""" Unrecognized option: --illegal-access=permit
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit. """
I see this error when ı burpsuite work. How can ı fix this problem ??
Where did you install burp suite from? Blackarch Repo? How ?
Also, post output of inxi -Faz
as text enclosed with ~~~
Check if the hint below on setting jdk-11 as default helps, because it seems that the option above is valid after jdk-8, which is often the default.
https://wiki.archlinux.org/title/Burp_suite#Fix_“An_unknown_error_has_occurred”
Apart from that, I hope someone can help better. I’m not an expert.
But remember that blackarch is not officially supported…
Thank u so much. God bless u. I can fixed.
