Hi everyone. I noticed that my webcam is not working, or not found to be exact. I have been searching for a solution with no luck so far. lshw | grep webcam is not giving me any info, same as lsusb and lspci. I know it was several days because I have had a zoom meeting. So here I am. Here is my “gardua-inxi” output below.
root=UUID=e3358bab-8e05-4deb-bb10-5d3077e74637 rw rootflags=subvol=@
loglevel=3 quiet splash nvidia_drm.modeset=1 ibt=off
Type: Laptop System: Alienware product: Alienware x14 v: 1.5.0
Mobo: Alienware model: 0J3PYX v: A01 serial: <superuser required>
UEFI: Alienware v: 1.5.0 date: 07/11/2022
ID-1: BAT1 charge: 59.4 Wh (100.0%) condition: 59.4/80.5 Wh (73.8%)
volts: 12.7 min: 11.4 model: COMPAL PABAS0241231 type: Li-ion
serial: <filter> status: full cycles: 381
Info: model: 12th Gen Intel Core i7-12700H bits: 64 type: MST AMCP
microcode: 0x430
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 467 high: 755 min/max: 400/4600:4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 499 2: 400 3: 400 4: 400
5: 650 6: 400 7: 400 8: 400 9: 400 10: 731 11: 400 12: 400 13: 400 14: 400
15: 400 16: 755 17: 400 18: 400 19: 719 20: 400 bogomips: 107520
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-2 empty: DP-2, DP-3, DP-4, DP-5 bus-ID: 0000:00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA107BM [GeForce RTX 3050 Mobile] vendor: Dell
driver: nvidia v: 545.29.02 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 ports: active: none
empty: DP-1,HDMI-A-1,eDP-1 bus-ID: 0000:01:00.0 chip-ID: 10de:25e2
compositor: Hyprland driver: X: loaded: modesetting,nvidia unloaded: nouveau
alternate: fbdev,intel,nv,vesa dri: iris gpu: i915,nvidia display-ID: 1
Monitor-1: eDP-2 res: 1920x1080 size: N/A modes: N/A
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: nvidia
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3050 Laptop
GPU/PCIe/SSE2 memory: 3.91 GiB
API: Vulkan v: 1.3.269 layers: 11 device: 0 type: integrated-gpu
name: Intel Graphics (ADL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:46a6 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce RTX 3050 Laptop GPU driver: nvidia
v: 545.29.02 device-ID: 10de:25e2 surfaces: xcb,xlib,wayland device: 2
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
Device-2: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1
chip-ID: 10de:2291 class-ID: 0403
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.85 status: active with: 1: pipewire-pulse
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c010c
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 168.96 GiB (35.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM9A1 NVMe 512GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 36308229 temp: 43.9 C
ID-1: / raw-size: 287.92 GiB size: 287.92 GiB (100.00%)
used: 74.46 GiB (25.9%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 287.92 GiB size: 287.92 GiB (100.00%)
ID-4: /var/log raw-size: 287.92 GiB size: 287.92 GiB (100.00%)
ID-5: /var/tmp raw-size: 287.92 GiB size: 287.92 GiB (100.00%)
ID-1: swap-1 type: partition size: 19.53 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: swap-2 type: zram size: 15.29 GiB used: 1024 KiB (0.0%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20
System Temperatures: cpu: 52.0 C mobo: N/A
Processes: 430 Uptime: 6m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.29 GiB used: 5.29 GiB (34.6%) Init: systemd v: 254
Packages: pm: pacman pkgs: 2241 libs: 604 tools: octopi,pamac,paru,yay
Shell: fish v: 3.6.1 running-in: guake inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-11-02
Last full system update: 2023-11-20
