On very old AMD PC, no wallpaper, calamares open full screen.
inxi -Fxxxza
Kernel: 5.11.15-zen1-2-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=de_DE keytable=de tz=Europe/Berlin
misobasedir=garuda misolabel=GARUDA_SWAY_SOARING_ quiet systemd.show_status=1
systemd.unified_cgroup_hierarchy=1 driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
Desktop: sway 1.6 vt: 1 dm: N/A Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: MEDIONPC model: MS-7501 v: 3.1 serial: <filter>
BIOS: American Megatrends v: A7501MLN.30E date: 04/28/2009
Info: Quad Core model: AMD Phenom 9650 bits: 64 type: MCP arch: K10 family: 10 (16)
model-id: 2 stepping: 3 microcode: 1000095 cache: L2: 2 MiB
flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 18360
Speed: 2300 MHz min/max: 1150/2300 MHz Core speeds (MHz): 1: 2300 2: 2300 3: 2300
4: 2300
Type: spec_store_bypass status: Not affected
Type: spectre_v2 mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD RV710 [Radeon HD 4550] vendor: PC Partner Limited driver: radeon
v: kernel bus-ID: 01:00.0 chip-ID: 1002:9540 class-ID: 0300
Display: wayland server: X.Org 1.21.1.1 compositor: sway v: 1.6 driver:
loaded: radeon note: n/a (using device driver) display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x318mm (20.0x12.5")
s-diag: 599mm (23.6")
OpenGL: renderer: AMD RV710 (DRM 2.50.0 / 5.11.15-zen1-2-zen LLVM 11.1.0)
v: 3.3 Mesa 21.0.3 compat-v: 3.0 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
Device-2: AMD RV710/730 HDMI Audio [Radeon HD 4000 series]
vendor: PC Partner Limited driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aa38 class-ID: 0403
Sound Server-1: ALSA v: k5.11.15-zen1-2-zen running: yes
Sound Server-3: JACK v: 0.125.0 running: no
Sound Server-4: PulseAudio v: 14.2 running: yes
Sound Server-5: PipeWire v: 0.3.25 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: e800 bus-ID: 02:00.0
Device-2: IMC Networks AW-NU222 802.11bgn Wireless Module [Ralink RT2770+RT2720]
type: USB driver: rt2800usb bus-ID: 2-4:4 chip-ID: 13d3:3247 class-ID: 0000
IF: wlan0 state: down mac: <filter>
Local Storage: total: 1.5 TiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD6400AACS-00G8B1
size: 596.17 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
serial: <filter> rev: 4C05 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HDT721010SLA360 size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s rotation: 7200 rpm
serial: <filter> rev: A31B scheme: MBR
ID-3: /dev/sdf maj-min: 8:80 type: USB model: UDISK PDU01 8G 98I2.0 size: 7.22 GiB
block-size: physical: 512 B logical: 512 B speed: <unknown> serial: <filter>
rev: 0.00 scheme: MBR
Kernel: swappiness: 10 (default 60) cache-pressure: 75 (default 100)
ID-1: swap-1 type: zram size: 981.5 MiB used: 478.6 MiB (48.8%) priority: 32767
ID-2: swap-2 type: zram size: 981.5 MiB used: 479.3 MiB (48.8%) priority: 32767
dev: /dev/zram1
ID-3: swap-3 type: zram size: 981.5 MiB used: 477.4 MiB (48.6%) priority: 32767
dev: /dev/zram2
ID-4: swap-4 type: zram size: 981.5 MiB used: 478 MiB (48.7%) priority: 32767
dev: /dev/zram3
Message: No sensor data found. Is lm-sensors configured?
Processes: 207 Uptime: 17m wakeups: 0 Memory: 3.83 GiB used: 3.03 GiB (79.1%)
Init: systemd v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages:
pacman: 1187 lib: 294 Shell: fish v: 3.2.1 default: Bash v: 5.1.4
running-in: alacritty inxi: 3.3.04
sudo -E calamares -d
QStandardPaths: runtime directory '/run/user/1000' is not owned by UID 0, but a directory permissions 0700 owned by UID 1000 GID 1000
06:10:39 [6]: Calamares::Settings::Settings(const QString&, bool)
Using Calamares settings file at "/etc/calamares/settings.conf"
WARNING: .. Required settings.conf key hide-back-and-next-during-exec is missing.
