil-1:6.2.1-1 bluez-qt-6.7.0-1 bottles-2:51.15-1 breeze-6.2.1-1 breeze-icons-6.7.0-1
breeze5-6.2.1-1 cachyos-ananicy-rules-git-20241016.r437.g77e7534-1 chaotic-mirrorlist-20240724-1 clang-18.1.8-4
czkawka-gui-8.0.0-1 dkms-3.0.13-1 dxvk-mingw-git-2.4.1.r293.g4c0cbbef-1 electron-1:33-1 electron31-31.7.1-1
electron32-32.2.1-1 electron33-33.0.1-1 eza-0.20.4-1 falkon-24.08.2-2 firefox-131.0.3-1 firewalld-2.2.3-1
frameworkintegration-6.7.0-1 freecad-1.0rc2-3 fwupd-2.0.1-1 game-devices-udev-0.23-1 glib2-2.82.2-1
gnome-firmware-47.0-1 gvfs-1.56.1-1 gvfs-smb-1.56.1-1 gvim-9.1.0785-1 iana-etc-20241016-1
jdk-openjdk-23.0.1.u0-1 jdk17-openjdk-17.0.13.u11-1 kactivitymanagerd-6.2.1-1 karchive-6.7.0-1 kauth-6.7.0-1
kbookmarks-6.7.0-1 kcalendarcore-6.7.0-1 kcmutils-6.7.0-1 kcodecs-6.7.0-1 kcolorscheme-6.7.0-1
kcompletion-6.7.0-1 kconfig-6.7.0-1 kconfigwidgets-6.7.0-1 kcontacts-1:6.7.0-1 kcoreaddons-6.7.0-1
kcrash-6.7.0-1 kdav-1:6.7.0-1 kdbusaddons-6.7.0-1 kde-cli-tools-6.2.1-1 kde-gtk-config-6.2.1-1
kdeclarative-6.7.0-1 kdecoration-6.2.1-1 kded-6.7.0-1 kdeplasma-addons-6.2.1-1 kdesu-6.7.0-1 kdnssd-6.7.0-1
kfilemetadata-6.7.0-1 kglobalaccel-6.7.0-1 kglobalacceld-6.2.1-1 kguiaddons-6.7.0-2 kholidays-1:6.7.0-1
ki18n-6.7.0-1 kicad-8.0.6-1 kicad-library-8.0.6-1 kicad-library-3d-8.0.6-1 kiconthemes-6.7.0-1
kidletime-6.7.0-1 kinfocenter-6.2.1-1 kio-6.7.0-1 kirigami-6.7.0-1 kitemmodels-6.7.0-1 kitemviews-6.7.0-1
kjobwidgets-6.7.0-1 kmenuedit-6.2.1-1 knewstuff-6.7.0-1 knotifications-6.7.0-1 knotifyconfig-6.7.0-1
kpackage-6.7.0-1 kparts-6.7.0-1 kpeople-6.7.0-1 kpipewire-6.2.1-1 kplotting-6.7.0-1 kpty-6.7.0-1
kquickcharts-6.7.0-1 krunner-6.7.0-1 kscreen-6.2.1-1 kscreenlocker-6.2.1-1 kservice-6.7.0-1
ksshaskpass-6.2.1-1 kstatusnotifieritem-6.7.0-1 ksvg-6.7.0-1 ksystemstats-6.2.1-1 ktexteditor-6.7.0-2
ktexttemplate-6.7.0-1 ktextwidgets-6.7.0-1 kunitconversion-6.7.0-1 kuserfeedback-6.7.0-1 kwallet-6.7.0-1
kwallet-pam-6.2.1-1 kwayland-6.2.1-1 kwayland-integration-6.2.1-1 kwidgetsaddons-6.7.0-1 kwin-6.2.1.1-1
kwindowsystem-6.7.0-1 kxmlgui-6.7.0-1 layer-shell-qt-6.2.1-1 ldb-2:4.21.1-1 leptonica-1.85.0-2
lib32-glib2-2.82.2-1 lib32-libcups-2.4.11-1 lib32-libva-mesa-driver-1:24.2.5-1 lib32-mesa-1:24.2.5-1
lib32-mesa-vdpau-1:24.2.5-1 lib32-vulkan-intel-1:24.2.5-1 lib32-vulkan-mesa-layers-1:24.2.5-1
lib32-vulkan-radeon-1:24.2.5-1 libarchive-3.7.7-1 libcupsfilters-2.1.0-1 libkscreen-6.2.1-1
libksysguard-6.2.1-1 libngtcp2-1.8.1-1 libplasma-6.2.1-1 libppd-2.1.0-1 libtirpc-1.3.6-1 libuv-1.49.2-1
libva-mesa-driver-1:24.2.5-1 libwbclient-2:4.21.1-1 libxmlb-0.3.21-1 libzip-1.11.1-1
linux-firmware-20241017.22a6c7dc-1 linux-firmware-whence-20241017.22a6c7dc-1 linux-zen-6.11.4.zen1-1
linux-zen-headers-6.11.4.zen1-1 lutris-0.5.17-7 mesa-1:24.2.5-1 mesa-vdpau-1:24.2.5-1