06:10:39 [6]: void Logger::setupLogfile()
Using log file: "/home/garuda/.cache/calamares/session.log"
06:10:39 [6]: void CalamaresApplication::init()
Calamares version: 3.2.39.3-2.3
.. languages: "ar, as, ast, az, az_AZ, be, bg, bn, ca, [email protected], cs_CZ, da, de, el, en, en_GB, eo, es, es_MX, es_PR, et, eu, fa, fi_FI, fr, fur, gl, he, hi, hr, hu, id, is, it_IT, ja, ko, lt, ml, mr, nb, nl, pl, pt_BR, pt_PT, ro, ru, sk, sl, sq, sr, [email protected], sv, tg, th, tr_TR, uk, vi, zh_CN, zh_TW"
06:10:39 [6]: bool CalamaresUtils::initQmlModulesDir()
Using Calamares QML directory "/usr/share/calamares/qml"
06:10:39 [6]: Calamares::Branding::Branding(const QString&, QObject*)
Using Calamares branding file at "/usr/share/calamares/branding/garuda/branding.desc"
06:10:39 [2]: void Calamares::flavorAndSide(const YAML::Node&, const char*, Calamares::Branding::PanelFlavor&, Calamares::Branding::PanelSide&)
WARNING: Branding setting for sidebar is missing, using "widget" "left"
WARNING: Branding setting for navigation is missing, using "widget" "bottom"
06:10:39 [2]: Calamares::Branding::Branding(const QString&, QObject*)
WARNING: the branding component "/usr/share/calamares/branding/garuda" does not ship translations.
Loaded branding component "garuda"
.. No translation for "tz_" "de_DE" using default (en)
.. Loaded QRC translation "calamares_" "de_DE"
.. STARTUP: initSettings, initQmlPath, initBranding done
.. STARTUP: initModuleManager: module init started
06:10:39 [6]: void Calamares::ModuleManager::doInit()
Found 49 modules
06:10:39 [6]: void CalamaresApplication::initView()
STARTUP: initModuleManager: all modules init done
STARTUP: initJobQueue done
06:10:39 [6]: CalamaresWindow::CalamaresWindow(QWidget*)
Available desktop QSize(1920, 1200) minimum size QSize(1024, 520)
.. Proposed window size: 1024 600
06:10:39 [2]: QString Calamares::_stylesheet(const QDir&)
WARNING: The branding component "/usr/share/calamares/branding/garuda" does not ship stylesheet.qss.
STARTUP: CalamaresWindow created; loadModules started
06:10:40 [6]: void Calamares::Module::loadConfigurationFile(const QString&)
Loaded module configuration "/etc/calamares/modules/welcome.conf"
06:10:40 [6]: void Config::initLanguages()
Matching locale QLocale(German, Latin, Germany)
.. Matched with index 12 "de_DE"
06:10:40 [6]: void Config::setLocaleIndex(int)
Index 12 Selected locale QLocale(German, Latin, Germany)
06:10:40 [0]: propsReply "Method \"GetAll\" with signature \"s\" on interface \"org.freedesktop.DBus.Properties\" doesn't exist\n"
06:10:40 [0]: nmReply "Method \"GetDevices\" with signature \"\" on interface \"org.freedesktop.NetworkManager\" doesn't exist\n"
06:10:40 [0]: "Object path cannot be empty"
06:10:40 [8]: "Not supported"
06:10:40 [6]: QPair<CalamaresUtils::Network::RequestStatus, QNetworkReply*> CalamaresUtils::Network::synchronousRun(QNetworkAccessManager*, const QUrl&, const CalamaresUtils::Network::RequestOptions&)
HTTP error QNetworkReply::ConnectionRefusedError on request for QUrl("https://ipapi.co/json")
06:10:40 [2]: virtual QString CalamaresUtils::GeoIP::GeoIPJSON::rawReply(const QByteArray&)
WARNING: Invalid YAML data for GeoIPJSON
06:10:42 [6]: virtual void Calamares::ViewModule::loadSelf()
ViewModule "[email protected]" loading complete.
06:10:42 [6]: void Calamares::Module::loadConfigurationFile(const QString&)
Loaded module configuration "/etc/calamares/modules/locale.conf"
Loaded module configuration "/usr/share/calamares/modules/keyboard.conf"
06:10:42 [6]: KeyboardModelsModel::KeyboardModelsModel(QObject*)
Loaded 188 keyboard models
06:10:42 [6]: KeyboardPage::KeyboardPage(Config*, QWidget*)
Variants now 0 -1
06:10:43 [6]: virtual void Calamares::ViewModule::loadSelf()
06:10:43 [6]: void Calamares::Module::loadConfigurationFile(const QString&)
Loaded module configuration "/usr/share/calamares/modules/partition.conf"
06:10:43 [6]: CalamaresUtils::Partition::InternalManager::InternalManager()
KPMCore backend starting ..
06:10:43 [8]: Loaded backend plugin: "pmsfdiskbackendplugin"
.. Backend @0x561300ffd170 "pmsfdiskbackendplugin" "1"
06:10:43 [6]: CalamaresUtils::Partition::KPMManager::KPMManager()
KPMManager 1 created.