mhwd-nvidia-560.35.03.16-1 milou-6.2.1-1 modemmanager-qt-6.7.0-1 networkmanager-qt-6.7.0-1 nodejs-22.10.0-1
ocean-sound-theme-6.2.1-1 ocenaudio-bin-3.14.5-2 plasma-activities-6.2.1-1 plasma-activities-stats-6.2.1-1
plasma-browser-integration-6.2.1-1 plasma-desktop-6.2.1-1 plasma-firewall-6.2.1-1 plasma-integration-6.2.1-1
plasma-nm-6.2.1-1 plasma-pa-6.2.1-1 plasma-systemmonitor-6.2.1-1 plasma-thunderbolt-6.2.1-1
plasma-workspace-6.2.1.1-1 plasma5-integration-6.2.1-1 plasma5support-6.2.1-1 polkit-kde-agent-6.2.1-1
poppler-24.09.0-4 poppler-glib-24.09.0-4 poppler-qt5-24.09.0-4 poppler-qt6-24.09.0-4 powerdevil-6.2.1-1
print-manager-1:6.2.1-1 prison-6.7.0-1 protobuf-28.2-3 purpose-6.7.0-1 pyenv-1:2.4.16-1 pyside6-6.8.0.1-2
python-coverage-7.6.3-1 python-protobuf-28.2-3 python-pyqt6-6.8.0dev2410141303-1 python-tensorflow-2.18rc2-1
python-trove-classifiers-2024.10.11-2 python-validate-pyproject-0.21-1 python-zope-interface-7.1.0-1
qqc2-breeze-style-6.2.1-1 qqc2-desktop-style-6.7.0-1 qt5-base-5.15.15+kde+r132-1 qt5-wayland-5.15.15+kde+r60-1
qt6-5compat-6.8.0-1 qt6-base-6.8.0-1 qt6-connectivity-6.8.0-1 qt6-declarative-6.8.0-2 qt6-imageformats-6.8.0-1
qt6-location-6.8.0-1 qt6-multimedia-6.8.0-1 qt6-multimedia-ffmpeg-6.8.0-1 qt6-networkauth-6.8.0-1
qt6-positioning-6.8.0-1 qt6-quick3d-6.8.0-1 qt6-quicktimeline-6.8.0-1 qt6-scxml-6.8.0-1 qt6-sensors-6.8.0-1
qt6-shadertools-6.8.0-1 qt6-speech-6.8.0-1 qt6-svg-6.8.0-1 qt6-tools-6.8.0-1 qt6-translations-6.8.0-1
qt6-virtualkeyboard-6.8.0-1 qt6-wayland-6.8.0-1 qt6-webchannel-6.8.0-1 qt6-webengine-6.8.0-5
qt6-websockets-6.8.0-1 resvg-0.44.0-1 rpi-imager-1.9.0-3 ruby-3.3.5-2 ruby-bundled-gems-3.3.5-2
ruby-bundler-2.5.16-1 ruby-debug-1.9.1-1 ruby-default-gems-3.3.5-2 ruby-erb-4.0.4-6 ruby-irb-1.13.1-1
ruby-matrix-0.4.2-2 ruby-minitest-5.22.3-2 ruby-net-ftp-0.3.5-3 ruby-net-imap-0.4.12-3 ruby-net-pop-0.1.2-3
ruby-net-smtp-0.5.0-3 ruby-power_assert-2.0.3-5 ruby-prime-0.1.2-2 ruby-racc-1.7.3-1 ruby-rake-13.1.0-1
ruby-rbs-3.4.4-3 ruby-rdoc-6.6.3.1-1 ruby-rexml-3.3.2-2 ruby-rss-0.3.1-2 ruby-stdlib-3.3.5-2
ruby-test-unit-3.6.2-3 ruby-typeprof-0.21.9-1 rubygems-3.5.16-1 ruff-0.7.0-1 samba-2:4.21.1-1
sddm-kcm-6.2.1-1 shiboken6-6.8.0.1-2 smbclient-2:4.21.1-1 solid-6.7.0-1 sonnet-6.7.0-1 starship-1.21.1-1
subversion-1.14.3-3 syndication-6.7.0-1 syntax-highlighting-6.7.0-1 systemsettings-6.2.1-1
telegram-desktop-5.6.3-1 tensorflow-2.18rc2-1 threadweaver-6.7.0-1 tpm2-tss-4.1.3-1 vim-runtime-9.1.0785-1
virtiofsd-1.12.0-1 virtualbox-7.1.4-1 virtualbox-guest-iso-7.1.4-1 virtualbox-host-dkms-7.1.4-1
vte-common-0.78.1-1 vte3-0.78.1-1 vulkan-intel-1:24.2.5-1 vulkan-mesa-layers-1:24.2.5-1
vulkan-radeon-1:24.2.5-1 vulkan-swrast-1:24.2.5-1 wireless-regdb-2024.10.07-1 xdg-desktop-portal-kde-6.2.1-1
xf86-input-evdev-2.11.0-1 xf86-input-libinput-1.5.0-1 xnviewmp-1.8.2-1