06:10:43 [6]: virtual void PartitionViewStep::setConfigurationMap(const QVariantMap&)
Setting firmwareType to "bios"
06:10:43 [6]: QString PartUtils::findFS(QString, FileSystem::Type*)
Found filesystem "ext4"
Partition-module setting *defaultFileSystemType* "ext4"
06:10:43 [2]: virtual void PartitionViewStep::setConfigurationMap(const QVariantMap&)
WARNING: Partition-module setting *defaultPartitionTableType* is unset, will use gpt for efi or msdos for bios
Loaded module configuration "/etc/calamares/modules/users.conf"
06:10:43 [6]: void Calamares::ModuleManager::loadModules()
Module "[email protected]" already loaded.
06:10:47 [6]: Calamares::SlideshowQML::SlideshowQML(QWidget*)
QML import paths:
"/usr/bin"
"qrc:/qt-project.org/imports"
"/usr/lib/qt/qml"
06:10:47 [6]: void Calamares::Module::loadConfigurationFile(const QString&)
Loaded module configuration "/usr/share/calamares/modules/mount.conf"
Loaded module configuration "/etc/calamares/modules/unpackfs.conf"
Loaded module configuration "/etc/calamares/modules/machineid.conf"
06:10:47 [2]: virtual void MachineIdJob::setConfigurationMap(const QVariantMap&)
WARNING: MachineId: configuration setting *symlink* is deprecated, use *dbus-symlink*.
06:10:47 [6]: virtual void Calamares::CppJobModule::loadSelf()
CppJobModule "[email protected]" loading complete.
Loaded module configuration "/usr/share/calamares/modules/fstab.conf"
06:10:47 [6]: void Calamares::ModuleManager::loadModules()
Loaded module configuration "/usr/share/calamares/modules/luksopenswaphookcfg.conf"
Loaded module configuration "/etc/calamares/modules/plymouthcfg.conf"
No config file for "initcpiocfg" found anywhere at
"/home/garuda/src/modules/initcpiocfg/initcpiocfg.conf"
"/etc/calamares/modules/initcpiocfg.conf"
"/usr/share/calamares/modules/initcpiocfg.conf"
Loaded module configuration "/etc/calamares/modules/initcpio.conf"
Loaded module configuration "/etc/calamares/modules/displaymanager.conf"
Loaded module configuration "/etc/calamares/modules/mhwdcfg.conf"
Loaded module configuration "/etc/calamares/modules/services.conf"
Loaded module configuration "/usr/share/calamares/modules/grubcfg.conf"
Loaded module configuration "/etc/calamares/modules/bootloader.conf"
Loaded module configuration "/etc/calamares/modules/postcfg.conf"
Loaded module configuration "/usr/share/calamares/modules/umount.conf"
Loaded module configuration "/etc/calamares/modules/finished.conf"
06:10:47 [2]: void Config::setConfigurationMap(const QVariantMap&)
WARNING: Configuring the finished module with deprecated restartNowEnabled settings
06:10:47 [6]: virtual void Calamares::ViewModule::loadSelf()
06:10:47 [6]: setGeoIP(Config*, const QVariantMap&)::<lambda()>
GeoIP result for welcome= ""
06:10:47 [6]: void setCountry(Config*, const QString&, CalamaresUtils::GeoIP::Handler*)
Unusable country code ""
.. Obtained from "https://ipapi.co/json" ( 1 "country" )
Authorization required, but no authorization protocol specified
Cannot open display ":0"
06:10:47 [6]: Config::Config(QObject*)::<lambda(int)>::<lambda()>
xkbmap selection changed to: "af" - ""
06:10:47 [6]: void CalamaresApplication::initViewSteps()
STARTUP: loadModules for all modules done
06:10:47 [6]: void Calamares::ModuleManager::checkRequirements()
Checking module requirements ..
06:10:48 [6]: void CalamaresApplication::initViewSteps()
STARTUP: Window now visible and ProgressTreeView populated
.. 8 view steps loaded.
.. No translation for "kb_" "de_DE" using default (en)
fish: Job 1, 'sudo -E calamares -d' terminated by signal SIGBUS (Fehler: nicht ausgerichtete Adresse)
sudo -E calamares
06:12:05 [0]: propsReply "Method \"GetAll\" with signature \"s\" on interface \"org.freedesktop.DBus.Properties\" doesn't exist\n"
06:12:05 [0]: nmReply "Method \"GetDevices\" with signature \"\" on interface \"org.freedesktop.NetworkManager\" doesn't exist\n"
06:12:05 [0]: "Object path cannot be empty"
fish: Job 1, 'sudo -E calamares' terminated by signal SIGBUS (Fehler: nicht ausgerichtete Adresse)
Screenshot as alibi
